MQTT(Message Queuing Telemetry Transport,消息隊(duì)列遙測(cè)傳輸協(xié)議),是一種基于發(fā)布/訂閱(publish/subscribe)模式的"輕量級(jí)"通訊協(xié)議,該協(xié)議構(gòu)建于TCP/IP協(xié)議上,由IBM在1999年發(fā)布。MQTT最大優(yōu)點(diǎn)在于,可以以極少的代碼和有限的帶寬,為連接遠(yuǎn)程設(shè)備提供實(shí)時(shí)可靠的消息服務(wù)。作為一種低開銷、低帶寬占用的即時(shí)通訊協(xié)議,使其在物聯(lián)網(wǎng)、小型設(shè)備、移動(dòng)應(yīng)用等方面有較廣泛的應(yīng)用。
在基于C的封包底層上有許多比較精妙的地方,可以參考看一看
- * @version V1.0.0
- * @date 2019/12/15
- * @brief
- #define MQTTCLIENT_C_//如果沒有定義
- #include "mqtt_msg.h"
- #include "string.h"
- #include "stm32f10x.h"
- #define MQTT_MAX_FIXED_HEADER_SIZE 3
- uint16_t mqtt_message_id = 0;
- enum mqtt_connect_flag
- MQTT_CONNECT_FLAG_USERNAME = 1 << 7,
- MQTT_CONNECT_FLAG_PASSWORD = 1 << 6,
- MQTT_CONNECT_FLAG_WILL_RETAIN = 1 << 5,
- MQTT_CONNECT_FLAG_WILL = 1 << 2,
- MQTT_CONNECT_FLAG_CLEAN_SESSION = 1 << 1
- //__attribute((__packed__))
- struct mqtt_connect_variable_header
- uint8_t lengthMsb;
- uint8_t lengthLsb;
- uint8_t magic[4];
- uint8_t version;
- uint8_t flags;
- uint8_t keepaliveMsb;
- uint8_t keepaliveLsb;
- int mqtt_get_type(char* buffer) { return (buffer[0] & 0xf0) >> 4; }
- int mqtt_get_connect_ret_code(char* buffer) { return (buffer[3]); }
- int mqtt_get_qos(char* buffer) { return (buffer[0] & 0x06) >> 1; }
- int append_string(int *length, char* buffer,int buffer_length, char* string, int len)
- if((*length) + len + 2 > buffer_length)//加上 ClientID 和 記錄 ClientID個(gè)數(shù)(兩位) 以后超出了數(shù)組
- return -1;
- buffer[(*length)++] = len >> 8;
- buffer[(*length)++] = len & 0xff;
- c_memcpy(buffer + (*length), string, len);
- (*length) += len;
- return len + 2;
- uint16_t append_message_id(int *length, char* buffer,int buffer_length, uint16_t message_id)
- // If message_id is zero then we should assign one, otherwise
- // we'll use the one supplied by the caller
- while(message_id == 0)
- message_id = ++mqtt_message_id;
- if((*length) + 2 > buffer_length)
- return 0;
- buffer[(*length)++] = message_id >> 8;
- buffer[(*length)++] = message_id & 0xff;
- return message_id;
- int fini_message(char **data_ptr,int length,char* buffer, int type, int dup, int qos, int retain)
- int remaining_length = length - MQTT_MAX_FIXED_HEADER_SIZE;
- if(remaining_length > 127)
- buffer[0] = ((type & 0x0f) << 4) | ((dup & 1) << 3) | ((qos & 3) << 1) | (retain & 1);
- buffer[1] = 0x80 | (remaining_length % 128);
- buffer[2] = remaining_length / 128;
- length = remaining_length + 3;
- *data_ptr = buffer;
- else
- buffer[1] = ((type & 0x0f) << 4) | ((dup & 1) << 3) | ((qos & 3) << 1) | (retain & 1);
- buffer[2] = remaining_length;
- length = remaining_length + 2;
- *data_ptr = buffer + 1;
- return length;
- uint16_t mqtt_get_id(char* buffer, uint16_t length)
- if(length < 1)
- return 0;
- switch(mqtt_get_type(buffer))
- case MQTT_MSG_TYPE_PUBLISH:
- int i;
- int topiclen;
- for(i = 1; i < length; ++i)
- if((buffer[i] & 0x80) == 0)
- ++i;
- break;
- if(i + 2 >= length)
- return 0;
- topiclen = buffer[i++] << 8;
- topiclen |= buffer[i++];
- if(i + topiclen >= length)
- return 0;
- i += topiclen;
- if(mqtt_get_qos(buffer) > 0)
- return 0;
- //i += 2;
- } else {
- return 0;
- return (buffer[i] << 8) | buffer[i + 1];
- case MQTT_MSG_TYPE_PUBACK:
- case MQTT_MSG_TYPE_PUBREC:
- case MQTT_MSG_TYPE_PUBREL:
- case MQTT_MSG_TYPE_PUBCOMP:
- case MQTT_MSG_TYPE_SUBACK:
- case MQTT_MSG_TYPE_UNSUBACK:
- case MQTT_MSG_TYPE_SUBSCRIBE:
- // This requires the remaining length to be encoded in 1 byte,
- // which it should be.
