查看: 7495|回復(fù): 13
單片機(jī)電子密碼鎖仿真
  1. #include<reg52.h>
  2. #define uint unsigned int
  4. void key_scan();
  5. uchar count0,count1,count3,num,n=0,temp,a,j,count4;
  6. uchar mima[8];                                                        //初始密碼存儲區(qū)
  7. uchar tab_key[50];                                                //輸入密碼存儲區(qū)
  8. uchar code table[]={
  9. 0x3f,0x06,0x5b,0x4f,
  10. 0x66,0x6d,0x7d,0x07,
  11. 0x7f,0x6f,0x77,0x7c,
  12. 0x39,0x5e,0x79,0x71};
  13. bit enterflag;                                                        //確認(rèn)鍵按下與否的標(biāo)志
  14. bit mimaflag;                                                        //密碼正確與否的標(biāo)志
  15. bit xiugaiflag;                                                        //修改密碼標(biāo)志
  16. bit enter1flag;                                                //修改密碼確認(rèn)鍵標(biāo)志
  17. sbit red=P3^7;
  18. sbit bell=P3^6;
  19. sbit rs=P2^0;
  20. sbit rw=P2^1;
  21. sbit lcden=P2^2;
  22. sbit scl=P3^4;
  23. sbit sda=P3^5;
  24. uchar code table1[]="input the passco";
  25. uchar code table2[]="de:     --------";
  26. uchar code table3[]="*";
  27. uchar code table4[]="right   (^_^)   ";
  28. uchar code table5[]="first  error!!!!";
  29. uchar code table6[]="second error!!!!";
  30. uchar code table7[]="third error see ";
  31. uchar code table8[]="u tomorrow (^_^)";
  32. uchar code table9[]="define the passc";
  33. uchar code table10[]="ode:    --------";
  34. uchar code table11[]="code   is    new";
  35. //******************************鍵盤消抖函數(shù)*******************************
  36. void delay1()
  37. { ;; }
  38. void delay2(uchar x)
  39. {
  40.         uchar a,b;
  41.         for(a=x;a>0;a--)
  42.          for(b=100;b>0;b--);
  43. }
  44.
  45. void delay(uint z)
  46. {
  47.         uint x,y;
  48.         for(x=z;x>0;x--)
  49.                 for(y=110;y>0;y--);
  50. }
  51. //****************************e^2room的初始化*******************************
  52. void start()  //開始信號
  53. {
  54.         sda=1;
  55.         delay1();
  56.         scl=1;
  57.         delay1();
  58.         sda=0;
  59.         delay1();
  60. }
  61. void stop()   //停止
  62. {
  63.         sda=0;
  64.         delay1();
  65.         scl=1;
  66.         delay1();
  67.         sda=1;
  68.         delay1();
  69. }
  70. //****************************應(yīng)答信號*************************************
  71. void respond()
  72. {
  73.         uchar i;
  74.         scl=1;
  75.         delay1();
  76.         while((sda==1)&&(i<250))i++;
  77.         scl=0;
  78.         delay1();
  79. }
  80. //*****************************寫字節(jié)操作函數(shù)**********************************
  81. void write_byte(uchar date)
  82. {
  83.         uchar i,temp;
  84.         temp=date;
  85.         for(i=0;i<8;i++)
  86.         {
  87.                 temp=temp<<1;                        //保持最高位,左移到進(jìn)位CY
  88.                 scl=0;
  89.             delay1();
  90.                 sda=CY;
  91.                 delay1();
  92.                 scl=1;
  93.                 delay1();
  94.         }
  95.         scl=0;
  96.         delay1();
  97.         sda=1;//總線釋放
  98.         delay1();
  99. }
  100. //*******************************讀字節(jié)操作函數(shù)*****************************
  101. uchar read_byte()
  102. {
  103.         uchar i,k;
  104.         scl=0;
  105.         delay1();
  106.         sda=1;
  107.         delay1();
  108.         for(i=0;i<8;i++)
  109.         {
  110.                 scl=1;
  111.                 delay1();
  112.                 k=(k<<1)|sda;    //或運(yùn)算,放到最低位
  113.                 scl=0;
  114.                 delay1();
  115.         }
  116.         return k;
  117. }
  118. //**********************************寫地址函數(shù)******************************
  119. void write_add(uchar address,uchar date)
  120. {
  121.         start();
  122.         write_byte(0xa0);
  123.         respond();
  124.         write_byte(address);
  125.         respond();
  126.         write_byte(date);
  127.         respond();
  128.         stop();
  129. }
  130. //*******************************讀地址函數(shù)*************************************
  131. uchar read_add(uchar address)
  132. {
  133.         uchar date;
  134.         start();
  135.         write_byte(0xa0);
  136.         respond();
  137.         write_byte(address);
