查看: 4603|回復: 2
基于51單片機的XY軸激光打印機電路原理圖+程序
ID:301780 發表于 2020-4-20 13:51 | 顯示全部樓層 |閱讀模式
基于51單片機的XY軸激光打印機電路原理圖,內含51單片機原理圖相關的庫文件,以及該打印機的測試代碼。
原理圖
原理圖
  1. #include<reg52.h>
  2. #include<math.h>
  3. #include<data.h>
  4. #include<delay.h>
  5. #include<delayms.h>
  6. #define        work_pl 2000        //計時器初值
  7. #define dl 71.5   //脈沖當量
  8. #define wid 10.0   //數字字寬
  9. #define wid_1 130.0   //漢字字寬
  10. #define rad 15          //所打印圓半徑
  11. #define len 33     //所打印圓的圓心基點
  12. #define high 1.73205  //根號3對應常數
  13. #define on   0                 //激光開關
  14. #define off  1
  15. sbit x_move=P2^4;
  16. sbit x_direct=P2^5;
  17. sbit y_move=P2^2;
  18. sbit y_direct=P2^3;
  19. sbit light=P2^0;    //激光開關
  20. sbit turnlight=P2^1;  //打印開始或結束
  21. sbit x_stp=P1^1;        //限位開關
  22. sbit y_stp=P1^0;
  23. sbit start=P1^3;        //啟動開關
  24. sbit contin=P1^4;  //暫停
  25. // 脈沖發生器
  26. void time0make(unsigned char a,unsigned char b)
  27. {
  28. TMOD=0x01;
  29. TH0=(65536-work_pl)/256;
  30. TL0=(65536-work_pl)%256;
  31. EA=1;
  32. TR0=1;
  33. while(1)
  34. {
  35.    if(TF0)
  36.    {
  37.          TF0=0;
  38.          if(a==0)
  39.          {
  40.           x_direct=b;
  41.           x_move=!x_move;
  42.           TH0=(65536-work_pl)/256;
  43.       TL0=(65536-work_pl)%256;
  44.           while(!TF0);
  45.           x_move=!x_move;
  46.           TF0=0;
  47.           return;
  48.          }
  49.         else
  50.          {
  51.           y_direct=b;
  52.           y_move=!y_move;
  53.           TH0=(65536-work_pl)/256;
  54.       TL0=(65536-work_pl)%256;
  55.           while(!TF0);
  56.           y_move=!y_move;
  57.           TF0=0;
  58.           return;
  59.          }
  60.          TH0=(65536-work_pl)/256;
  61.      TL0=(65536-work_pl)%256;
  62.          while(!TF0)
  63.          TF0=0;
  64.          return;
  65.    }
  66. }
  67. }
  68. //直線插補
  69. void math_zhixian(float x_e,float y_e)
  70. {
  71.   float f0,x0,y0,sum;
  72.   unsigned char a,b;
  73.   if(x_e>=0&&y_e>=0)  //相對坐標象限判斷
  74.          {a=1;b=1;}
  75.          else if(x_e<=0&&y_e>=0)
  76.          {a=0;b=1;}
  77.            else if(x_e<=0&&y_e<=0)
  78.             {a=0,b=0;}
  79.                   else
  80.                   {a=1,b=0;};
  81.   x0=fabs(dl*x_e);
  82.   y0=fabs(dl*y_e);
  83.   f0=0;
  84.   sum=x0+y0;
  85.   while(sum>=0)
  86.   {
  87.   if(f0>=0)
  88.    {
  89.    time0make(0,a);
  90.    f0=f0-y0;
  91.    sum=sum-1;
  92.    }
  93.   else
  94.    {
  95.    time0make(1,b);
  96.    f0=f0+x0;
  97.    sum=sum-1;
  98.    }
  99.   }
  100. }
  101. //第一象限逆圓弧插補
  102. void math_yuanhu(float x0,float y0,float x1,float y1)
  103. {
  104. float f0,sum,temp;
  105. f0=0;
  106. x0=dl*x0;
  107. y0=dl*y0;
  108. x1=dl*x1;
  109. y1=dl*y1;
  110. sum=x0+y1;
  111. temp=sum;
  112. while(sum>0)         //第一象限
  113. {
  114.    if(f0>=0)
  115.    {
  116.    time0make(0,0);
  117.    f0=f0-2*x0+1;
