查看: 4545|回復: 10
關于STM32驅動LCD1602引腳不連續的問題
ID:428871 發表于 2020-4-26 16:26 | 顯示全部樓層 |閱讀模式
設計電路圖時,將LCD1602的D0-D3接在了PC8-PC11,將D4-D7接在了PB4-PB7上,要怎么樣驅動LCD呢?麻煩各位大佬給點指點,我初學STM32,最好是給點程序。
ID:328014 發表于 2020-4-26 21:10 | 顯示全部樓層
了解一下C語言位域(位段)概念,可以解決這個問題
ID:726709 發表于 2020-4-26 21:40 | 顯示全部樓層
#include "bsp-lcd1602.h"
void LCD1602_GPIO_Config(void)
RCC_APB2PeriphClockCmd(LCD1602_CLK, ENABLE);
GPIO_InitTypeDef LCD1602_GPIOStruct;
LCD1602_GPIOStruct.GPIO_Mode = GPIO_Mode_Out_PP;
LCD1602_GPIOStruct.GPIO_Speed = GPIO_Speed_10MHz;
LCD1602_GPIOStruct.GPIO_Pin =  LCD1602_E | LCD1602_RS | LCD1602_RW ;
GPIO_Init(LCD1602_GPIO_PORT,&LCD1602_GPIOStruct);
LCD1602_GPIOStruct.GPIO_Mode = GPIO_Mode_Out_OD;
LCD1602_GPIOStruct.GPIO_Pin =   DB0 |  DB1 | DB2 |DB3 |  DB4 | DB5|
                 DB6 |  DB7 ;     //設置為開漏輸出
void LCD1602_WaitReady(void) //檢測忙狀態
uint8_t sta;
GPIOB->ODR =0x00FF;
RSO(0);
RWO(1);
EO(1);
SysTick_Delay_Us(1);
do{
  sta=GPIO_ReadInputDataBit(LCD1602_GPIO_PORT,GPIO_Pin_7);
  EO(0);
}while(sta);
void LCD1602_WriteCmd(uint8_t cmd) //寫指令
LCD1602_WaitReady();
RSO(0);
RWO(0);
EO(0);
EO(1);
LCD1602_GPIO_PORT->ODR &= (cmd|0xFF00);
EO(0);
SysTick_Delay_Us(400);
void LCD1602_WriteDat(uint8_t dat) //寫數據
RSO(1);
RWO(0);
SysTick_Delay_Us(30);
EO(1);
LCD1602_GPIO_PORT->ODR &=(dat|0xFF00);
EO(0);
void LCD1602_SetCursor(uint8_t x, uint8_t y)
    uint8_t addr;
    if (y == 0)  //由輸入的屏幕坐標計算顯示RAM的地址
        addr = 0x00 + x;  //第一行字符地址從0x00起始
        addr = 0x40 + x;  //第二行字符地址從0x40起始
    LCD1602_WriteCmd(addr|0x80);  //設置RAM地址
void LCD1602_ShowStr(uint8_t x, uint8_t y, uint8_t *str, uint8_t len)
    LCD1602_SetCursor(x, y); //設置起始地址
    while (len--)         //連續寫入len個字符數據
        LCD1602_WriteDat(*str++);
void LCD1602_Init(void)
   LCD1602_GPIO_Config();   //開啟GPIO口
    LCD1602_WriteCmd(0X38);  //16*2顯示,5*7點陣,8位數據接口
    LCD1602_WriteCmd(0x0C);  //顯示器開,光標關閉
    LCD1602_WriteCmd(0x06);  //文字不動,地址自動+1
    LCD1602_WriteCmd(0x01);  //清屏
#ifndef _BSP_LCD1602_H
#define _BSP_LCD1602_H
#include "stm32f10x.h"
#include "stm32f10x_gpio.h"
#include "bsp_SysTick.h"
