- #include "PS2X_lib.h"
- #include <math.h>
- #include <stdio.h>
- #include <stdint.h>
- #include <avr/io.h>
- #if ARDUINO > 22
- #include "Arduino.h"
- #else
- #include "WProgram.h"
- #include "pins_arduino.h"
- #endif
- static byte enter_config[]={0x01,0x43,0x00,0x01,0x00};
- static byte set_mode[]={0x01,0x44,0x00,0x01,0x03,0x00,0x00,0x00,0x00};
- static byte set_bytes_large[]={0x01,0x4F,0x00,0xFF,0xFF,0x03,0x00,0x00,0x00};
- static byte exit_config[]={0x01,0x43,0x00,0x00,0x5A,0x5A,0x5A,0x5A,0x5A};
- static byte enable_rumble[]={0x01,0x4D,0x00,0x00,0x01};
- static byte type_read[]={0x01,0x45,0x00,0x5A,0x5A,0x5A,0x5A,0x5A,0x5A};
- boolean PS2X::NewButtonState() {
- return ((last_buttons ^ buttons) > 0);
- boolean PS2X::NewButtonState(unsigned int button) {
- return (((last_buttons ^ buttons) & button) > 0);
- boolean PS2X::ButtonPressed(unsigned int button) {
- return(NewButtonState(button) & Button(button));
- boolean PS2X::ButtonReleased(unsigned int button) {
- return((NewButtonState(button)) & ((~last_buttons & button) > 0));
- boolean PS2X::Button(uint16_t button) {
- return ((~buttons & button) > 0);
- unsigned int PS2X::ButtonDataByte() {
- return (~buttons);
- byte PS2X::Analog(byte button) {
- return PS2data[button];
- unsigned char PS2X::_gamepad_shiftinout (char byte) {
- unsigned char tmp = 0;
- for(unsigned char i=0;i<8;i++) {
- if(CHK(byte,i)) CMD_SET();
- else CMD_CLR();
- CLK_CLR();
- delayMicroseconds(CTRL_CLK);
- //if(DAT_CHK()) SET(tmp,i);
- if(DAT_CHK()) bitSet(tmp,i);
- CLK_SET();
- #if CTRL_CLK_HIGH
- delayMicroseconds(CTRL_CLK_HIGH);
- #endif
- CMD_SET();
- delayMicroseconds(CTRL_BYTE_DELAY);
- return tmp;
- void PS2X::read_gamepad() {
- read_gamepad(false, 0x00);
- boolean PS2X::read_gamepad(boolean motor1, byte motor2) {
- double temp = millis() - last_read;
- if (temp > 1500) //waited to long
- reconfig_gamepad();
- if(temp < read_delay) //waited too short
- delay(read_delay - temp);
- if(motor2 != 0x00)
- motor2 = map(motor2,0,255,0x40,0xFF); //noting below 40 will make it spin
- char dword[9] = {0x01,0x42,0,motor1,motor2,0,0,0,0};
- byte dword2[12] = {0,0,0,0,0,0,0,0,0,0,0,0};
- // Try a few times to get valid data...
- for (byte RetryCnt = 0; RetryCnt < 5; RetryCnt++) {
- CMD_SET();
- CLK_SET();
- ATT_CLR(); // low enable joystick
- //Send the command to send button and joystick data;
- for (int i = 0; i<9; i++) {
- PS2data[i] = _gamepad_shiftinout(dword[i]);
- if(PS2data[1] == 0x79) { //if controller is in full data return mode, get the rest of data
- for (int i = 0; i<12; i++) {
- PS2data[i+9] = _gamepad_shiftinout(dword2[i]);
- ATT_SET(); // HI disable joystick
- // Check to see if we received valid data or not.
- // We should be in analog mode for our data to be valid (analog == 0x7_)
- if ((PS2data[1] & 0xf0) == 0x70)
- break;
- // If we got to here, we are not in analog mode, try to recover...
- reconfig_gamepad(); // try to get back into Analog mode.
- delay(read_delay);
- // If we get here and still not in analog mode (=0x7_), try increasing the read_delay...
- if ((PS2data[1] & 0xf0) != 0x70) {
- if (read_delay < 10)
- read_delay++; // see if this helps out...
