查看: 4302|回復: 2
Proteus模擬Arduino控制LED矩陣顯示屏測試程序
// Arduino 328 用16行*32列 LED矩陣顯示屏基礎測試程序,主頻是32MHz,在主菜單Project->工程設置中修改
// 項目格式 Proteus V8.9 SP2版本,測試如圖所示。
// 源代碼如下。
int A = 8;
int B = 9;
int C = 10;
int D = 11;
int DE = 12;
int LATCH = 2; //鎖存信號 Latch
int SCLK = 3; //時鐘信號 Shift Clock
int R0 = 4; //數據輸入 ,Data Shift in
char datain=0x0F;
int refreshtime=500;
int i=0,LineNum=0; // 臨時循環變量
#define NumOf74HC595  3// 從0開始查數,實際上是4個,0也算一個。
unsigned char zimo[][32]={
{0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x3F,0xF8,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x3F,0xF8,0x21,0x08,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00},/*"中",0*/
/* (16 X 16 , 宋體 )*/
{0x00,0x00,0x7F,0xFC,0x40,0x04,0x40,0x04,0x5F,0xF4,0x41,0x04,0x41,0x04,0x4F,0xE4,0x41,0x04,0x41,0x44,0x41,0x24,0x5F,0xF4,0x40,0x04,0x40,0x04,0x7F,0xFC,0x40,0x04},/*"國",1*/
{0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x7C,0xFE,0x44,0x12,0x44,0x12,0x44,0x12,0x44,0x12,0x44,0x12,0x44,0x12,0x44,0x12,0x44,0x22,0x44,0x22,0x7C,0x4A,0x44,0x84,0x00},/*"加",2*/
{0x00,0x40,0x20,0x40,0x10,0x40,0x10,0x40,0x87,0xFC,0x44,0x44,0x44,0x44,0x14,0x44,0x14,0x44,0x27,0xFC,0xE4,0x44,0x24,0x44,0x24,0x44,0x24,0x44,0x27,0xFC,0x04,0x04},/*"油",3*/
unsigned char DisplayBuffer[16][4]={};  // 16行*32(4*8bit)列的顯示緩沖區,與LED點陣屏一一對應,要顯示什么內容,先把內容復制到這個緩沖區中即可。
void setup() {
  pinMode(LATCH, OUTPUT);
  pinMode(SCLK, OUTPUT);
  pinMode(R0, OUTPUT);
  pinMode(A, OUTPUT);
  pinMode(B, OUTPUT);
  pinMode(C, OUTPUT);
  pinMode(D, OUTPUT);
  pinMode(DE, OUTPUT);
  DDRB=0xFF;  // 8 pin output
  digitalWrite(DE, HIGH); // 關閉138的輸出,顯示屏不會亮
    // 填充顯示緩沖區
  for(LineNum=0;LineNum<16;LineNum++)
     DisplayBuffer[LineNum][NumOf74HC595]=zimo[2][LineNum*2];
     DisplayBuffer[LineNum][NumOf74HC595-1]=zimo[2][LineNum*2+1];
     DisplayBuffer[LineNum][NumOf74HC595-2]=zimo[3][LineNum*2];
     DisplayBuffer[LineNum][NumOf74HC595-3]=zimo[3][LineNum*2+1];
void loop() {
    digitalWrite(DE, HIGH); // 關閉138的輸出,防止顯示串行
    PORTB=0xF0 | LineNum;    // 選擇第LineNum行
    for (i = 0; i <= NumOf74HC595; i++)
    {  // 本電路圖中有4個595芯片,所以這里是4
       // 串行輸出數據
       digitalWrite(LATCH, LOW);
       shiftOut(R0, SCLK, MSBFIRST, DisplayBuffer[LineNum][NumOf74HC595-i]);
       digitalWrite(LATCH, HIGH);
     digitalWrite(DE, LOW); // 打開138的輸出,點亮相應的行
     delayMicroseconds(refreshtime); // 每行數據的顯示停留時間
LEDMatrix1632_8_9.rar
73.47 KB, 下載次數: 22, 下載積分: 黑幣 -5
ID:685875 發表于 2020-4-26 23:49 | 只看該作者
Arduino 328  主頻是32MHz?
ID:306434 發表于 2022-1-26 07:43 | 只看該作者
gch1 發表于 2020-4-26 23:49
可以改,主頻低的話,顯示效果不好!
主站蜘蛛池模板: 欧美亚洲视频在线观看 | 久久精品国产一区二区三区 | 日本高清中文字幕 | 日本欧美黄色片 | 一区二区三区视频在线观看 | 中文天堂在线观看 | 久久精品国产亚洲一区二区三区 | 夜夜爆操 | 四虎午夜剧场 | 一区二区在线观看av | 亚洲精品一区二区三区蜜桃久 | 狠狠干狠狠操 | 国内精品成人 | 日韩不卡一区二区 | 国产探花在线精品一区二区 | 国产精品久久久久久久久婷婷 | 久久久不卡网国产精品一区 | 精品伦精品一区二区三区视频 | 久久一级免费视频 | 国产成人精品一区二区三区 | 免费国产一区二区视频 | 久久五月婷 | 天天干夜夜| 日韩精品一区二区三区免费观看 | 精品视频一区二区三区在线观看 | 亚洲国产精品久久久久婷婷老年 | av中文字幕在线观看 | 中文字幕免费在线观看 | 色天堂影院 | 成年人国产在线观看 | 精品乱子伦一区二区三区 | 午夜影院在线观看视频 | 91香蕉视频在线观看 | 久久亚洲一区二区 | 中文在线一区二区 | 欧美天堂一区 | 电影91久久久 | 91中文视频 | 亚洲视频欧美视频 | 96久久久久久 | 在线观看免费av片 |
