查看: 6744|回復: 4
基于51單片機的電機轉速控制Proteus仿真程序
#include<reg52.h>
#include<stdio.h>
#define uchar unsigned char
#define uint unsigned int
#define THC0 0xf9
#define TLC0 0x0f   //2ms
unsigned char  code Duan[]={0x3F, 0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};//共陰極數碼管,0-9段碼表
unsigned char  Data_Buffer[8]={0,0,0,0,0,0,0,0};             // 顯示緩沖
uchar i=0;
sbit AddSpeed=P1^1;
sbit SubSpeed=P1^2;
sbit TurnForward=P1^3;
sbit TurnBackward=P1^4;
sbit Stop=P1^5;
sbit IN1=P3^0;
sbit IN2=P3^1;
sbit PWM_FC=P1^0;
int e ,e1 ,e2 ;
float uk ,uk1 ,duk ;//pid輸出值
float Kp=15,Ki=12,Kd=1.6;
int out=0;
uint SpeedSet=380;
uint cnt=0;
uint Inpluse=0,num=0;//脈沖計數
uint PWMTime=100;//脈沖寬度
unsigned char  arry[];
void SendString(uint ch);
void PIDControl();
void SystemInit();
void delay(uchar x);
void PWMOUT();
void SetSpeed();
void SegRefre();
/**************主函數************/
    SystemInit();
        SetSpeed();     //按鍵設定速度
        SegRefre();     //數碼管顯示刷新
        PWMOUT();       //輸出PWM
void PIDControl()        //pid偏差計算
    e=SpeedSet-num;
    duk=(Kp*(e-e1)+Ki*e+Kd*(e-2*e1+e2))/50;
    uk=uk1+duk;
    out=(int)uk;   //輸出為占空比
    if(out>1000)
        out=1000;
    else if(out<0)
        out=0;
    uk1=uk;               //變量值移位
    e2=e1;
    e1=e;
    PWMTime=out;
void delay(uchar x)
    uint i,j;
    for(i=x;i>0;i--)
        for(j=50;j>0;j--);
void PWMOUT()
    if(cnt<PWMTime)
        PWM_FC=1;
        PWM_FC=0;
    if(cnt>1000) cnt=0;
void SystemInit()
    TMOD=0X21;
    TH0=THC0;
    TL0=TLC0;
    TH1=0xC0;
    TL1=0XC0;
    ET1=1;
    ET0=1;
    TR0=1;
    TR1=1;
    EX0=1;
    IT0=1;
    EA=1;
    e =0;
    e1=0;
    e2=0;
    IN1 = 1;
    IN2 = 0;
void SetSpeed()
    if(AddSpeed==0)
        delay(200);           //消抖處理
        if(AddSpeed==0)
            SpeedSet+=10;
            if(SpeedSet>1500)
                SpeedSet=1500;
    if(SubSpeed==0)
        delay(200);
        if(SubSpeed==0)
            SpeedSet-=10;
            if(SpeedSet<0) SpeedSet=0;
    if(TurnForward==0)
        delay(200);
        if(TurnForward==0)
           IN1 = 1;
           IN2 = 0;
           while(TurnForward==0);
    if(TurnBackward==0)
        delay(200);
        if(TurnBackward==0)
           IN1 = 0;
           IN2 = 1;
           while(TurnBackward==0);
    if(Stop==0)
        delay(200);
        if(Stop==0)
           IN1 = 1;
           IN2 = 1;
           while(Stop==0);
void SegRefre()       //顯示刷新
     Data_Buffer[0]=SpeedSet/1000;        //分離設定值各位
     Data_Buffer[1]=SpeedSet%1000/100;
     Data_Buffer[2]=SpeedSet%100/10;
     Data_Buffer[3]=SpeedSet%10;
     Data_Buffer[4]=num/1000;
     Data_Buffer[5]=num%1000/100;
     Data_Buffer[6]=num%100/10;
     Data_Buffer[7]=num%10;
void int0() interrupt 0
    Inpluse++;          //采集外部脈沖
void t0() interrupt 1
    static unsigned char Bit=0;
    static unsigned int time=0;
    TH0=THC0;
    TL0=TLC0;
    Bit++;
    time++;  //轉速測量周期
    if(Bit>8) Bit=0;
    P0=0xff;
    P2=Duan[Data_Buffer[Bit]];  //顯示段碼
    switch(Bit)                 //數碼管位選
        case 0:P0=0X7F;break;
        case 1:P0=0XBF;break;
        case 2:P0=0XDF;break;
        case 3:P0=0XEF;break;
        case 4:P0=0XF7;break;
        case 5:P0=0XFB;break;
        case 6:P0=0XFD;break;
        case 7:P0=0XFE;break;
    if(time>100)
        time=0;
        num=Inpluse*5;
        Inpluse=0;
        PIDControl();
void timer_1()  interrupt 3
    cnt++;  //cnt越大占空比越高2.5Khz
全部資料51hei下載地址:
單片機直流電機.zip (1.81 MB, 下載次數: 178)
收藏收藏4 分享淘帖 頂1 踩
ID:825015 發表于 2020-9-30 21:42 | 只看該作者
哥哥,你可以幫我講解一下嗎?急求,我看不懂
ID:825015 發表于 2020-9-30 21:45 | 只看該作者
請求講解
ID:220066 發表于 2022-3-10 09:25 | 只看該作者
東西挺好的 挺實用的
ID:1142899 發表于 2025-1-12 17:10 | 只看該作者
謝謝分享!東西很好
主站蜘蛛池模板: 欧美a视频 | 欧美国产综合 | 久久免费看视频 | 亚洲在线免费观看 | 欧美性猛交99久久久久99按摩 | 日韩在线视频免费观看 | 天天舔天天干 | 日本福利视频 | a级片免费 | 国产一区二区在线看 | 欧美日韩在线视频观看 | 色婷婷香蕉在线一区二区 | 日韩成人免费视频 | 日本不卡视频 | 欧美日本在线 | 长河落日连续剧48集免费观看 | 黄色日本视频 | 性爱视频日本 | 国产日韩在线播放 | 中文一区二区 | 香蕉网在线 | 成人9ⅰ免费影视网站 | 黄色成人在线观看 | 亚洲黄色三级 | 五十路av | 日韩一区中文字幕 | 亚洲五月婷婷 | 日韩av免费看 | 99re视频在线| 日韩精品一区二区三区四区 | 黄色国产在线观看 | 91精品在线播放 | 天天天天天干 | 国产第一页在线 | 老女人性生活视频 | 日本福利在线 | www午夜| 日韩少妇av| 视频一区二区在线 | 在线成人免费视频 | 亚洲经典一区二区 |
