查看: 3814|回復: 0
2440驅動MMA7455L源程序
  1. /****************************************************************
  2. 文件名:Main.c
  3. 功能描述:主程序
  4. ****************************************************************/
  5. #define        GLOBAL_CLK                1
  6. #include <stdlib.h>
  7. #include <string.h>
  8. #include "def.h"
  9. #include "option.h"
  10. #include "2440addr.h"
  11. #include "2440lib.h"
  12. #include "2440slib.h"
  13. #include "Uart.h"
  14. void SPI_Init(void);
  15. void WriteByte_MMA7455L(U8 addr,U8 dat);
  16. U8 ReadByte_MMA7455L(U8 addr);
  17. static U32 cpu_freq;
  18. static U32 UPLL;
  19. static void cal_cpu_bus_clk(void)
  20. {
  21.         U32 val;
  22.         U8 m, p, s;
  23.         val = rMPLLCON;          //MPLLCON上電初始值為0x00096030
  24.         m = (val>>12)&0xff;        //結果為0x96=150
  25.         p = (val>>4)&0x3f;        //結果為0x03=3
  26.         s = val&3;                          //結果為0
  27.         //(m+8)*FIN*2 不要超出32位數!
  28.         FCLK = ((m+8)*(FIN/100)*2)/((p+2)*(1<<s))*100;//"1<<s"表示令1左移s位,即可得2^s
  29.         val = rCLKDIVN;
  30.         m = (val>>1)&3;
  31.         p = val&1;
  32.         val = rCAMDIVN;
  33.         s = val>>8;
  34.         switch (m) {
  35.         case 0:
  36.                 HCLK = FCLK;
  37.                 break;
  38.         case 1:
  39.                 HCLK = FCLK>>1;
  40.                 break;
  41.         case 2:
  42.                 if(s&2)
  43.                         HCLK = FCLK>>3;
  44.                 else
  45.                         HCLK = FCLK>>2;
  46.                 break;
  47.         case 3:
  48.                 if(s&1)
  49.                         HCLK = FCLK/6;
  50.                 else
  51.                         HCLK = FCLK/3;
  52.                 break;
  53.         }
  54.         if(p)
  55.                 PCLK = HCLK>>1;
  56.         else
  57.                 PCLK = HCLK;
  58.         if(s&0x10)
  59.                 cpu_freq = HCLK;
  60.         else
  61.                 cpu_freq = FCLK;
  62.         val = rUPLLCON;
  63.         m = (val>>12)&0xff;
  64.         p = (val>>4)&0x3f;
  65.         s = val&3;
  66.         UPLL = ((m+8)*FIN)/((p+2)*(1<<s));
  67.         UCLK = (rCLKDIVN&8)?(UPLL>>1):UPLL;
  68. }
  69. void Main(void)
  70. {
  71.         U8 key,sta;
  72.         int i;
  73.         U32 mpll_val = 0;
  74.         i = 2 ;
  75.         switch ( i ) {
  76.         case 0:        //200
  77.                 key = 12;
  78.                 mpll_val = (92<<12)|(4<<4)|(1);
  79.                 break;
  80.         case 1:        //300
  81.                 key = 13;
  82.                 mpll_val = (67<<12)|(1<<4)|(1);
  83.                 break;
  84.         case 2:        //400M
  85.                 key = 14;
  86.                 mpll_val = (92<<12)|(1<<4)|(1);
  87.                 break;
  88.         case 3:        //440!!!
  89.                 key = 14;
  90.                 mpll_val = (102<<12)|(1<<4)|(1);
  91.                 break;
  92.         default:
  93.                 key = 14;
  94.                 mpll_val = (92<<12)|(1<<4)|(1);
  95.                 break;
  96.         }
  97.         //rMPLLCON賦值0x5c011
  98.         ChangeMPllValue((mpll_val>>12)&0xff, (mpll_val>>4)&0x3f, mpll_val&3);
  99.         ChangeClockDivider(key, 12); //key=14
  100.         cal_cpu_bus_clk();
  101.
  102.         Port_Init();        //IO端口初始化
  103.         SPI_Init();//SPI初始化
  104.         MMA7455L_INIT();//MMA7455L初始化
  105.         Uart_Init();//串口初始化
  106.         Uart_Select(0);
  107.         Delay(5); //延時10ms讓IIC和SPI準備就緒
  108.         Uart_Printf("CLKCON=%x!",rCLKCON);
  109.         Uart_Printf("開始發送數據!\n\n");
  110.         //對MMA7455L的0x16寄存器寫配置數據0x05
  111.         WriteByte_MMA7455L(0x16,0x05);
  112.         //讀回0x16寄存器的配置值,判斷SPI通信是否成功.
  113.         sta=ReadByte_MMA7455L(0x16);
  114.         Uart_Printf("sta=0x%x",sta);
  115.         while(1)
  116.         {
  117.         }
  118. }
  119. void WriteByte_MMA7455L(U8 addr,U8 dat)
  120. {
  121.         int n;
  122.         //片選CS置低,使能MMA7455為SPI模式
  123.         rGPFDAT &= 0xef;
  124.         Delay(1);
  125.