  138.         respond();
  139.         start();
  140.         write_byte(0xa1);
  141.         respond();
  142.         date=read_byte();
  143.         stop();
  144.         return date;
  145. }
  146. //****************************LCD1602的初始化*******************************
  147. void write_com(uchar com)
  148. {
  149.         rs=0;
  150.         lcden=0;
  151.         P0=com;
  152.         delay(5);
  153.         lcden=1;
  154.         delay(5);
  155.         lcden=0;
  156. }
  157. void write_date(uchar date)
  158. {
  159.         rs=1;
  160.         lcden=0;
  161.         P0=date;
  162.         delay(5);
  163.         lcden=1;
  164.         delay(5);
  165.         lcden=0;
  166. }
  167. //***************************************密碼比較函數(shù)********************************
  168. bit mimacmp()
  169. {
  170.         bit flag;
  171.         uchar i;
  172.         for(i=0;i<8;i++)
  173.                 {
  174.                         if(mima[i]==tab_key[i])
  175.                                 flag=1;
  176.                         else
  177.                                 {
  178.                                 flag=0;
  179.                                 i=8;
  180.                                 }
  181.                 }
  182.         return(flag);                                                        //返回flag
  183. }
  184. ////**********************************LCD顯示函數(shù)開始**************************************
  185. void lcd_display()
  186. {
  187. uchar i=0;
  188. write_com(0x80+0x40+8);
  189. for(i=0;i<n;i++)
  190. {
  191. write_date(table3[0]);
  192. }
  193. }
  194. //****************************************鍵盤功能分配函數(shù)群開始****************************
  195. //** 0 ** 1 **2 ** 3**
  196. //** 4** 5** 6 **7 **
  197. //**8** 9** 確認(rèn)(A)  **無效(B)
  198. //**取消(C)**修改密碼鍵(D)**確認(rèn)修改鍵(E)**無效(F)
  199. void key_manage1()
  200. {
  201. tab_key[n]=0;
  202. n++;
  203. if(xiugaiflag==1)
  204. {
  205. mima[count4]=0;
  206. count4++;
  207. }
  208. }
  209. void key_manage2()
  210. {
  211. tab_key[n]=1;
  212. n++;
  213. if(xiugaiflag==1)
  214. {
  215. mima[count4]=1;
  216. count4++;
  217. }
  218. }
  219. void key_manage3()
  220. {
  221. tab_key[n]=2;
  222. n++;
  223. if(xiugaiflag==1)
  224. {
  225. mima[count4]=2;
  226. count4++;
  227. }
  228. }
  229. void key_manage4()
  230. {
  231. tab_key[n]=3;
  232. n++;
  233. if(xiugaiflag==1)
  234. {
  235. mima[count4]=3;
  236. count4++;
  237. }
  238. }
  239. void key_manage5()
  240. {
  241. tab_key[n]=4;
  242. n++;
  243. if(xiugaiflag==1)
  244. {
  245. mima[count4]=4;
  246. count4++;
  247. }
  248. }
  249. void key_manage6()
  250. {
  251. tab_key[n]=5;
  252. n++;
  253. if(xiugaiflag==1)
  254. {
  255. mima[count4]=5;
  256. count4++;
  257. }
  258. }
  259. void key_manage7()
  260. {
  261. tab_key[n]=6;
  262. n++;
  263. if(xiugaiflag==1)
  264. {
  265. mima[count4]=6;
  266. count4++;
  267. }
  268. }
  269. void key_manage8()
  270. {
  271. tab_key[n]=7;
  272. n++;
  273. if(xiugaiflag==1)
  274. {
  275. mima[count4]=7;
  276. count4++;
  277. }
  278. }
  279. void key_manage9()
  280. {
  281. tab_key[n]=8;
  282. n++;
  283. if(xiugaiflag==1)
  284. {
  285. mima[count4]=8;
  286. count4++;
  287. }
  288. }
  289. void key_manage10()
  290. {
  291. tab_key[n]=9;
  292. n++;
  293. if(xiugaiflag==1)
  294. {
  295. mima[count4]=9;
  296. count4++;
  297. }
  298. }
  299. //**********************************確認(rèn)鍵**************************************************************
  300. void key_manage11()
  301. {
  302.         enterflag=1;                                        //確認(rèn)鍵按下
  303.         if(n==8)                                           //只有輸入8個(gè)密碼后按確認(rèn)才做比較
  304.                 mimaflag=mimacmp();
  305.         else
  306.                 mimaflag=0;
  307.          if(enterflag==1)
  308.                 {
  309.                         enterflag=0;
  310.                         n=0;
  311.                         //用FFFFFFFF清除已經(jīng)輸入的密碼
  312.                         for(count3=0;count3<8;count3++)
  313.                         {
  314.                                 delay(5);
  315.                                 tab_key[count3]=0x0f;
  316.                         }
  317.