#define LCD1602_CLK  RCC_APB2Periph_GPIOB
#define LCD1602_GPIO_PORT   GPIOB
#define LCD1602_E    GPIO_Pin_10              //定義使能引腳
#define LCD1602_RW   GPIO_Pin_11             //定義讀寫引腳
#define LCD1602_RS   GPIO_Pin_12             //定義數據、命名引腳
#define EO(X)         X? (GPIO_SetBits(LCD1602_GPIO_PORT,LCD1602_E)):(GPIO_ResetBits(LCD1602_GPIO_PORT,LCD1602_E))
#define RWO(X)        X? (GPIO_SetBits(LCD1602_GPIO_PORT,LCD1602_RW)):(GPIO_ResetBits(LCD1602_GPIO_PORT,LCD1602_RW))
#define RSO(X)        X? (GPIO_SetBits(LCD1602_GPIO_PORT,LCD1602_RS)):(GPIO_ResetBits(LCD1602_GPIO_PORT,LCD1602_RS))
//只能是某個GPIO口的低八位
#define DB0     GPIO_Pin_0
#define DB1     GPIO_Pin_1
#define DB2     GPIO_Pin_2
#define DB3     GPIO_Pin_3
#define DB4     GPIO_Pin_4
#define DB5     GPIO_Pin_5
#define DB6     GPIO_Pin_6
#define DB7     GPIO_Pin_7
void LCD1602_Init(void);  //初始化LCD602;
void LCD1602_ShowStr(uint8_t x, uint8_t y, uint8_t *str,uint8_t len);
#endif //_BSP_LCD1602_H
這是.c和.h文件對應I/O口改一下就可以了
ID:282850 發表于 2020-4-27 00:30 | 顯示全部樓層
非要用并口嗎?1602極小的數據量,串口輕松搞定。1602本身就不是好的顯示。12864或乾12832比1602好的多。我的1602試驗完就丟一邊了。
樓上說的正解,就是取前4、后4位,再相或的方法。
ID:732506 發表于 2020-4-27 03:18 | 顯示全部樓層
可以4位寫入,只用D4-D7就可以了。
ID:328014 發表于 2020-4-27 14:56 | 顯示全部樓層
ID:739441 發表于 2020-4-27 16:43 | 顯示全部樓層
段位操作,可以找個例程參考一下,直接用人家的代碼先驅動起來再說,先亮起來再說,然后再看代碼
ID:446064 發表于 2020-5-5 16:51 | 顯示全部樓層
JFSN 發表于 2020-4-26 21:40
為什么我按照你的改了之后亂碼顯示
ID:152816 發表于 2022-12-10 16:22 | 顯示全部樓層
你這個是連續引腳,別人問的是不連續引腳
ID:53813 發表于 2024-12-19 08:52 | 顯示全部樓層
翻老帖,網上這類解答真少,好不容易找打一個,沒明確答案~
ID:517951 發表于 2024-12-23 08:01 | 顯示全部樓層
單片機可以用iicPCF8547T芯片驅動1602, 可以節省IO端口, 詳見  http://m.zg4o1577.cn/bbs/dpj-177486-1.html
主站蜘蛛池模板: 青草视频在线播放 | 91精品国产综合久久久久久 | 国产一区在线播放 | 免费av观看 | 香蕉视频在线免费看 | 成人在线视频免费观看 | 欧美理论片在线观看 | 国产成人在线免费观看 | 免费网站黄 | 亚欧av在线 | 国产精品久久久一区二区三区 | 欧美日韩在线一区二区 | 中文字幕综合 | 黄色小说视频网站 | 国产一区二区三区在线 | 91久久国产综合久久91精品网站 | 欧洲色综合 | 亚洲h网站| 中国农村毛片免费播放 | 亚洲天堂第一页 | 少妇一级淫片免费放 | 深夜福利视频在线观看 | 午夜拍拍 | 久久中文视频 | 18岁毛片| 亚洲第一黄色 | a级黄色片| 草草福利影院 | 一区二区三区视频在线播放 | 天天摸天天爽 | 久久久久久久影院 | 日韩欧美在线播放 | 四虎影院免费观看 | 手机看片国产 | 亚洲综合区 | 国产一区二区三区免费 | 日本a级大片 | 国产精品福利一区 | 欧洲美一区二区三区亚洲 | 福利视频网站 | 亚洲日本视频 |