  118.    x0=x0-1;
  119.    sum=sum-1;
  120.    }
  121.    else
  122.    {
  123.         time0make(1,1);
  124.         f0=f0+2*y0+1;
  125.         y0=y0+1;
  126.         sum=sum-1;
  127.    }
  128. }
  129. sum=temp;
  130. f0=0;
  131. while(sum>0)          //第二象限
  132. {
  133.   if(f0>=0)
  134.    {
  135.     time0make(1,0);
  136.         f0=f0-2*y0+1;
  137.         y0=y0-1;
  138.         sum=sum-1;
  139.    }
  140.   else
  141.   {
  142.    time0make(0,0);
  143.    f0=f0-2*x0+1;
  144.    x0=x0-1;
  145.    sum=sum-1;
  146.   }
  147. }
  148. sum=temp;
  149. f0=0;
  150. while(sum>0)  //第三象限
  151. {
  152.   if(f0>=0)
  153.    {
  154.     time0make(0,1);
  155.         f0=f0+2*x0+1;
  156.         x0=x0+1;
  157.         sum=sum-1;
  158.    }
  159.   else
  160.   {
  161.            time0make(1,0);
  162.         f0=f0-2*y0+1;
  163.         y0=y0-1;
  164.         sum=sum-1;
  165.   }
  166. }
  167. sum=temp;
  168. f0=0;
  169. while(sum>0)  //第四象限
  170. {
  171.   if(f0>=0)
  172.    {
  173.     time0make(1,1);
  174.         f0=f0+2*y0+1;
  175.         y0=y0+1;
  176.         sum=sum-1;
  177.    }
  178.   else
  179.   {
  180.     time0make(0,1);
  181.         f0=f0+2*x0+1;
  182.         x0=x0+1;
  183.         sum=sum-1;
  184.   }
  185. }
  186. }
  187. //回到初始點
  188. void init0()
  189. {
  190.   delay();
  191.   while(1)
  192.   {
  193.     time0make(0,0);
  194.         if(x_stp==0)
  195.         {
  196.           if(x_stp==0)
  197.           break;
  198.         }
  199.   }
  200.   while(1)
  201.   {
  202.    time0make(1,0);
  203.    if(y_stp==0)
  204.         {
  205.           if(y_stp==0)
  206.           break;
  207.         }
  208.    }
  209. }
  210. void main()                  //主函數
  211. {
  212. char p,m,order;
  213. int k;
  214. float i,j,length;
  215. EA=1;
  216. IT0=1;     //脈沖觸發外部中斷控制
  217. // start=1;
  218. // while(start)
  219. // {
  220. //        delay();
  221. //        if(start==0)
  222. //        break;
  223. // }
  224. light=off;
  225. delayms();
  226. turnlight=off;
  227. init0();     //歸零
  228. i=len+rad;
  229. math_zhixian(i,len+40);  //預留打印數字和漢字的高度
  230. light=on;              //打印圓
  231. delay();
  232. turnlight=on;
  233. math_yuanhu(rad,0,0,rad);
  234. light=off;
  235. delay();
  236. turnlight=off;
  237. length=rad*2*high;
  238. i=0-(rad+length/2);
  239. j=0-rad;
  240. math_zhixian(i,j);
  241. i=length/2;           //打印等邊三角形
  242. j=length*high/2;
  243. light=on;
  244. delay();
  245. turnlight=on;
  246. math_zhixian(i,j);
  247. i=length/2;
  248. j=0-length*high/2;
  249. math_zhixian(i,j);
  250. i=0-length;
  251. j=0;
  252. math_zhixian(i,j);
  253. light=off;
  254. delay();
  255. turnlight=off;
  256. i=0-20;
  257. j=0-10;
  258. math_zhixian(i,j);
  259. for(m=0;m<12;m++)
  260. {
  261.   order=xuehao[m];
  262.    if(order==6)
  263.    {
  264.     k=0;
  265.     for(;;)  //打印數字   6
  266.       {
  267.
