tm1638仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
TM1638仿真程序
- #ifndef _TM1638_H
- #define _TM1638_H
- #include <REGX51.H>
- #define DATA_COMMAND 0X40
- #define DISP_COMMAND 0x80
- #define ADDR_COMMAND 0XC0
- //TM1638模塊引腳定義
- sbit DIO=P1^0;
- sbit CLK=P1^1;
- sbit STB=P1^2;
- //共陰數碼管顯示代碼
- unsigned char code tab[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,
- 0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
- void TM1638_Write(unsigned char DATA) //寫數據函數
- unsigned char i;
- for(i=0;i<8;i++)
- CLK=0;
- if(DATA&0X01)
- DIO=1;
- else
- DIO=0;
- DATA>>=1;
- CLK=1;
- unsigned char TM1638_Read(void) //讀數據函數
- unsigned char i;
- unsigned char temp=0;
- DIO=1; //設置為輸入
- for(i=0;i<8;i++)
- temp>>=1;
- CLK=0;
- if(DIO)
- temp|=0x80;
- CLK=1;
- return temp;
- void Write_COM(unsigned char cmd) //發送命令字
- STB=0;
- TM1638_Write(cmd);
- STB=1;
- unsigned char Read_key(void)
- unsigned char c[4],i,key_value=0;
- STB=0;
- TM1638_Write(0x42); //讀鍵掃數據 命令
- for(i=0;i<4;i++)
- c[i]=TM1638_Read();
- STB=1; //4個字節數據合成一個字節
- for(i=0;i<4;i++)
- key_value|=c[i]<<i;
- for(i=0;i<8;i++)
- if((0x01<<i)==key_value)
- break;
- return i;
- void Write_DATA(unsigned char add,unsigned char DATA) //指定地址寫入數據
- Write_COM(0x44);
- STB=0;
- TM1638_Write(0xc0|add);
- TM1638_Write(DATA);
- STB=1;
- void Write_oneLED(unsigned char num,unsigned char flag) //單獨控制一個LED函數,num為需要控制的led序號,flag為0時熄滅,不為0時點亮
- if(flag)
- Write_DATA(2*num+1,1);
- else
- Write_DATA(2*num+1,0);
- void Write_allLED(unsigned char LED_flag) //控制全部LED函數,LED_flag表示各個LED狀態
- unsigned char i;
- for(i=0;i<8;i++)
- if(LED_flag&(1<<i))
- //Write_DATA(2*i+1,3);
- Write_DATA(2*i+1,1);
- else
- Write_DATA(2*i+1,0);
- //TM1638初始化函數
- void init_TM1638(void)
- unsigned char i;
- Write_COM(0x8b); //亮度 (0x88-0x8f)8級亮度可調
- Write_COM(0x40); //采用地址自動加1
- STB=0; //
- TM1638_Write(0xc0); //設置起始地址
- for(i=0;i<16;i++) //傳送16個字節的數據
- TM1638_Write(0x00);
- STB=1;
- #endif
TM1638.DLL文件要放到MODELS目錄里面才能仿真,還有LIBRARY目錄的文件也要放進去,要用Proteus7.8版本:
TM1638C51仿真和程序.zip
(86.13 KB, 下載次數: 216)
2020-7-23 14:10 上傳
點擊文件名下載附件
