查看: 3156|回復: 0
MikroC寫的ATmega16驅動spi接口128x64屏例子帶仿真
MikroC寫的ATmega16驅動spi接口128x64屏例子帶仿真。自帶驅動庫,圖片轉換成數組的工具也集成在軟件內,可到官網下載無須注冊。
  1. const code char truck_bmp[1024];
  2. const code char B_bmp[1024];
  3. // Port Expander module connections
  4. sbit  SPExpanderRST at PORTB0_bit;
  5. sbit  SPExpanderCS  at PORTB1_bit;
  6. sbit  SPExpanderRST_Direction at DDB0_bit;
  7. sbit  SPExpanderCS_Direction  at DDB1_bit;
  8. // End Port Expander module connections
  9. void Delay2s(){                         // 2 seconds delay function
  10.   Delay_ms(2000);
  11. }
  12. void main() {
  13.   char counter;
  14.   char *someText;
  15.   // If Port Expander Library uses SPI1 module
  16.   SPI1_Init_Advanced(_SPI_MASTER, _SPI_FCY_DIV2, _SPI_CLK_HI_TRAILING);  // Initialize SPI module used with PortExpander
  17.   // // If Port Expander Library uses SPI2 module
  18.   //  SPI2_Init_Advanced(_SPI_MASTER, _SPI_FCY_DIV2, _SPI_CLK_HI_TRAILING);  // Initialize SPI module used with PortExpander
  19.   SPI_Glcd_Init(0);                              // Initialize Glcd via SPI
  20.   SPI_Glcd_Fill(0x00);                           // Clear Glcd
  21.   while(1) {
  22.     SPI_Glcd_Image(truck_bmp);                   // Draw image
  23.     Delay2s(); Delay2s();
  24.     SPI_Glcd_fill(0x00);                                  // Clear GLCD
  25.     //SPI_Glcd_PartialImage(0,0,68,30,128,64,truck_bmp);    // Partial image
  26.     //Delay_ms(500);
  27.     //SPI_Glcd_PartialImage(24,16,68,30,128,64,truck_bmp);
  28.     //Delay_ms(500);
  29.     //SPI_Glcd_PartialImage(56,34,68,30,128,64,truck_bmp);
  30.     //Delay2s(); Delay2s();
  31.     //SPI_Glcd_Fill(0x00);                             // Clear GLCD
  32.
  33.     SPI_Glcd_Box(62,40,124,56,1);                    // Draw box
  34.     SPI_Glcd_Rectangle(5,5,84,35,1);                 // Draw rectangle
  35.     Delay_ms(1000);
  36.     SPI_Glcd_Rectangle_Round_Edges(2,2,87,38,7,1);
  37.     Delay_ms(1000);
  38.     SPI_Glcd_Rectangle_Round_Edges_Fill(8,8,81,32,12,1);
  39.     Delay_ms(1000);
  40.     SPI_Glcd_Line(0, 0, 127, 63, 1);                 // Draw line
  41.     Delay2s();
  42.     SPI_Glcd_Image(B_bmp);
  43.     Delay2s();
  44.
  45.     for(counter = 5; counter < 60; counter+=5 ) {  // Draw horizontal and vertical lines
  46.       Delay_ms(250);
  47.       SPI_Glcd_V_Line(2, 54, counter, 1);
  48.       SPI_Glcd_H_Line(2, 120, counter, 1);
  49.       }
  50.     Delay2s();
  51.     SPI_Glcd_Fill(0x00);                         // Clear Glcd
  52.     SPI_Glcd_Set_Font(Character8x7, 8, 7, 32);   // Choose font, see __Lib_GLCDFonts.c in Uses folder
  53.     SPI_Glcd_Write_Text("mikroE", 5, 7, 2);      // Write string
  54.     for (counter = 1; counter <= 10; counter++)  // Draw circles
  55.       SPI_Glcd_Circle(63,32, 3*counter, 1);
  56.     Delay2s();
  57.     SPI_Glcd_Circle_Fill(63,32, 30, 1);          // Draw circles
  58.     Delay2S();
  59.     SPI_Glcd_Box(12,20, 70,63, 2);               // Draw box
  60.     Delay2s();
  61.     SPI_Glcd_Fill(0xFF);                         // Fill Glcd
  62.     SPI_Glcd_Set_Font(Character8x7, 8, 7, 32);   // Change font
  63.     someText = "8x7 Font";
  64.     SPI_Glcd_Write_Text(someText, 5, 0, 2);      // Write string
  65.     Delay2s();
  66.     SPI_Glcd_Set_Font(System3x5, 3, 5, 32);      // Change font
  67.     someText = "3X5 CAPITALS ONLY";
  68.     SPI_Glcd_Write_Text(someText, 60, 2, 2);     // Write string
  69.     Delay2s();
  70.     SPI_Glcd_Set_Font(font5x7, 5, 7, 32);        // Change font
  71.     someText = "5x7 Font";
  72.     SPI_Glcd_Write_Text(someText, 5, 4, 2);      // Write string
  73.     Delay2s();
  74.     SPI_Glcd_Set_Font(FontSystem5x7_v2, 5, 7, 32); // Change font
  75.     someText = "5x7 Font (v2)";
  76.     SPI_Glcd_Write_Text(someText, 5, 6, 2);        // Write string
  77.     Delay2s();
  78.     }
  79. }
ATMEGA16 SPI128x64.zip (29.35 KB, 下載次數: 15)
主站蜘蛛池模板: 久插视频| 国产成人精品一区二区三区在线观看 | 一道本在线 | 精品免费在线 | 欧美激情第二页 | 一级片在线播放 | 欧美黑人一区二区三区 | 色噜噜狠狠一区二区三区 | 五月婷婷综合网 | 国产裸体永久免费视频网站 | 亚洲第一黄网 | 久久久久亚洲精品 | 日本一级大毛片a一 | 亚洲国产日韩在线 | 亚洲激情视频在线 | 午夜国产视频 | 日韩一区在线视频 | 啪啪综合网 | 久久99免费视频 | 婷婷在线播放 | 欧美视频免费看 | 国产精品一区视频 | 欧美日韩在线免费观看 | 亚洲精品一区二区三区蜜桃久 | 国产日韩精品在线 | 91久久精品视频 | 成年人免费在线视频 | 伊人成人在线 | 嫩草嫩草嫩草嫩草 | 欧美大片18 | 国产成人精品久久久 | 成人特级毛片 | 日本一级淫片色费放 | 又色又爽又黄gif动态图 | 日韩av网站在线观看 | 欧美精品在线视频 | 日本少妇一区二区 | 欧美视频免费在线观看 | 国产一级二级视频 | 99久久九九 | 欧美激情亚洲 |
