查看: 2937|回復(fù): 0
[轉(zhuǎn)發(fā)]F28335 spwm生成程序
ID:754925 發(fā)表于 2020-5-18 20:30 | 顯示全部樓層 |閱讀模式
/* * main.c */#include "DSP2833x_Project.h"
void InitEPwm1Example(void);void Gpio_Setup(void);interrupt void epwm1_isr(void);
int N=60;float M=0.8;int i;
float sina[30]={0.0000, 0.1081, 0.2150, 0.3193, 0.4199, 0.5156,                0.6052, 0.6877, 0.7622, 0.8277, 0.8835, 0.9290,                0.9635, 0.9868, 0.9985, 0.9985, 0.9868, 0.9635,                0.9290, 0.8835, 0.8277, 0.7622, 0.6877, 0.6052,                0.5156, 0.4199, 0.3193, 0.2150, 0.1081, 0.0000};
float sinb[30]={0.8660, 0.8069, 0.7383, 0.6610, 0.5760, 0.4843,                0.3868, 0.2849, 0.1796, 0.0722, -0.0361, -0.1439,                -0.2501, -0.3533, -0.4524, -0.5462, -0.6335, -0.7135,                -0.7850, -0.8474, -0.8998, -0.9417, -0.9726, -0.9920,                -0.9998, -0.9959, -0.9803, -0.9533, -0.9150, -0.8660};
int main(void) {        InitSysCtrl();  //初始化系統(tǒng)控制        InitEPwm1Gpio();        Gpio_Setup();   //子函數(shù),gpio口設(shè)置        DINT;           //關(guān)閉中斷        InitPieCtrl();  //初始化中斷控制        IER = 0x0000;        IFR = 0x0000;        InitPieVectTable();//初始化中斷矢量表
        EALLOW;  // This is needed to write to EALLOW protected registers        PieVectTable.EPWM1_INT = &epwm1_isr;        EDIS;
        EALLOW;        SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;  //先置0,進行ePWM配置,再置1        EDIS;
        InitEPwm1Example();
        EALLOW;        SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;  //看上一個注釋        EDIS;
        i=1;
        IER |= M_INT3;
        // Enable EPWM INTn in the PIE: Group 3 interrupt 1-3        PieCtrlRegs.PIEIER3.bit.INTx1 = 1;
        // Enable global Interrupts and higher priority real-time debug events:        EINT;   // Enable Global interrupt INTM        ERTM;   // Enable Global realtime interrupt DBGM
        for(;;){            __asm("          NOP");        }
void Gpio_Setup(void){    EALLOW;    GpioCtrlRegs.GPAMUX1.bit.GPIO0=1;   //GPIO0配置為ePWM1A功能    GpioCtrlRegs.GPAMUX1.bit.GPIO1=1;   //GPIO1配置為ePWM1B功能    EDIS;}
void InitEPwm1Example(void){       // Setup TBCLK       EPwm1Regs.TBPRD = 0x61A8;                      // 3KHz       EPwm1Regs.TBPHS.half.TBPHS = 0x0000;           // Phase is 0       EPwm1Regs.TBCTR = 0;                           // 時基計數(shù)器清零       EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up       EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;        // Disable phase loading       EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;       // Clock ratio to SYSCLKOUT       EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;
       // Setup shadowing       EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;       EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;       EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;  // Load on Zero       EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
       // Set actions       EPwm1Regs.AQCTLA.bit.CAU = AQ_SET;             // Set PWM1A on event A, up count       EPwm1Regs.AQCTLA.bit.CAD = AQ_CLEAR;           // Clear PWM1A on event A, down count
       EPwm1Regs.AQCTLB.bit.CBU = AQ_SET;             // Set PWM1B on event B, up count       EPwm1Regs.AQCTLB.bit.CBD = AQ_CLEAR;           // Clear PWM1B on event B, down count
       // Interrupt where we will change the Compare Values       EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_PRD;      // Select INT on PRD event       EPwm1Regs.ETSEL.bit.INTEN = 1;                 // Enable INT       EPwm1Regs.ETPS.bit.INTPRD = ET_1ST;            // Generate INT on 1ST event
       EPwm1Regs.CMPA.half.CMPA=0x0C35;}
interrupt void epwm1_isr(void){
    if ((i>=0)&&(i<N/2)){        EPwm1Regs.CMPA.half.CMPA=EPwm1Regs.TBPRD*((1.0+M*sina[ i])/2.0);        EPwm1Regs.CMPB=EPwm1Regs.TBPRD*((1.0+M*sinb[ i])/2.0);    }
    if ((i>=N/2)&&(i<N)){        EPwm1Regs.CMPA.half.CMPA=EPwm1Regs.TBPRD*((1.0-M*sina[i-30])/2.0);        EPwm1Regs.CMPB=EPwm1Regs.TBPRD*((1.0-M*sinb[i-30])/2.0);    }
    i++;
    if (i>=N){        i=0;    }
    EPwm1Regs.ETCLR.bit.INT = 1;        //寫1對ETFLG[INT]狀態(tài)標志位清零,從而能進行下一次中斷    PieCtrlRegs.PIEACK.all=PIEACK_GROUP3;}
主站蜘蛛池模板: 欧美性猛交99久久久久99按摩 | 日韩中文一区 | 中文字幕在线看 | 男女激情视频网站 | av大全在线观看 | 日韩中文字幕一区 | 久久都是精品 | 久久成人精品视频 | 久久不卡视频 | 中文字幕在线观看第一页 | 黄色一级片视频 | 亚洲成人免费观看 | 五月天.com | 91精品国产综合久久久久久 | 色天堂影院| www视频在线观看网站 | 久久香蕉网 | 久久综合伊人 | 国产寡妇亲子伦一区二区三区四区 | 狠狠的日 | 中文字幕无人区二 | 97在线视频观看 | 日韩一区二区三区四区 | 欧美色综合 | 日韩一级免费视频 | 九色在线视频 | 免费国产一区 | 久久精品一区二区国产 | 男女激情av | 青草视频在线播放 | 一区二区在线视频 | 欧美久久久久久久 | 天天天天操 | 日日操视频| 欧美国产日韩在线 | 日韩精品一区在线观看 | 欧美日韩毛片 | 国产黄色一区 | 亚洲国产一区在线 | 久久这里只有精品6 | 91啪国产|
