查看: 6732|回復: 0
關于串口問題。
ID:14101 發表于 2009-6-11 12:03 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
剛學單片機。
用DS1302制作電子鐘
為什么單片機串口程序一直都不斷的重新載入
求各位幫幫忙啊
串口程序
#include <reg52.h>
#include "serio.h"
#include "ds1302.h"
uchar count=0;
struct time clock1;
struct time *tm1;
void UART0_Init()//initial uart
SCON = 0x50;
//SCON: serail mode 1, 8-bit UART, REN=1,Buard=(2^SMOD)(Timer1 溢出率 )/32
TMOD |= 0x20; //TMOD:timer1 mode 2,8 位reload
PCON |= 0x80; //SMOD=1;
TH1 = 0xFD; //fosc=11.0592MHz,smod=0, Baud:4.8k--TH:F4,9.6K--TH:FD;
TL1 = 0xFD; //fosc=11.0592MHz,smod=1, Baud:19.2K--TH:FD;
IE |= 0x90; //ea=1,es=1,Enable Serial Interrupt
TR1 = 1; // timer 1 run
void UART0_SendByte(uchar da)//send one byte to pc
EA = 0;
SBUF = da;
while(TI==0);
TI=0;
EA = 1;
void UART0_SendStr(uchar *str)//send one string to pc
uchar i;
i=0;
while((*(str+i))!='\0')
UART0_SendByte(*(str+i));
i=i+1;
void UART0_SendUint32(uint32 da)
uchar flag;//第一次非0 標志,1 有效
uchar temp;
flag=0;
da=da%100000000;//求余數
temp=da/10000000;//求千萬位數
if(temp!=0 || flag!=0)
flag=1;
UART0_SendByte(temp+'0');
da=da%10000000;
temp=da/1000000;//求百萬位數
flag=1;
da=da%1000000;
temp=da/100000;//求十萬位數
flag=1;
da=da%100000;
temp=da/10000;//求萬位數
flag=1;
da=da%10000;
temp=da/1000;//求千位數
flag=1;
da=da%1000;
temp=da/100;//求百位數
flag=1;
da=da%100;
temp=da/10;//求十位數
flag=1;
da=da%10;
UART0_SendByte(da+'0');//發送個位數
void receive(void) interrupt 4
uchar temp;
EA=0;
if(RI)
temp=SBUF;
switch(count)
case 0:if(temp==0x30)
count=1;
count=0;
break;
case 1:if(temp==0x30)
count=2;
count=0;
break;
case 2:if(temp==0x30)
count=3;
count=0;
break;
case 3:clock1.year=(temp&0x0f)<<4;
count=4;
break;
case 4:clock1.year=(temp&0x0f)+clock1.year;
count=5;
break;
case 5:clock1.month=(temp&0x0f)<<4;
count=6;
break;
case 6:clock1.month=(temp&0x0f)+clock1.month;
count=7;
break;
case 7:clock1.date=(temp&0x0f)<<4;
count=8;
break;
case 8:clock1.date=(temp&0x0f)+clock1.date;
count=9;
break;
case 9:clock1.hour=(temp&0x0f)<<4;
count=10;
break;
case 10:clock1.hour=(temp&0x0f)+clock1.hour;
count=11;
break;
case 11:clock1.minute=(temp&0x0f)<<4;
count=12;
break;
case 12:clock1.minute=(temp&0x0f)+clock1.minute;
count=13;
break;
case 13:clock1.sec=(temp&0x0f)<<4;
count=14;
break;
case 14:clock1.sec=(temp&0x0f)+clock1.sec;
count=15;
break;
case 15:clock1.week=(temp&0x0f);
tm1=&clock1;
SetTime(tm1);
count=0;
break;
RI=0;
TI=0;
EA=1;
主程序
#include "reg52.h"
#include "ds1302.h"
#include "serio.h"
#include "display.h"
#include "YM12864.h"
uchar code string1[]="20  年  月  日";//第一行,lcd 顯示年月日,星期
uchar code string2[]="  :  :  ";//第二行,lcd 顯示時分秒
uchar code string3[]="電子鐘設置,設置格式為:";//計算機上顯示的提示信息
uchar code string4[]="000  年  月  日  時  分  秒 星期";//共16 個字符,其中000 為時鐘修改字
struct time *tm;
struct time clock;
void main(void)
UART0_Init();//串口初始化
UART0_SendStr(string3);
UART0_SendStr(string4);
UART0_SendByte(0x0d);
UART0_SendByte(0x0a);
LCDInit();//初始化lcd
CLS();
ShowGroup(1,1,string1);
ShowGroup(1,2,string2);
tm=&clock;//給結構指針tm 分配空間while(1)
GetTime(tm);
ShowTime(tm);
Delay(2000);
主站蜘蛛池模板: 午夜激情网站 | 黄色大片在线免费观看 | 日韩黄色一级片 | 明日边缘 | 亚洲精品乱码久久久久久动漫 | 久久一区二区视频 | 天天综合影院 | 成人在线视频免费观看 | 日本一级片在线观看 | 红桃av在线 | 日韩一二区 | 日本一级大毛片a一 | 成人福利在线观看 | 天天躁日日躁狠狠躁av麻豆男男 | 久久精品国产亚洲 | 午夜视频| 亚洲欧美日本在线 | 久久夜色精品国产欧美乱极品 | 美女91网站 | 国产成人免费观看 | 国产超碰在线观看 | 在线一区视频 | 91片黄在线观看动漫 | 窝窝午夜精品一区二区 | 特级毛片爽www免费版 | 天天操网 | 在线不卡视频 | 亚洲成人三级 | 激情五月综合色婷婷一区二区 | 国产一区二区不卡 | 国产女优在线 | 亚洲一级黄色 | 午夜成人在线视频 | 中文天堂网| 国产日本在线观看 | 国产丝袜av | 亚洲精品免费在线 | 久久久久久久免费视频 | 亚洲一区二区三区四区在线 | 黄色大片免费在线观看 | 欧美xx孕妇|