  318.                         TR1=1;        //打開計(jì)數(shù)器1
  319.                         count1=0;        //定時(shí)器1由50MS累計(jì)到1S所用的計(jì)數(shù)器
  320.                         if(mimaflag==1)
  321.                         {
  322.                                 a=0;
  323.
  324.                                 write_com(0x01);
  325.                                 write_com(0x80);
  326.                                 for(count3=0;count3<16;count3++)
  327.                                 {
  328.                                         write_date(table4[count3]);        //密碼正確,顯示RIGHT,綠燈亮
  329.                                         delay(5);
  330.                                 }
  331.                         }
  332.
  333.                     else
  334.                         {
  335.                                  n=0;
  336.                                  red=0;
  337.                             bell=0;
  338.                                 a++;
  339.                                 if(a==1)
  340.                                 {
  341.                                         for(count3=0;count3<8;count3++) //ffffffff清除密碼
  342.                                         {
  343.                                                 delay(5);
  344.                                                 tab_key[count3]=0x0f;
  345.                                         }
  346.                                         write_com(0x01);
  347.                                         write_com(0x80);
  348.                                         for(count3=0;count3<16;count3++)
  349.                                         {
  350.                                                 write_date(table5[count3]);        //密碼錯(cuò)誤,顯示 first error,紅燈亮
  351.                                                 delay(5);
  352.                                         }
  353.                                                 TR1=1;
  354.                                 }
  355.                                 if(a==2)
  356.                                 {
  357.                                         for(count3=0;count3<8;count3++) //ffffffff清除密碼
  358.                                         {
  359.                                                 delay(5);
  360.                                                 tab_key[count3]=0x0f;
  361.                                         }
  362.                                                 write_com(0x01);
  363.                                                 write_com(0x80);
  364.                                                 for(count3=0;count3<16;count3++)
  365.                                                 {
  366.                                                         write_date(table6[count3]);        //密碼錯(cuò)誤,顯示SECOND ERROR,紅燈亮
  367.                                                         delay(5);
  368.                                                 }
  369.                                                         TR1=1;
  370.                                 }
  371.
  372.                                   if(a==3)
  373.                                         {
  374.                                                 for(count3=0;count3<8;count3++) //ffffffff清除密碼
  375.                                                 {
  376.                                                         delay(5);
  377.                                                         tab_key[count3]=0x0f;
  378.                                                 }
  379.                                                 write_com(0x01);
  380.                                                 write_com(0x80);
  381.                                                 for(count3=0;count3<16;count3++)
  382.                                                 {
  383.                                                         write_date(table7[count3]);        //密碼錯(cuò)誤,顯示third error see,紅燈亮
  384.                                                         delay(5);
  385.                                                 }
  386.                                                 write_com(0x80+0x40);
  387.                                                 for(count3=0;count3<16;count3++)
  388.                                                 {
  389.                                                         write_date(table8[count3]);//密碼錯(cuò)誤,顯示 U TOMORROW ,紅燈亮
  390.                                                         delay(5);
  391.                                                 }
  392.                                                         TR1=0;
  393.
  394.                                         }
  395.