- if(length >= 4 && (buffer[1] & 0x80) == 0)
- return (buffer[2] << 8) | buffer[3];
- else
- return 0;
- default:
- return 0;
- * @brief 打包連接MQTT指令
- * @param info MQTT信息
- * @param data_ptr 打包的數(shù)據(jù)首地址
- * @param buffer 打包進(jìn)的數(shù)組
- * @param buffer_length 數(shù)組長(zhǎng)度
- * @retval 數(shù)據(jù)長(zhǎng)度
- * @warning None
- * @example
- int mqtt_msg_connect(mqtt_connect_info_t* info,char **data_ptr,char* buffer,int buffer_length)
- int length;
- struct mqtt_connect_variable_header* variable_header;
- mqtt_message_id = 0;
- length = MQTT_MAX_FIXED_HEADER_SIZE;//頭.連接類型1位,數(shù)據(jù)個(gè)數(shù)2位(如果大于127就需要兩位)
- if(length + sizeof(*variable_header) > buffer_length)//數(shù)組不夠存儲(chǔ)的
- return 0;
- variable_header = (void*)(buffer + length);//把數(shù)組分給這個(gè)結(jié)構(gòu)體里面的變量
- length += sizeof(*variable_header);//存儲(chǔ)完 連接類型,整個(gè)數(shù)據(jù)個(gè)數(shù),版本號(hào)個(gè)數(shù),版本號(hào),等
- variable_header->lengthMsb = 0;//版本名稱個(gè)數(shù)高位
- variable_header->lengthLsb = 4;//版本名稱個(gè)數(shù)低位
- c_memcpy(variable_header->magic, "MQTT", 4);//版本名稱MQTT
- variable_header->version = 4;//版本號(hào)
- variable_header->flags = 0;//先清零
- variable_header->keepaliveMsb = info->keepalive >> 8;//心跳包時(shí)間
- variable_header->keepaliveLsb = info->keepalive & 0xff;//心跳包時(shí)間
- if(info->clean_session)//清除連接信息
- variable_header->flags |= MQTT_CONNECT_FLAG_CLEAN_SESSION;
- if(info->client_id != NULL && info->client_id[0] != '\0')//client_id
- if(append_string(&length,buffer,buffer_length, info->client_id, c_strlen(info->client_id)) < 0)//拷貝
- return -1;//數(shù)組不夠用呀...
- else
- return -2;//沒有設(shè)置client_id
- if(info->will_topic != NULL && info->will_topic[0] != '\0')//遺囑
- if(append_string(&length,buffer,buffer_length , info->will_topic, c_strlen(info->will_topic)) < 0)//遺囑的主題
- return -3;
- if(append_string(&length,buffer,buffer_length , info->will_message, c_strlen(info->will_message)) < 0)//遺囑的消息
- return -4;
- variable_header->flags |= MQTT_CONNECT_FLAG_WILL;//需要遺囑
- if(info->will_retain)//遺囑是夠需要服務(wù)器保留
- variable_header->flags |= MQTT_CONNECT_FLAG_WILL_RETAIN;//保留遺囑
- variable_header->flags |= (info->will_qos & 3) << 3;//遺囑消息等級(jí)
- if(info->username != NULL && info->username[0] != '\0')//username
- if(append_string(&length,buffer,buffer_length, info->username, c_strlen(info->username)) < 0)//拷貝用戶名
- return -5;
- variable_header->flags |= MQTT_CONNECT_FLAG_USERNAME;//有用戶名
- if(info->password != NULL && info->password[0] != '\0')//password
- if(append_string(&length,buffer,buffer_length, info->password, c_strlen(info->password)) < 0)
- return -6;
- variable_header->flags |= MQTT_CONNECT_FLAG_PASSWORD;//有密碼
- return fini_message(data_ptr,length, buffer, MQTT_MSG_TYPE_CONNECT, 0, 0, 0);//最終組合連接MQTT的指令
- * @brief 判斷是否連接上MQTT
- * @param 服務(wù)器返回的數(shù)據(jù)
- * @param
- * @retval 0 連接成功
- * @example
- int mqtt_msg_connect_ack(char *buff)
- if(mqtt_get_type(buff) == MQTT_MSG_TYPE_CONNACK)
- return mqtt_get_connect_ret_code(buff);
- return -1;
- * @brief 斷開連接
- * @warning None
- * @example
- int mqtt_msg_disconnect(char **data_ptr,char* buffer,int buffer_length)
- int length;
- return fini_message(data_ptr,length, buffer, MQTT_MSG_TYPE_DISCONNECT, 0, 0, 0);
- * @brief 訂閱主題
- * @param topic 訂閱的主題
- * @param qos 消息等級(jí)
- * @warning None
- * @example
- int mqtt_msg_subscribe_topic(char* topic, int qos,char **data_ptr,char* buffer,int buffer_length)
- int length;
- if(topic == NULL || topic[0] == '\0')
- return -1;
- if((mqtt_message_id = append_message_id(&length, buffer, buffer_length, 0)) == 0)
- return -2;