- #ifdef PS2X_COM_DEBUG
- Serial.println("OUT:IN");
- for(int i=0; i<9; i++){
- Serial.print(dword[i], HEX);
- Serial.print(":");
- Serial.print(PS2data[i], HEX);
- Serial.print(" ");
- Serial.print(dword2[i], HEX);
- Serial.print(PS2data[i+9], HEX);
- Serial.println("");
- #endif
- last_buttons = buttons; //store the previous buttons states
- #if defined(__AVR__)
- buttons = *(uint16_t*)(PS2data+3); //store as one value for multiple functions
- #else
- buttons = (uint16_t)(PS2data[4] << 8) + PS2data[3]; //store as one value for multiple functions
- #endif
- last_read = millis();
- return ((PS2data[1] & 0xf0) == 0x70); // 1 = OK = analog mode - 0 = NOK
- byte PS2X::config_gamepad(uint8_t clk, uint8_t cmd, uint8_t att, uint8_t dat) {
- return config_gamepad(clk, cmd, att, dat, false, false);
- byte PS2X::config_gamepad(uint8_t clk, uint8_t cmd, uint8_t att, uint8_t dat, bool pressures, bool rumble) {
- byte temp[sizeof(type_read)];
- #ifdef __AVR__
- _clk_mask = digitalPinToBitMask(clk);
- _clk_oreg = portOutputRegister(digitalPinToPort(clk));
- _cmd_mask = digitalPinToBitMask(cmd);
- _cmd_oreg = portOutputRegister(digitalPinToPort(cmd));
- _att_mask = digitalPinToBitMask(att);
- _att_oreg = portOutputRegister(digitalPinToPort(att));
- _dat_mask = digitalPinToBitMask(dat);
- _dat_ireg = portInputRegister(digitalPinToPort(dat));
- #else
- uint32_t lport; // Port number for this pin
- lport = digitalPinToPort(clk);
- _clk_lport_set = portOutputRegister(lport) + 2;
- _clk_lport_clr = portOutputRegister(lport) + 1;
- lport = digitalPinToPort(cmd);
- _cmd_lport_set = portOutputRegister(lport) + 2;
- _cmd_lport_clr = portOutputRegister(lport) + 1;
- lport = digitalPinToPort(att);
- _att_lport_set = portOutputRegister(lport) + 2;
- _att_lport_clr = portOutputRegister(lport) + 1;
- _dat_lport = portInputRegister(digitalPinToPort(dat));
- #endif
- pinMode(clk, OUTPUT); //configure ports
- pinMode(att, OUTPUT);
- pinMode(cmd, OUTPUT);
- pinMode(dat, INPUT);
- digitalWrite(dat, HIGH); //enable pull-up
- #endif
- CMD_SET(); // SET(*_cmd_oreg,_cmd_mask);
- CLK_SET();
- //new error checking. First, read gamepad a few times to see if it's talking
- read_gamepad();
- read_gamepad();
- //see if it talked - see if mode came back.
- //If still anything but 41, 73 or 79, then it's not talking
- if(PS2data[1] != 0x41 && PS2data[1] != 0x73 && PS2data[1] != 0x79){
- #ifdef PS2X_DEBUG
- Serial.println("Controller mode not matched or no controller found");
- Serial.print("Expected 0x41, 0x73 or 0x79, but got ");
- Serial.println(PS2data[1], HEX);
- #endif
- return 1; //return error code 1
- //try setting mode, increasing delays if need be.
- read_delay = 1;
- for(int y = 0; y <= 10; y++) {
- sendCommandString(enter_config, sizeof(enter_config)); //start config run
- //read type
- CMD_SET();
- CLK_SET();
- temp[i] = _gamepad_shiftinout(type_read[i]);
- controller_type = temp[3];
- sendCommandString(set_mode, sizeof(set_mode));
- if(rumble){ sendCommandString(enable_rumble, sizeof(enable_rumble)); en_Rumble = true; }
- if(pressures){ sendCommandString(set_bytes_large, sizeof(set_bytes_large)); en_Pressures = true; }
- sendCommandString(exit_config, sizeof(exit_config));
- read_gamepad();
- if(pressures){
- break;
- if(PS2data[1] == 0x73)
- return 3;
- break;
- if(y == 10){
- #ifdef PS2X_DEBUG
- Serial.println("Controller not accepting commands");
- Serial.print("mode stil set at");
- #endif
- return 2; //exit function with error
- read_delay += 1; //add 1ms to read_delay
- return 0; //no error if here
- void PS2X::sendCommandString(byte string[], byte len) {
- byte temp[len];
- for (int y=0; y < len; y++)
- temp[y] = _gamepad_shiftinout(string[y]);
- ATT_SET(); //high disable joystick
- delay(read_delay); //wait a few
- Serial.println("OUT:IN Configure");
- for(int i=0; i<len; i++) {
- Serial.print(string[i], HEX);
- Serial.print(temp[i], HEX);
- #else
- _gamepad_shiftinout(string[y]);
- #endif
- byte PS2X::readType() {
- CMD_SET();
- CLK_SET();
- if(temp[3] == 0x03)
- return 1;
- else if(temp[3] == 0x01)
- return 2;
- return 0;
- if(controller_type == 0x03)
- return 1;
- else if(controller_type == 0x01)
- return 2;
- else if(controller_type == 0x0C)
- return 3; //2.4G Wireless Dual Shock PS2 Game Controller
- return 0;
- void PS2X::enableRumble() {
- sendCommandString(enable_rumble, sizeof(enable_rumble));
- en_Rumble = true;
- bool PS2X::enablePressures() {
- sendCommandString(set_bytes_large, sizeof(set_bytes_large));
- read_gamepad();
- read_gamepad();
- if(PS2data[1] != 0x79)
- return false;
- en_Pressures = true;
- return true;
- void PS2X::reconfig_gamepad(){
- if (en_Rumble)
- if (en_Pressures)
- #ifdef __AVR__
- inline void PS2X::CLK_SET(void) {
- register uint8_t old_sreg = SREG;
- cli();
- *_clk_oreg |= _clk_mask;
- SREG = old_sreg;
- inline void PS2X::CLK_CLR(void) {
- cli();
- *_clk_oreg &= ~_clk_mask;
- SREG = old_sreg;
- inline void PS2X::CMD_SET(void) {
- cli();
- *_cmd_oreg |= _cmd_mask; // SET(*_cmd_oreg,_cmd_mask);
- SREG = old_sreg;
- inline void PS2X::CMD_CLR(void) {
- cli();
- *_cmd_oreg &= ~_cmd_mask; // SET(*_cmd_oreg,_cmd_mask);
- SREG = old_sreg;
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
PS2X_lib.zip
2020-7-16 09:08 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
5.83 KB, 下載次數(shù): 7, 下載積分: 黑幣 -5