  396.                 }
  397.         }
  398. }
  399. void key_manage12()
  400. {
  401. tab_key[n]=11;
  402. n++;                                                  //密碼計(jì)數(shù)清零
  403. }
  404. //****************************************************取消鍵********************************************
  405. void key_manage13()
  406. {
  407. n=0;                                                  //密碼計(jì)數(shù)清零
  408. write_com(0x80);                                                //指針?biāo)肝恢?br />
  409. for(count3=0;count3<16;count3++)
  410. {
  411.         write_date(table1[count3]);                //第一行顯示INPUT THE PASSPORD:
  412.         delay(5);
  413. }
  414. write_com(0x80+0x40);
  415. for(count3=0;count3<16;count3++)
  416. {
  417.         write_date(table2[count3]);        //開機(jī)顯示--------
  418.         delay(5);
  419.         tab_key[count3]=0x0f;                        //用FFFFFFFF清楚已經(jīng)輸入的密碼
  420. }
  421. }
  422. //*******************************************修改密碼鍵**********************************
  423. void key_manage14()
  424. {
  425.         uchar aa=0;
  426.         n=0;
  427.         xiugaiflag=1;
  428.         write_com(0x01);
  429.         write_com(0x80);
  430. for(count3=0;count3<16;count3++)
  431. {
  432.         write_date(table9[count3]);        //顯示define the password
  433.         delay(5);
  434.         tab_key[count3]=0x0f;                        //用FFFFFFFF清楚已經(jīng)輸入的密碼
  435. }
  436.         write_com(0x80+0x40);
  437. for(count3=0;count3<16;count3++)
  438. {
  439.         write_date(table10[count3]);        //顯示--------
  440.         delay(5);
  441. }
  442. TR0=1;
  443. }
  444. //******************************************修改密碼鍵的確認(rèn)鍵********************************
  445. void key_manage15()
  446. {
  447. n=0;
  448. enter1flag=1;
  449. if(enter1flag==1)
  450. {
  451.         enter1flag=0;
  452.         count4=0;
  453.         for(count3=0;count3<16;count3++)
  454.         {
  455.         tab_key[count3]=0x0f;                        //用FFFFFFFF清楚已經(jīng)輸入的密碼
  456.          }
  457.         write_com(0x01);
  458.         write_com(0x80);
  459.         for(count3=0;count3<16;count3++)
  460.         {
  461.                 write_date(table11[count3]);
  462.                 delay(100);
  463.         }
  464.         TR1=1;
  465.         count1=0;
  466. }
  467. }
  468. void key_manage16()
  469. {
  470. tab_key[n]=15;
  471. n++;
  472. }
  473. //****************************************定時(shí)器1的50MS,共延時(shí)1秒*****************************
  474. void time_1() interrupt 3
  475. {
  476.         TH1=(65536-50000)/256;
  477.         TL1=(65536-50000)%256;
  478.         if(count1<20)
  479.         {
  480.                 count1++;
  481.         }
  482.         else                                                         //計(jì)時(shí)到1S
  483.         {
  484.                 TR1=0;
  485.                 count1=0;
  486.                 mimaflag=0;
  487.                 red=1;
  488.                 bell=1;
  489.                 //顯示FFFFFFFF
  490.                 write_com(0x01);
  491.                 write_com(0x80);
  492.                 for(count3=0;count3<16;count3++)
  493.                         {
  494.                                 write_date(table1[count3]);        //顯示INPUT THE PASSCODE
  495.                                 delay(5);
  496.                         }
  497.                 write_com(0x80+0x40);
  498.                 for(count3=0;count3<16;count3++)
  499.                         {
  500.                                 write_date(table2[count3]);        //開機(jī)顯示FFFFFFFF
  501.                                 delay(5);
  502.                         }
  503.         }
  504. }
  505. //***********************************************定時(shí)0**********************************************
  506. void time_0() interrupt 1
  507. {
  508.         TH0=(65536-50000)/256;
  509.         TL0=(65536-50000)%256;
  510. if(count4<8)
  511. {
  512.         key_scan();
  513. }
  514. else
  515. {
  516.         TR0=0;
  517.         count4=0;
  518. }
  519. }
  520. //初始化函數(shù)
  521. void init()
  522. {
  523.         uchar i;
  524.         lcden=0;
  525.         write_com(0x38);                                        //打開顯示模式設(shè)置
  526.         write_com(0x0c);                                        //打開顯示,光標(biāo)等等設(shè)置未零
  527.         write_com(0x06);                                        //當(dāng)讀或?qū)懸粋(gè)字符后地址指針加一,且光標(biāo)加一,當(dāng)寫一個(gè)字符后整頻顯示左移,
  528.         write_com(0x01);                                        //清零指令
  529.         write_com(0x80);                                        //指針?biāo)肝恢?br />
  530.         //定時(shí)器初始化
  531.         TMOD=0x11;                                                        //T0,T1工作方式1
  532.         TH0=(65536-2000)/256;
  533.         TL0=(65536-2000)%256;                                //T0初始化2MS
  534.         TH1=(65536-50000)/256;
  535.         TL1=(65536-50000)%256;                                //T1初始化50MS
  536.         TR1=0;
  537.         ET1=1;
  538.         EA=1;
  539.         TR0=0;
  540.         ET0=1;
  541.         count0=0;                                                        //初始沒有密碼輸入,故為零
  542.         enterflag=0;                                                //沒有確認(rèn)鍵按下
  543.         mimaflag=0;                                                        //密碼正確與否鍵先置零
  544.