- if(append_string(&length, buffer, buffer_length, topic, c_strlen(topic)) < 0)
- return -3;
- if(length + 1 > buffer_length)
- return -4;
- buffer[length++] = qos;
- return fini_message(data_ptr,length, buffer, MQTT_MSG_TYPE_SUBSCRIBE, 0, 1, 0);
- * @brief 判斷是否成功訂閱
- * @param buffer 服務(wù)器返回的數(shù)據(jù)
- * @param length 服務(wù)器返回的數(shù)據(jù)長(zhǎng)度
- * @retval 0:成功 1:失敗
- * @example
- int mqtt_msg_subscribe_ack(char* buffer, uint16_t length)
- if(mqtt_get_type(buffer) == MQTT_MSG_TYPE_SUBACK)
- if(mqtt_get_id(buffer,length) == mqtt_message_id)
- return 0;
- else
- return 1;
- else
- return 1;
- * @brief 發(fā)布消息
- * @param topic 主題
- * @param data 消息
- * @param data_length 消息長(zhǎng)度
- * @param retain 是否需要保留消息
- * @warning None
- * @example
- int mqtt_msg_publish(char* topic, char* date, int data_length, int qos, int retain, char **data_ptr,char* buffer,int buffer_length)
- int length;
- return -1;
- if(append_string(&length, buffer, buffer_length, topic, strlen(topic)) < 0)
- return -2;
- if(qos > 0)
- return -3;
- else
- if(length + data_length > buffer_length)
- return -4;
- memcpy(buffer + length, date, data_length);
- length += data_length;
- return fini_message(data_ptr,length, buffer, MQTT_MSG_TYPE_PUBLISH, 0, qos, retain);
- int mqtt_msg_puback(uint16_t message_id,char **data_ptr,char* buffer,int buffer_length)
- int length;
- if(append_message_id(&length, buffer, buffer_length,message_id) == 0)
- return -1;
- return fini_message(data_ptr,length, buffer, MQTT_MSG_TYPE_PUBACK, 0, 0, 0);
- int mqtt_msg_pubrec(uint16_t message_id,char **data_ptr,char* buffer,int buffer_length)
- int length;
- return -1;
- return fini_message(data_ptr,length, buffer, MQTT_MSG_TYPE_PUBREC, 0, 0, 0);
- int mqtt_msg_pubrel(uint16_t message_id,char **data_ptr,char* buffer,int buffer_length)
- int length;
- return -1;
- return fini_message(data_ptr,length, buffer, MQTT_MSG_TYPE_PUBREL, 0, 1, 0);
- int mqtt_msg_pubcomp(uint16_t message_id,char **data_ptr,char* buffer,int buffer_length)
- int length;
- return -1;
- return fini_message(data_ptr,length, buffer, MQTT_MSG_TYPE_PUBCOMP, 0, 0, 0);
- const char* mqtt_get_publish_topic(char* buffer, uint16_t* length)
- int i;
- int totlen = 0;
- int topiclen;
- for(i = 1; i < *length; ++i)
- totlen += (buffer[i] & 0x7f) << (7 * (i -1));
- ++i;
- break;
- totlen += i;
- if(i + 2 >= *length)
- return NULL;
- if(i + topiclen > *length)
- return NULL;
- *length = topiclen;
- return (const char*)(buffer + i);
- const char* mqtt_get_publish_data(char* buffer, uint16_t* length)
- int i;
- int totlen = 0;
- int topiclen;
- int blength = *length;
- *length = 0;
- for(i = 1; i < blength; ++i)
- totlen += (buffer[i] & 0x7f) << (7 * (i - 1));
- ++i;
- break;
- totlen += i;
- if(i + 2 >= blength)
- return NULL;
- if(i + topiclen >= blength)
- return NULL;
- i += topiclen;
- return NULL;
- i += 2;
- if(totlen < i)
- return NULL;
- if(totlen <= blength)
- *length = totlen - i;
- else
- *length = blength - i;
- * @brief 打包服務(wù)器返回的心跳包數(shù)據(jù)(用不到)
- * @warning None
- * @example
- int mqtt_msg_pingresp(char **data_ptr,char* buffer,int buffer_length)
- int length;
- return fini_message(data_ptr,length, buffer, MQTT_MSG_TYPE_PINGRESP, 0, 0, 0);
- * @brief 獲取發(fā)送給服務(wù)器的心跳包數(shù)據(jù)
- * @warning None
- * @example
- int mqtt_msg_pingreq(char **data_ptr,char* buffer,int buffer_length)
- int length;
- return fini_message(data_ptr,length, buffer, MQTT_MSG_TYPE_PINGREQ, 0, 0, 0);
MQTT封包解包底層(C語言).zip
2020-6-26 15:31 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
4.14 KB, 下載次數(shù): 28, 下載積分: 黑幣 -5