  268.            p=num6[k];
  269.            if(p==0)
  270.            break;
  271.            k++;
  272.            i=num6[k];
  273.            i=(2/wid)*i;
  274.            k++;
  275.            j=num6[k];
  276.            j=0-(2/wid)*j;          //Y取反
  277.            k++;
  278.            if(p==1)
  279.            {light=on;
  280.                    delay();
  281.            turnlight=on;}
  282.            else if(p==2)
  283.            {light=off;
  284.                    delay();
  285.            turnlight=off;}
  286.            math_zhixian(i,j);
  287.        }
  288.         }
  289.         else if(order==4)
  290.    {
  291.     k=0;
  292.     for(;;)  //打印數字  4
  293.       {
  294.
  295.            p=num4[k];
  296.            if(p==0)
  297.            break;
  298.            k++;
  299.            i=num4[k];
  300.            i=(2/wid)*i;
  301.            k++;
  302.            j=num4[k];
  303.            j=0-(2/wid)*j;
  304.            k++;
  305.            if(p==1)
  306.            {light=on;
  307.                    delay();
  308.            turnlight=on;}
  309.            else if(p==2)
  310.            {light=off;
  311.                    delay();
  312.            turnlight=off;}
  313.            math_zhixian(i,j);
  314.        }
  315.         }
  316.         else if(order==3)
  317.    {
  318.     k=0;
  319.     for(;;)  //打印數字  3
  320.       {
  321.
  322.            p=num3[k];
  323.            if(p==0)
  324.            break;
  325.            k++;
  326.            i=num3[k];
  327.            i=(2/wid)*i;
  328.            k++;
  329.            j=num3[k];
  330.            j=0-(2/wid)*j;
  331.            k++;
  332.            if(p==1)
  333.            {light=on;
  334.                    delay();
  335.            turnlight=on;}
  336.            else if(p==2)
  337.            {light=off;
  338.                    delay();
  339.            turnlight=off;}
  340.            math_zhixian(i,j);
  341.        }
  342.         }
  343.         else if(order==2)
  344.    {
  345.      k=0;
  346.      for(;;)  //打印數字2
  347.       {
  348.
  349.            p=num2[k];
  350.            if(p==0)
  351.            break;
  352.            k++;
  353.            i=num2[k];
  354.            i=(2/wid)*i;
  355.            k++;
  356.            j=num2[k];
  357.            j=0-(2/wid)*j;
  358.            k++;
  359.            if(p==1)
  360.            {light=on;
  361.                    delay();
  362.            turnlight=on;}
  363.            else if(p==2)
  364.            {light=off;
  365.                    delay();
  366.            turnlight=off;}
  367.            math_zhixian(i,j);
  368.        }
  369.         }
  370.         else if(order==1)
  371.    {
  372.       k=0;
  373.       for(;;)  //打印數字 1
  374.       {
  375.
  376.            p=num1[k];
  377.            if(p==0)
  378.            break;
  379.            k++;
  380.            i=num1[k];
  381.            i=(2/wid)*i;
  382.            k++;
  383.            j=num1[k];
  384.            j=0-(2/wid)*j;
  385.            k++;
  386.            if(p==1)
  387.            {light=on;
  388.                    delay();
  389.            turnlight=on;}
  390.            else if(p==2)
  391.            {light=off;
  392.                    delay();
  393.            turnlight=off;}
  394.            math_zhixian(i,j);
  395.        }
  396.         }
  397.         else if(order==0)
  398.    {
  399.     k=0;
  400.     for(;;)  //打印數字 0
  401.       {
  402.
  403.            p=num0[k];
  404.            if(p==0)
  405.            break;
  406.            k++;
  407.            i=num0[k];
  408.            i=(2/wid)*i;
  409.            k++;
  410.            j=num0[k];
  411.            j=0-(2/wid)*j;
  412.            k++;
  413.            if(p==1)
  414.            {light=on;
  415.                    delay();
  416.            turnlight=on;}
  417.            else if(p==2)
  418.            {light=off;
  419.                    delay();
  420.            turnlight=off;}
  421.            math_zhixian(i,j);
  422.        }
  423.         }
  424.         else
  425.         continue;
  426. }
  427.          light=off;
  428.          delay();
  429.      turnlight=off;
  430.          i=0-5*12;  //移動到打印字的起點且與數字同一個邊開始
  431.          j=0-20;
  432.          math_zhixian(i,j);
  433.          k=0;
  434.      for(;;)                //打印姓名首字
  435.       {
  436.