  545.         red=1;        //紅燈不亮
  546. //************密碼存入EPROM中**********************************
  547.         sda=1;
  548.         delay(5);
  549.         scl=1;
  550.         delay(5);
  551.         for(i=0;i<8;i++)
  552.         {
  553.                 write_add(i,8);
  554.                 delay2(100);
  555.         }
  556.         for(i=0;i<8;i++)
  557.         {
  558.                 mima[i]=read_add(i);
  559.                 delay(5);
  560.         }
  561. }
  562. void main()
  563. {        rw=0;
  564.         init();
  565.         write_com(0x80);                                                //指針?biāo)肝恢?br />
  566.         for(count3=0;count3<16;count3++)
  567.         {
  568.                 write_date(table1[count3]);                //第一行顯示INPUT THE PASSPORD:
  569.                 delay(5);
  570.         }
  571.         write_com(0x80+0x40);
  572.         for(count3=0;count3<16;count3++)
  573.         {
  574.                 write_date(table2[count3]);                //開機(jī)顯示FFFFFFFF
  575.                 delay(5);
  576.         }
  577.         while(1)
  578.         {
  579.                 key_scan();                                                      //調(diào)用鍵盤掃描函數(shù)
  580.                 lcd_display();
  581.         }
  582.
  583. }
  584. //**************************************************鍵盤掃描函數(shù)開始********************************
  585. void key_scan()
  586. {
  587. //**********掃描第一行*********
  588. P1=0xfe;
  589. temp=P1;
  590. temp=temp&0xf0;
  591. if(temp!=0xf0)
  592. {
  593. delay(100);
  594. if(temp!=0xf0)
  595. {
  596. temp=P1;
  597. switch(temp)
  598. {
  599. case 0xee:
  600. key_manage1();
  601. break;
  602. case 0xde:
  603. key_manage2();
  604. break;
  605. case 0xbe:
  606. key_manage3();
  607. break;
  608. case 0x7e:
  609. key_manage4();
  610. break;
  611. }
  612. while(temp!=0xf0)
  613. {
  614. temp=P1;
  615. temp=temp&0xf0;
  616. }
  617. }
  618. }
  619. //**************************************************掃描第二行***********************************
  620. P1=0xfd;
  621. temp=P1;
  622. temp=temp&0xf0;
  623. if(temp!=0xf0)
  624. {
  625. delay(100);
  626. if(temp!=0xf0)
  627. {
  628. temp=P1;
  629. switch(temp)
  630. {
  631. case 0xed:
  632. key_manage5();
  633. break;
  634. case 0xdd:
  635. key_manage6();
  636. break;
  637. case 0xbd:
  638. key_manage7();
  639. break;
  640. case 0x7d:
  641. key_manage8();
  642. break;
  643. }
  644. while(temp!=0xf0)
  645. {
  646. temp=P1;
  647. temp=temp&0xf0;
  648. }
  649. }
  650. }
