查看: 2578|回復: 1
MC96F6508A測溫C程序
ID:62214 發表于 2020-4-5 02:39 | 顯示全部樓層 |閱讀模式
#include <mc96f6508a.h>
#include <intrins.h>
#include        "MC96F6508A.h"
#include        "func_def.h"
#include"lcd.h"
#include"temp.h"
#define uchar unsigned char
#define uint unsigned int
void LcdDisplay(int);
* 函數名         : main
* 函數功能                   : 主函數
* 輸入           : 無
* 輸出                  : 無
main()
        P1IO                = 0xff;                        // 輸出P1 Direction Register
    P1OD                = 0xff;                        //漏極開路輸出 P1 Open-drain Selection Register
    P1PU                = 0xff;                        // 內部上拉電阻P1 Pull-up Resistor Selection Register
    P1DB                = 0xff;                        //消抖
        P2IO                = 0xf0;                        // 輸出P1 Direction Register
    P2OD                = 0x00;                        //漏極開路輸出 P1 Open-drain Selection Register
    P2PU                = 0xff;                        // 內部上拉電阻P1 Pull-up Resistor Selection Register
    P2FSR                = 0x00;                        //
        P3IO                = 0xff;                        // 輸出P1 Direction Register
    P3OD                = 0x00;                        //漏極開路輸出 P1 Open-drain Selection Register
    P3PU                = 0xff;                        // 內部上拉電阻P1 Pull-up Resistor Selection Register
    P3FSR                = 0x00;                        //消抖
        P4IO                = 0xff;                        // 輸出P1 Direction Register
    P4OD                = 0xff;                        //漏極開路輸出 P1 Open-drain Selection Register
    P4PU                = 0xff;                        // 內部上拉電阻P1 Pull-up Resistor Selection Register
    P4FSR                = 0x00;                        //消抖
        P5IO                = 0xff;                        // 輸出P1 Direction Register
    P5OD                = 0xff;                        //漏極開路輸出 P1 Open-drain Selection Register
    P5PU                = 0xf0;                        // 內部上拉電阻P1 Pull-up Resistor Selection Register
    P5FSRH                = 0xff;                        //
        P5FSRL                = 0xff;
                P6IO                = 0xff;                        // 輸出P1 Direction Register
    P6OD                = 0xff;                        //漏極開路輸出 P1 Open-drain Selection Register
    P6PU                = 0xff;                        // 內部上拉電阻P1 Pull-up Resistor Selection Register
    P6FSR                = 0x0f;                        // 設置為Xin/Xout
        P0IO                = 0x00;                        // 輸出P1 Direction Register
    P0OD                = 0xff;                        //漏極開路輸出 P1 Open-drain Selection Register
    P0PU                = 0xff;                        // 內部上拉電阻P1 Pull-up Resistor Selection Register
    P0DB                = 0xff;                        //消抖
        P4=0xff;
                // internal RC clock (16.000000MHz)
        OSCCR = 0x08;           // Set Int. OSC
        SCCR = 0x00;            // Use Int. OSC
        //P4=0x00;
        //DSPORT=0;
        //OSCCR = 0x28;           // 外部主時鐘
        //SCCR = 0x00;            // 打開外部主時鐘
        LcdInit();                         //初始化LCD1602
        LcdWriteCom(0x88);        //寫地址 80表示初始地址
        LcdWriteData('C');
                LcdDisplay(Ds18b20ReadTemp());
                //Delay1ms(1000);//1s鐘刷一次
* 函數名         : LcdDisplay()
* 函數功能                   : LCD顯示讀取到的溫度
* 輸入           : v
* 輸出                  : 無
void LcdDisplay(int temp)          //lcd顯示
          unsigned char datas[] = {0, 0, 0, 0, 0}; //定義數組
        float tp;
        if(temp< 0)                                //當溫度值為負數
                  LcdWriteCom(0x80);                //寫地址 80表示初始地址
            LcdWriteData('-');                  //顯示負
                //因為讀取的溫度是實際溫度的補碼,所以減1,再取反求出原碼
                temp=temp-1;
                temp=~temp;
                tp=temp;
                temp=tp*0.0625*100+0.5;
                //留兩個小數點就*100,+0.5是四舍五入,因為C語言浮點數轉換為整型的時候把小數點
                //后面的數自動去掉,不管是否大于0.5,而+0.5之后大于0.5的就是進1了,小于0.5的就
                //算由?.5,還是在小數點后面。
            LcdWriteData('+');                 //顯示正
                tp=temp;//因為數據處理有小數點所以將溫度賦給一個浮點型變量
                //如果溫度是正的那么,那么正數的原碼就是補碼它本身
                //算加上0.5,還是在小數點后面。
        datas[0] = temp / 10000;
        datas[1] = temp % 10000 / 1000;
        datas[2] = temp % 1000 / 100;
        datas[3] = temp % 100 / 10;
        datas[4] = temp % 10;
        LcdWriteCom(0x82);                  //寫地址 80表示初始地址
        LcdWriteData('0'+datas[0]); //百位
        LcdWriteCom(0x83);                 //寫地址 80表示初始地址
        LcdWriteData('0'+datas[1]); //十位
        LcdWriteCom(0x84);                //寫地址 80表示初始地址
        LcdWriteData('0'+datas[2]); //個位
        LcdWriteCom(0x85);                //寫地址 80表示初始地址
        LcdWriteData('.');                 //顯示 ‘.’
        LcdWriteCom(0x86);                 //寫地址 80表示初始地址
        LcdWriteData('0'+datas[3]); //顯示小數點
        LcdWriteCom(0x87);                 //寫地址 80表示初始地址
        LcdWriteData('0'+datas[4]); //顯示小數點
ID:62214 發表于 2020-4-5 20:22 | 顯示全部樓層
補全電路原理圖,源碼,
temperature.pdf
56.3 KB, 下載次數: 5, 下載積分: 黑幣 -5
temperature.zip
76.23 KB, 下載次數: 3, 下載積分: 黑幣 -5
主站蜘蛛池模板: 色天堂影院 | 亚洲看片| 午夜婷婷 | 久久99精品国产麻豆91樱花 | 91av免费在线观看 | 可以看毛片的网站 | 精品免费在线 | 九九视频在线观看 | 日韩黄色一级片 | 男女啪啪免费视频 | 69av在线播放 | 激情另类小说 | 中文字幕av网站 | 中文字幕在线一区二区三区 | 日韩国产精品一区二区 | 中文字幕第一区 | 国产99对白在线播放 | 在线观看黄色片 | 国产精品久久久久久久久久 | 日本一区二区三区四区五区 | 一区二区视频在线播放 | 激情做爰呻吟视频舌吻 | 91精品国产乱码久久久久 | 久久久久精 | 亚洲福利视频一区 | 精品欧美黑人一区二区三区 | 亚洲国产精品一区二区三区 | 在线成人免费 | 特黄aaaaaaaaa真人毛片 | 东方成人av | 日韩a在线 | 亚洲午夜在线 | 欧美9999 | 激情五月激情综合网 | av福利网站 | 天天操夜夜骑 | 成年人免费视频网站 | 美女视频一区二区 | 九九久久精品视频 | 国产精品久久久久久久久久辛辛 | 国产区视频在线观看 |