  126.         Uart_Printf("SPI狀態寄存器的數據為0x%x!\n",rSPSTA0);
  127.         while(!(rSPSTA0&0x01==0x01)) ;
  128.         //高位置1寫操作
  129.         rSPTDAT0 = 0x80|((addr & 0x3f)<<1);
  130.         Uart_Printf("SPI狀態寄存器的數據為0x%x!\n",rSPSTA0);
  131.         Uart_Printf("寫操作地址發送成功!\n");
  132.         for(n=0;n<20;n++);
  133.         Uart_Printf("SPI狀態寄存器的數據為0x%x!\n",rSPSTA0);
  134.         while(!(rSPSTA0&0x01==0x01)) ;
  135.         rSPTDAT0 = dat;  //寫數據
  136.         Uart_Printf("SPI狀態寄存器的數據為0x%x!\n",rSPSTA0);
  137.         Uart_Printf("寫操作數據發送成功!\n");
  138.         for(n=0;n<20;n++);
  139.         //片選CS置高電平,結束SPI通信
  140.         rGPFDAT |= 0xff;
  141.         Delay(1);
  142. }
  143. U8 ReadByte_MMA7455L(U8 addr)
  144. {
  145.         int n;
  146.         U8 Re_Dat;
  147.         //片選CS置低電平,使能MMA7455L為SPI模式
  148.         rGPFDAT &= 0xef;
  149.         Delay(1);
  150.         Uart_Printf("SPI狀態寄存器的數據為0x%x!\n",rSPSTA0);
  151.         while(!(rSPSTA0&0x01==0x01)) ;
  152.         //讀操作高位清0
  153.         rSPTDAT0 = (addr & 0x3f)<<1;
  154.         Uart_Printf("SPI狀態寄存器的數據為0x%x!\n",rSPSTA0);
  155.         Uart_Printf("讀操作地址發送成功!\n");
  156.         for(n=0;n<20;n++);
  157.         Uart_Printf("SPI狀態寄存器的數據為0x%x!\n",rSPSTA0);
  158.         while(!(rSPSTA0&0x01==0x01));
  159.         Re_Dat = rSPRDAT0;
  160.         Uart_Printf("SPI狀態寄存器的數據為0x%x!\n",rSPSTA0);
  161.         for(n=0;n<20;n++);
  162.         //片選CS置高電平,結束SPI通信
  163.         rGPFDAT |= 0xff;
  164.         Delay(1);
  165.          //返回讀取數據
  166.         return Re_Dat;
  167. }
  168. //MMA7455L初始化
  169. void MMA7455L_INIT(void )
  170. {
  171.    MMA_QUEUE.MMA_HEAD=0;
  172.    MMA_QUEUE.MMA_CUR=0;
  173.    SPI_WriteREG(0x16,0x05);//級別模式
  174.    delay_nus(10);
  175.    SPI_WriteREG(0x18,0x20);
  176.    delay_nus(10);
  177.    SPI_WriteREG(0x19,0x00);
  178.    delay_nus(10);
  179.    SPI_WriteREG(0x1a,0x00);
  180.    delay_nus(10);
  181.   }
  182. //SPI初始化
  183. void SPI_Init(void)
  184. {
  185.         //激活時鐘控制器的SPI位
  186.         rCLKCON |= 1 <<18;
  187.         rSPCON0 = (0<<6)|(0<<5)|(1<<4)|(1<<3)|(0<<2)|(0<<1)|1;
  188.         //查詢模式;SCK使能;主機模式;時鐘低電平有效;格式A;普通模式;
  189.         //MMA7455的SPI的傳輸波特率在工作電壓小于2.4V時最高可達4MHz,大于2.4V時可達8MHz
  190.         //SPI波特率為50MHz/2/(24+1)=1MHz
  191.         rSPPRE0 = 24;
  192. }
第4章.zip (13.24 KB, 下載次數: 6)
主站蜘蛛池模板: 亚洲综合精品 | 欧美二区视频 | 国产精品无 | 国产农村妇女精品一二区 | 欧美在线综合 | av中文网 | 精品少妇一区二区三区免费观 | 中文字幕91 | 亚洲成人黄色 | 免费a视频| 欧美日韩一二区 | 国产福利一区二区 | 日韩在线观看 | 日本丰满肉感bbwbbwbbw | 亚洲欧美日韩国产 | 中文在线字幕观看 | 午夜视频网站 | 亚洲精品久久久蜜桃 | 免费成人在线观看视频 | 精品日韩在线观看 | 亚洲国产免费 | 婷婷激情五月 | 色在线视频 | 日本男人的天堂 | 成人aaaa| 欧美日韩二区三区 | 欧美视频免费在线观看 | 久久精品一区二区三区四区 | 日韩三级影院 | 伊人免费视频 | 啪啪综合网 | 亚洲人在线 | 闷骚老干部cao个爽 欧美区一区二 | 久久精品99久久久久久 | 9l视频自拍九色9l视频成人 | 精品视频久久 | 欧美成人精品欧美一级私黄 | 久久久精品国产sm调教 | 亚洲欧洲天堂 | 国产成人+综合亚洲+天堂 | 中文字幕一区二区三区四区视频 |
