今天剛做出的計數(shù)器,資料很全面,各位可以用來參考
程序如下:
#include<reg51.h>
#define uchar unsigned char
#define uint unsigned int
uchar code DSY_CODE[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
//計數(shù)值分解后的各待顯示數(shù)位
uchar Display_Buffer[3]={0,0,0};
uint Count = 0;
sbit Clear_Key = P3^6;
//在數(shù)碼管上顯示計數(shù)值
void Show_Count_ON_DSY()
Display_Buffer[1] = Count % 100/10;
Display_Buffer[0] = Count %10;
if(Display_Buffer[1] == 0) //高位為0時不顯示
Display_Buffer[2] = 0x0a;
//高位為0時,如果第二位為0則同樣不顯示
if(Display_Buffer[1] == 0 ) Display_Buffer[1] = 0x0a;
P1=DSY_CODE[Display_Buffer[0] ];
P2=DSY_CODE[Display_Buffer[1] ];
P0=0xff;
P1=0xff;
P2=0xff;
IE=0x81;
IT0=1;
if(Clear_Key==0)
Count = 0;
Show_Count_ON_DSY();
//INTO中斷函數(shù)
void EX_INT0() interrupt 0
Count++;
0-99計數(shù)器設計仿真+源碼.rar
(50.88 KB, 下載次數(shù): 26)
2020-4-30 14:14 上傳
點擊文件名下載附件
