查看: 7418|回復: 3
Proteus8.9 GCC編譯器仿真RtThread RealTime STM32F401VE_系列002_動態線程跑馬燈
ID:371233 發表于 2020-8-7 22:32 | 顯示全部樓層 |閱讀模式
本帖最后由 kaillen 于 2020-8-7 23:32 編輯
一,打開文件(可以隨文下載放置在文檔中打開)。(如下圖1所示)
圖1
二,調整原理圖大小,適合可視,另存工程文件。(如下圖2,3,4所示)
圖2
圖3
圖4
三,點擊Source Code標簽。(如下圖5所示)
圖5
四,編輯main.c Proteus8.9 VSM Studio GCC編譯器仿真RtThread RealTime STM32F103R6_系列002_動態線程跑馬燈 (如下圖6所示)
五,Main.c 代碼:
/* Main.c file generated by New Project wizard
* Author:   Ziegler Yin
* Created:   周四 一月 16 2020
* Processor: STM32F407ZGT6ZGT6
* Compiler:  GCC for ARM
#include "mfuncs.h"
#include "delay.h"
#include "usart.h"
#include "sys.h"
#include <rtthread.h>
#define LED0 PCout(0)
#define LED1 PCout(1)
#define LED2 PCout(2)
#ifndef RT_USING_HEAP
        static struct rt_thread led_thread;
        static char led_thread_stack[256];
#else
        static rt_thread_t led_thread;
#endif
static void MX_GPIO_Init(void)
          GPIO_InitTypeDef  GPIO_InitStructure;
          RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);//使能GPIOF時鐘
          //GPIOF9,F10初始化設置
          GPIO_InitStructure.GPIO_Pin= GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2;//LED對應引腳
          GPIO_InitStructure.GPIO_Mode= GPIO_Mode_OUT;//普通輸出模式
          GPIO_InitStructure.GPIO_OType= GPIO_OType_PP;//推挽輸出
          GPIO_InitStructure.GPIO_Speed= GPIO_Speed_100MHz;//100MHz
          GPIO_InitStructure.GPIO_PuPd= GPIO_PuPd_UP;//上拉
          GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化
                LED0= 0;
                LED1= 1;
static void led_thread_entry(void * parameter) {
        while(1) {
                LED0= ~LED0;
                LED1= ~LED1;
                uprint("控制芯片STM32F401VE_RtThread RealTime_跑馬燈仿真開始了。\r\n");
                rt_thread_mdelay(500);
int main(void)
        delay_init(84);  //初始化延時函數
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設置系統中斷優先級分組2
        uart_init(9600);//初始化串口波特率為115200
    MX_GPIO_Init();
                        rt_err_t rst;
                        rst= rt_thread_init(&led_thread,
        "ledshine",
        led_thread_entry,
        RT_NULL,
        &led_thread_stack[0],
        sizeof(led_thread_stack),
        RT_THREAD_PRIORITY_MAX - 2,
        20);
                        if(rst== RT_EOK) {
                                rt_thread_startup(&led_thread);
                #else
                        led_thread= rt_thread_create("ledshine",
        led_thread_entry,
        RT_NULL,
        256,
        20);
                        if(led_thread!= RT_NULL) {
                                rt_thread_startup(led_thread);
                #endif
                 while(1) {
                         rt_thread_mdelay(100);
六,點擊構建工程按鈕,編譯工程。(如下圖6所示)
圖6
七,點擊窗口左下方仿真按鈕,可見虛擬LED顯示。 (如下圖7,8,9所示)
圖7
圖8
圖9
八,選擇release,點擊構建工程按鈕,編譯工程生成Hex文件。(如下圖10所示)
圖10
附件Proteus8.9 VSM Studio GCC編譯器仿真RtThread RealTime STM32F401VE_系列002_動態線程跑馬燈在已安裝Proteus8.9的計算機文件夾中打開即可
需要進一步了解,請加入QQ群:976235464
RtThread_GCC_F401VE_002_動態線程_跑馬燈02pt.rar
425 KB, 下載次數: 40, 下載積分: 黑幣 -5
ID:64019 發表于 2022-5-4 08:52 | 顯示全部樓層
仿真提示錯誤
ID:228452 發表于 2022-5-8 16:33 | 顯示全部樓層
No source code , no .elf ,no .hex  only Proteus ?
ID:228452 發表于 2022-5-8 17:31 | 顯示全部樓層
oops
click the Source Code tab. As shown in Figure 5
Thank you for the project
主站蜘蛛池模板: 国产69精品久久久久久 | 欧美黄色一级 | 欧美一区二区在线播放 | 成人免费福利 | 午夜激情福利视频 | 欧美激情在线观看 | 国产精品美女久久久久久久久 | 色婷婷国产 | 国产成人精品网站 | 99精品网站 | 日韩伦理视频 | 99热综合 | 国产免费无遮挡 | 国产资源在线播放 | 国内精品国产成人国产三级 | aaa国产精品 | 中文字幕在线观看一区 | 欧美大白屁股 | 黄色一级免费看 | 亚洲国产日韩在线 | 不卡中文字幕 | 小sao货撅起屁股扒开c微博 | 美女毛片视频 | 国产一级在线观看 | 黄a视频 | 日本成人精品 | 欧美精品一区在线观看 | 91免费国产 | 中文字幕av一区二区三区 | 亚洲成人精品 | 欧美一级色 | 黄色网址在线播放 | 国产精品成人一区二区三区 | 一区在线观看视频 | 亚洲激情中文字幕 | 精品欧美一区二区精品久久 | 亚洲成人免费在线观看 | 色播av | 一级片观看 | 黄色激情视频在线观看 | 欧美精品99久久久 |
