查看: 5479|回復: 5
STM32F103C8T6驅動WS2812B源程序
ID:98798 發表于 2020-7-30 08:44 | 顯示全部樓層 |閱讀模式
void Timer2_init(void)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  DMA_InitTypeDef DMA_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        /* GPIOA Configuration: TIM2 Channel 1 as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
        /* Compute the prescaler value */
        //PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
        /* Time base configuration */
        TIM_TimeBaseStructure.TIM_Period = 90-1; // 800kHz
        TIM_TimeBaseStructure.TIM_Prescaler = 0;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
        /* PWM1 Mode configuration: Channel1 */
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_Pulse = 0;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
        TIM_OC1Init(TIM2, &TIM_OCInitStructure);
        /* configure DMA */
        /* DMA clock enable */
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
        /* DMA1 Channel6 Config */
        DMA_DeInit(DMA1_Channel2);
        DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)TIM2_CCR1_Address;        // physical address of Timer 3 CCR1
        DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)LED_BYTE_Buffer;                // this is the buffer memory
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;                                                // data shifted from memory to peripheral
        DMA_InitStructure.DMA_BufferSize = 42;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                                        // automatically increase buffer index
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;                                                        // stop DMA feed after buffer size is reached
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
        DMA_Init(DMA1_Channel2, &DMA_InitStructure);
                /* TIM3 CC1 DMA Request enable */
        TIM_DMACmd(TIM2, TIM_DMA_Update, ENABLE);
void WS2812_send(uint8_t (*color)[3], uint16_t len)
        uint8_t i;
        uint16_t memaddr;
        uint16_t buffersize;
        buffersize = (len*24)+43;        // number of bytes needed is #LEDs * 24 bytes + 42 trailing bytes
        memaddr = 0;                                // reset buffer memory index
        while (len)
                                for(i=0; i<8; i++) // GREEN data
                                        LED_BYTE_Buffer[memaddr] = ((color[0][1]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
                                        memaddr++;
                        for(i=0; i<8; i++) // RED
                                        LED_BYTE_Buffer[memaddr] = ((color[0][0]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
                                        memaddr++;
                        for(i=0; i<8; i++) // BLUE
                                        LED_BYTE_Buffer[memaddr] = ((color[0][2]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
                                        memaddr++;
                  len--;
//bug:最后一個周期波形不知道為什么全是高電平,故增加一個波形
          LED_BYTE_Buffer[memaddr] = ((color[0][2]<<8) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
          memaddr++;
                while(memaddr < buffersize)
                        LED_BYTE_Buffer[memaddr] = 0;
                        memaddr++;
                DMA_SetCurrDataCounter(DMA1_Channel2, buffersize);         // load number of bytes to be transferred
                DMA_Cmd(DMA1_Channel2, ENABLE);                         // enable DMA channel 6
                TIM_Cmd(TIM2, ENABLE);                                                 // enable Timer 3
                while(!DMA_GetFlagStatus(DMA1_FLAG_TC2)) ;         // wait until transfer complete
                TIM_Cmd(TIM2, DISABLE);         // disable Timer 3
                DMA_Cmd(DMA1_Channel2, DISABLE);                         // disable DMA channel 6
                DMA_ClearFlag(DMA1_FLAG_TC2);                                 // clear DMA1 Channel 6 transfer complete flag
int main(void)
        delay_init();            //延時函數初始化
        LED_Init();                          //初始化與LED連接的硬件接口
  Timer2_init();
                WS2812_send(r,10);
                delay_ms(1000);
                WS2812_send(g,10);
                delay_ms(1000);
                WS2812_send(b,10);
                delay_ms(1000);
STM32F103C8T6驅動WS2812B.7z
184.38 KB, 下載次數: 240, 下載積分: 黑幣 -5
ID:87063 發表于 2021-6-5 14:00 | 顯示全部樓層
親測   這個程序有個bug 只能驅動61個led 再多一個就不行了
ID:455905 發表于 2021-6-24 09:01 | 顯示全部樓層
PA0為什么是DMA通道2,定時器TM2_CH1不是DMA通道5嗎
ID:455905 發表于 2021-6-24 09:03 | 顯示全部樓層
為什么是DMA通道2,TIM2_CH1對應不是DMA通道5嗎
ID:986209 發表于 2021-11-30 00:42 | 顯示全部樓層
親測可以點亮燈珠uint16_t len設置成60,只有30個燈珠亮,不知道為什么
ID:1041297 發表于 2025-4-9 15:55 | 顯示全部樓層
小魚仔1111 發表于 2021-6-24 09:01
我也很奇怪,換個IO口就配不出來了
主站蜘蛛池模板: 美女福利视频 | 四虎影视在线播放 | 国产成人综合网 | 天天摸天天干 | 欧美123区| 能看的av网站 | 性色av蜜臀av浪潮av老女人 | 躁躁躁日日躁 | av片免费 | av在线播放网站 | 69精品人人人人 | 亚洲福利网站 | 欧美mv日韩mv国产网站 | 毛片一级片| 在线观看日韩 | av免费观看网站 | 日本少妇中文字幕 | 四虎黄色影院 | 丁香花在线观看 | 国产性色av | 国产一区二区免费看 | 国产欧美精品一区二区 | 精品亚洲一区二区 | 成人一区二区三区 | 久久久精品国产sm调教网站 | 香蕉久久久 | 免费国产精品视频 | 免费看av的网址 | 日本公妇乱偷中文字幕 | 九九热这里有精品 | 国产高清视频 | 欧美一区二区三区四区五区 | www.一级片| 亚洲专区在线 | 久久国产欧美 | 91精品一区 | 欧美国产视频 | 成年人的免费视频 | 少妇一级片 | 国产寡妇亲子伦一区二区三区四区 | 欧美激情视频一区二区三区 |
