VK1056驅(qū)動程序,在STM32F103下可以運行,51單片機可以自己小改,后面附上封裝和數(shù)據(jù)手冊
- #include "vk1056b.h"
- #include "delay.h"
- const u8 vk1056B_segtab[9]={14,15,16,17,18,19,20,21,22};
- u8 vk1056B_addrbit=6;//驅(qū)動ic的ram地址線數(shù)A5-A0,
- u8 vk1056B_segi,vk1056B_comi;
- u8 vk1056B_dispram[14];//顯示RAM buffer只使用低4位,bit0->com0,bit1->com1,bit2->com2,bit3->com3
- u8 vk1056B_myram[4]={0x00,0x00,0x00,0x00};
- * @brief 配置Vk1056B通信線GPIO.
- * @param None
- * @retval None
- void Vk1056B_Lowlevel_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14|GPIO_Pin_15;//通訊線電平不同,可設(shè)為開漏輸出,1056B有內(nèi)部上拉電?
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //通信線電平一樣,可設(shè)為推挽輸出?
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin =GPIO_Pin_8;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- void Vk1056B_Init(void)
- Vk1056B_Lowlevel_Init();
- //基本配置
- WriteCommandVk1056B(OSC_OFF); //00
- WriteCommandVk1056B(OSC_ON); //01
- WriteCommandVk1056B(DISP_ON); //03
- WriteCommandVk1056B(0x04);
- WriteCommandVk1056B(0x05);
- WriteCommandVk1056B(0x08);
- WriteCommandVk1056B(RC32K); //18
- WriteCommandVk1056B(COM_1_3__4);//29
- WriteCommandVk1056B(0x80);
- // WriteCommandVk1056B(COM_1_3__3);vk1056B_maxcom=3; //1/3bias 3com
- // WriteCommandVk1056B(COM_1_3__2);vk1056B_maxcom=2; //1/3bias 2com
- // WriteCommandVk1056B(COM_1_2__4);vk1056B_maxcom=4; //1/2bias 4com
- // WriteCommandVk1056B(COM_1_2__3);vk1056B_maxcom=3; //1/2bias 3com
- // WriteCommandVk1056B(COM_1_2__2);vk1056B_maxcom=2; //1/2bias 2com
- //上電默認(rèn)配置(以下未用功能關(guān)閉降低功耗)
- // WriteCommandVk1056B(TIMER_DIS);
- // WriteCommandVk1056B(WDT_DIS);
- // WriteCommandVk1056B(BUZZ_OFF);
- // WriteCommandVk1056B(IRQ_DIS);
- * @brief Vk1056B clk
- * @param None
- * @retval None
- void WriteClockVk1056B(void)
- WR=0;
- delay_us(10);
- WR=1;
- delay_us(10);
- * @brief Write Vk1056B Command
- * @param FunctonCode->功能/命令碼
- * @retval None
- void WriteCommandVk1056B(unsigned char FunctonCode) //寫命令
- u8 Shift = 0x80;
- u8 i;
- CS=0;
- delay_us(5);
- DATA=1;
- WriteClockVk1056B();
- DATA=0;
- DATA=0;
- for(i = 0; i < 8; i++)
- if(Shift & FunctonCode) //與1000 0000
- DATA=1;
- else
- DATA=0;
- Shift = Shift >> 1;
- DATA=0;
- WriteClockVk1056B(); //發(fā)送一個 0 16xx中最后一位 X
- CS=1;
- delay_us(5);
- DATA=1;
- * @brief Write 1 data to Vk1056B
- * @param Addr->寫入ram的地址
- * @param Databuf->寫入ram的數(shù)據(jù)
- * @retval None
- void Write1DataVk1056B(unsigned char Addr,unsigned char Dat)
- unsigned char i; //寫數(shù)據(jù)
- unsigned char Shift;
- Shift = 0x20; //屏蔽高3位 只用5位 0010 0000
- CS=0;
- delay_us(5);
- DATA=1;
- WriteClockVk1056B(); //101
- DATA=0;
- DATA=1;
- for( i = 0; i < vk1056B_addrbit; i++) //6
- if (Addr & Shift) //與0010 0000
- DATA=1;
- else
- DATA=0;
- Shift = 0x01;
- for (i = 0; i < 4; i++) //與0000 0001
- if( Dat & Shift)
- DATA=1;
- else
- DATA=0;
- Shift = Shift << 1;
- CS=1;
- delay_us(5);
- DATA=1;
- * @brief Write n data to Vk1056B
- * @param Addr->寫入ram的起始地址
- * @param Databuf->寫入ram的數(shù)據(jù)buffer
- * @param Cnt->寫入ram的數(shù)據(jù)個數(shù)
- * @retval None 連續(xù)寫模式
- void WritenDataVk1056B(unsigned char Addr,unsigned char *Databuf,unsigned char Cnt)
- unsigned char i,j;
- unsigned char dataval;
- CS=0;
- delay_us(5);
- DATA=1;
- DATA=0;
- DATA=1;
- Shift = 0x20; //0010 0000
- for( i = 0; i < 6; i++)
- if (Addr & Shift)
- DATA=1;
- else
- DATA=0;
- for (j = 0; j < Cnt; j++)
- Shift = 0x01;
- dataval=*Databuf++;
- if( dataval & Shift)
- DATA=1;
- else
- DATA=0;
- CS=1;
- delay_us(5);
- DATA=1;
- * @brief lcd全顯或全滅
- * @param state=1->lcd全亮
- * @param state=0->lcd全滅
- * @retval None
- void Vk1056B_DisAll(unsigned char state)
- unsigned char i;
- for(i=0;i<14;i++)
- if(state==1)
- vk1056B_dispram[i]=0x0f;
- else
- vk1056B_dispram[i]=0x00;
- WritenDataVk1056B(vk1056B_segtab[0],vk1056B_dispram,14);
- //以下是根據(jù)段碼屏廠家給出的表格做的,不同廠家資料程序不同,此處可以跳過不看了
- //A顯示
- void Vk1056B_Display_A(u8 i)
- switch(i)
- case 0:
- Vk1056B_On(0,1);
- Vk1056B_On(0,2);
- Vk1056B_On(0,4);
- Vk1056B_On(0,8);
- Vk1056B_On(1,2);
- Vk1056B_OFF(1,4);
- Vk1056B_On(1,8);
- break;
- case 1:
- Vk1056B_OFF(0,1);
- Vk1056B_OFF(0,2);
- Vk1056B_OFF(0,4);
- Vk1056B_OFF(0,8);
- Vk1056B_On(1,2);
- Vk1056B_OFF(1,4);
- Vk1056B_On(1,8);
- break;
- case 2:
- Vk1056B_On(0,1);
- Vk1056B_On(0,2);
- Vk1056B_OFF(0,4);
- Vk1056B_On(0,8);
- Vk1056B_OFF(1,2);
- Vk1056B_On(1,4);
- Vk1056B_On(1,8);
- break;
- case 3:
- Vk1056B_On(0,1);
- Vk1056B_OFF(0,2);
- Vk1056B_OFF(0,4);
VK1056驅(qū)動.zip
(3.66 KB, 下載次數(shù): 48)
2020-6-5 17:34 上傳
點擊文件名下載附件
VK1056技術(shù)手冊.zip
(1.88 MB, 下載次數(shù): 35)
2020-6-5 17:35 上傳
點擊文件名下載附件