  437.            p=cai[k];
  438.            if(p==0)
  439.            break;
  440.            k++;
  441.            i=cai[k];
  442.            i=(15/wid_1)*i;
  443.            k++;
  444.            j=cai[k];
  445.            j=0-(15/wid_1)*j;
  446.            k++;
  447.            if(p==1)
  448.            {light=on;
  449.                    delay();
  450.            turnlight=on;}
  451.            else if(p==2)
  452.            {light=off;
  453.                    delay();
  454.            turnlight=off;}
  455.            math_zhixian(i,j);
  456.        }
  457.          k=0;
  458.          for(;;)                //打印姓名第二字
  459.       {
  460.
  461.            p=ying[k];
  462.            if(p==0)
  463.            break;
  464.            k++;
  465.            i=ying[k];
  466.            i=(15/wid_1)*i;
  467.            k++;
  468.            j=ying[k];
  469.            j=0-(15/wid_1)*j;
  470.            k++;
  471.            if(p==1)
  472.            {light=on;
  473.                    delay();
  474.            turnlight=on;}
  475.            else if(p==2)
  476.            {light=off;
  477.                    delay();
  478.            turnlight=off;}
  479.            math_zhixian(i,j);
  480.        }
  481.          k=0;
  482.      for(;;)                //打印姓名第三字
  483.       {
  484.
  485.            p=tao[k];
  486.            if(p==0)
  487.            break;
  488.            k++;
  489.            i=tao[k];
  490.            i=(15/wid_1)*i;
  491.            k++;
  492.            j=tao[k];
  493.            j=0-(15/wid_1)*j;
  494.            k++;
  495.            if(p==1)
  496.            {light=on;
  497.                    delay();
  498.            turnlight=on;}
  499.            else if(p==2)
  500.            {light=off;
  501.                    delay();
  502.            turnlight=off;}
  503.            math_zhixian(i,j);
  504.        }
  505. while(1);
  506. }
  507. void stop() interrupt 0
  508. {
  509.   char x;
  510.   x=1;
  511.   delay();
  512.   while(x)
  513.   {
  514.   if(contin==0)
  515.   {
  516.    delay();
  517.    if(contin==0)
  518.    break;
  519.   }
  520.   }
  521. }
test.7z (57.72 KB, 下載次數: 69)
ID:685250 發表于 2023-7-11 15:16 | 顯示全部樓層
沒幣沒幣沒幣沒幣沒幣沒幣沒幣沒幣沒幣沒幣沒幣沒幣沒幣沒幣沒幣沒幣沒幣
ID:72224 發表于 2023-11-14 11:49 | 顯示全部樓層
有上位機嗎?
主站蜘蛛池模板: 亚洲国产精品久久久 | 成人免费在线观看 | 精品久久久久久久久久久久久久久久 | 免费一级a毛片 | 久久免费精品 | 国产精品毛片一区二区在线看 | 久久成人免费视频 | 成人小视频在线观看 | 欧美在线视频一区二区 | 国产福利一区二区三区 | 国产午夜精品久久久久久久 | 大乳女喂男人吃奶 | 97视频在线观看免费 | 国产精品欧美在线 | 精品久久久久久久久久久久久久 | www国产精品 | 在线视频福利 | www午夜 | 色综合天天综合网国产成人网 | 窝窝午夜精品一区二区 | 好吊视频一区二区三区 | 国产小视频在线观看 | 干少妇视频 | 久久精品在线播放 | 黄色a级网站 | 日韩视频免费看 | 欧美视频a | 亚洲激情视频在线 | 国产精品视频专区 | 亚洲69视频 | 福利视频网站 | 性欧美69| 久久久噜噜噜 | 午夜视频在线 | 成人av一区 | 亚洲精品播放 | 久久精品视频网站 | 久久天天躁狠狠躁夜夜躁2014 | 99久久精品一区二区成人 | 成人在线国产 | 午夜精品福利视频 |
