本帖最后由 jinglixixi 于 2020-6-17 23:06 編輯
1.使用GPIO口模擬I2C接口 在MM32 eMiniBoard開發板的例程中提供了一個LED燈閃爍程序,通過它我們可以學習控制GPIO口定義輸出口及輸出高低電平信號的方法, 據此可用GPIO口來模擬I2C接口以控制該接口形式的OLED顯示屏,該OLED顯示屏具有占用引腳少,顯示信息量較多的特點。 在引腳的分配上,用PB6來連接OLED屏的SCK引腳,用PB7來連接OLED屏的SDA引腳,為此其輸出高低的定義為: #define OLED_SCLK_Set() GPIO_SetBits(GPIOB,GPIO_Pin_6) //PB13 #define OLED_SCLK_Clr() GPIO_ResetBits(GPIOB,GPIO_Pin_6)
#define OLED_SDIN_Set() GPIO_SetBits(GPIOB,GPIO_Pin_7) //PB14 #define OLED_SDIN_Clr() GPIO_ResetBits(GPIOB,GPIO_Pin_7)
相應的OLED顯示屏的初始化函數為: - void OLED_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- OLED_SCLK_Set();
- OLED_SDIN_Set();
- delay_ms(800);
- OLED_WR_Byte(0xAE,OLED_CMD);//--display off
- OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
- OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
- OLED_WR_Byte(0x40,OLED_CMD);//--set start line address
- OLED_WR_Byte(0xB0,OLED_CMD);//--set page address
- OLED_WR_Byte(0x81,OLED_CMD); // contract control
- OLED_WR_Byte(0xFF,OLED_CMD);//--128
- OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap
- OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse
- OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
- OLED_WR_Byte(0x3F,OLED_CMD);//--1/32 duty
- OLED_WR_Byte(0xC8,OLED_CMD);//Com scan direction
- OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset
- OLED_WR_Byte(0xD5,OLED_CMD);//set osc division
- OLED_WR_Byte(0x80,OLED_CMD);//
- OLED_WR_Byte(0xD8,OLED_CMD);//set area color mode off
- OLED_WR_Byte(0x05,OLED_CMD);//
- OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
- OLED_WR_Byte(0xF1,OLED_CMD);//
- OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
- OLED_WR_Byte(0x12,OLED_CMD);//
- OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
- OLED_WR_Byte(0x30,OLED_CMD);//
- OLED_WR_Byte(0x8D,OLED_CMD);//set charge pump enable
- OLED_WR_Byte(0x14,OLED_CMD);//
- OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
復制代碼2. OLED屏顯示驅動 在完成功能引腳定義及初始化的基礎下,要實現具體的字符及數值的顯示,需相關函數的配合,關鍵的函數為: - void OLED_ShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t Char_Size)
- unsigned char c=0,i=0;
- c=chr-' ';
- if(x>Max_Column-1){x=0;y=y+2;}
- if(Char_Size ==16)
- OLED_Set_Pos(x,y);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
- OLED_Set_Pos(x,y+1);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
- else {
- for(i=0;i<6;i++)
- OLED_WR_Byte(F6x8[c][i],OLED_DATA);
- uint32_t oled_pow(uint8_t m,uint8_t n)
- uint32_t result=1;
- while(n--)result*=m;
- return result;
- void OLED_ShowNum(uint8_t x,uint8_t y,uint32_t num,uint8_t len,uint8_t size2)
- uint8_t t,temp;
- uint8_t enshow=0;
- for(t=0;t<len;t++)
- temp=(num/oled_pow(10,len-t-1))%10;
- if(enshow==0&&t<(len-1))
- if(temp==0)
- OLED_ShowChar(x+(size2/2)*t,y,' ',size2);
- continue;
- }else enshow=1;
- OLED_ShowChar(x+(size2/2)*t,y,temp+'0',size2);
- void OLED_ShowString(uint8_t x,uint8_t y,uint8_t *chr,uint8_t Char_Size)
- unsigned char j=0;
- while (chr[j]!='\0')
- { OLED_ShowChar(x,y,chr[j],Char_Size);
- x+=8;
- if(x>120){x=0;y+=2;}
- j++;
復制代碼3.顯示功能的測試 為了測試OLED屏的顯示功能,其主函數如下: - int main(void)
- delay_init();
- OLED_Init();
- OLED_Clear();
- OLED_ShowString(0,0,"MM32L073 TEST",16);
- OLED_ShowString(0,2,"OLED Display",16);
- OLED_ShowString(0,4,"jinglixixi",16);
- OLED_ShowString(0,6,"2020.5.22",16);
- while(1);
相應的顯示效果如圖1 所示,后面就可以為其添加具體的應用功能。圖1 顯示效果
4.溫度測量與顯示 在例程中存在一個利用A/D轉換測量片內溫度的程序,參考該程序的設計,我們可以將其改造成一個利用OLED屏來顯示溫度值。 實現圖2顯示效果的主程序如下: - int main(void)
- u16 ADCVAL;
- float Temp;
- u32 Tem;
- delay_init();
- uart_initwBaudRate(9600);
- OLED_Init();
- OLED_Clear();
- OLED_ShowString(0,2,"Temp Display",16);
- ADC1_SingleChannel( ADC_Channel_10);
- while(1)
- ADCVAL=Get_Adc_Average(ADC_Channel_10,5);
- Temp=27.0+(ADCVAL-1800)/5.96;
- Tem=Temp;
- printf("Temp=%.2f \r\n",Temp);
- OLED_ShowString(0,6,"Temp= C",16);
- OLED_ShowNum(40,6,Tem,4,16);
- delay_ms(1000);
圖2 顯示效果