  651. //*********************************************掃描第三行***********************************
  652. P1=0xfb;
  653. temp=P1;
  654. temp=temp&0xf0;
  655. if(temp!=0xf0)
  656. {
  657. delay(100);
  658. if(temp!=0xf0)
  659. {
  660. temp=P1;
  661. switch(temp)
  662. {
  663. case 0xeb:
  664. key_manage9();
  665. break;
  666. case 0xdb:
  667. key_manage10();
  668. break;
  669. case 0xbb:
  670. key_manage11();
  671. break;
  672. case 0x7b:
  673. key_manage12();
  674. break;
  675. }
  676. while(temp!=0xf0)
  677. {
  678. temp=P1;
  679. temp=temp&0xf0;
  680. }
  681. }
  682. }
  683. //***************************************************掃描第四行****************************************
  684. P1=0xf7;
  685. temp=P1;
  686. temp=temp&0xf0;
  687. if(temp!=0xf0)
  688. {
  689. delay(100);
  690. if(temp!=0xf0)
  691. {
  692. temp=P1;
  693. switch(temp)
  694. {
  695. case 0xe7:
  696. key_manage13();
  697. break;
  698. case 0xd7:
  699. key_manage14();
  700. break;
  701. case 0xb7:
  702. key_manage15();
  703. break;
  704. case 0x77:
  705. key_manage16();
  706. break;
  707. }
  708. while(temp!=0xf0)
  709. {
  710. temp=P1;
  711. temp=temp&0xf0;
  712. }
  713. }
  714. }
  715. }
電子密碼鎖.zip
197.29 KB, 下載次數(shù): 169, 下載積分: 黑幣 -5
收藏收藏8 分享淘帖 頂 踩
ID:745179 發(fā)表于 2020-5-10 17:23 | 只看該作者
仿真必須要用Proteus7.5打開
ID:761492 發(fā)表于 2020-6-7 16:11 | 只看該作者
代碼打不開,搞不懂
ID:783929 發(fā)表于 2020-6-19 12:30 | 只看該作者
可以的鐵子,很強(qiáng)
ID:741474 發(fā)表于 2020-7-1 22:04 來自觸屏版 | 只看該作者
study1344684670 發(fā)表于 2020-6-7 16:11
代碼打不開,搞不懂
我是仿真打不開,閃退。
ID:741474 發(fā)表于 2020-7-1 22:06 來自觸屏版 | 只看該作者
代碼打不開,搞不懂
代碼打開只有個(gè)頭文件,奇怪
ID:568565 發(fā)表于 2020-12-18 08:37 | 只看該作者
不會吧,我能打開呀
ID:865733 發(fā)表于 2020-12-22 18:54 | 只看該作者
這個(gè)程序很棒
ID:568565 發(fā)表于 2021-1-10 14:12 | 只看該作者
AA11 發(fā)表于 2020-5-10 17:23
能請問一下,為什么下載不下來呢?
不會吧,我可以打開的
ID:950314 發(fā)表于 2021-7-8 22:09 | 只看該作者
初始密碼不應(yīng)該是8位嗎?清除鍵在哪里啊
ID:1019140 發(fā)表于 2022-4-17 15:53 | 只看該作者
找了好久,就感覺這個(gè)很好,很完美。
ID:100749 發(fā)表于 2022-4-25 11:18 | 只看該作者
.c文件在1602+24C08+4X4鍵盤密碼鎖 目錄
仿真必須要用Proteus7.5打開
ID:825397 發(fā)表于 2022-6-3 10:01 | 只看該作者
仿真圖IO接線與程序聲明不一致,是不是搞混了。程序里明明要對比8位密碼,初始密碼確告知是123456,對應(yīng)不上。
ID:63541 發(fā)表于 2022-6-29 17:24 | 只看該作者
初始密碼在Keil C\用1602LCD+24C04設(shè)計(jì)的電子密碼鎖.hex才能打開。
主站蜘蛛池模板: 久久一区二区视频 | 日韩新片王网 | 日韩欧美三区 | 亚洲毛片视频 | 国产精品av在线 | 精品视频免费观看 | 久草视频免费看 | 日韩中文在线观看 | 国产精品毛片久久久久久久 | 美国特色黄a大片 | 国产美女自拍视频 | 手机av片| 综合久久久| 免费成人黄色 | 国产精品区二区三区日本 | 国产欧美激情 | 亚洲性av| 成人免费毛片嘿嘿连载视频 | 99福利| 另类专区亚洲 | 久久国产精 | 欧美日韩亚洲视频 | 99热免费 | 天天操天 | 深夜福利av | 欧美91 | 久久只有精品 | 色婷婷综合网 | 久久精品黄色 | 久久av一区二区 | 日本在线看 | 久久久精品一区 | 天天爽夜夜爽夜夜爽 | 国产精品二 | 亚洲成人三级 | 国产成人a亚洲精品 | 欧美三级 欧美一级 | 黄网站免费观看 | 国产精品久久网 | av免费网站 | 青青草国产成人av片免费 |
