查看: 4994|回復: 3
51單片機波形發生器設計 LCD12864(代碼+proteus仿真圖)
最近做設計的成果,參考了一些資料;
波形發生器包含正弦波、方波、鋸齒波、三角波;
可通過按鍵改變波形和頻率;
示波器可觀察到波形,LCD12864上顯示波形和頻率。
仿真圖和代碼全在壓縮包里了。
  1. #include <reg52.h>
  2. #include <math.h>
  3. #include <intrins.h>
  4. #include <lcd12864.h>
  5. #define DAC_OUT        P2
  6. sbit change_wave=P3^2;               //改變波形按鍵
  7. sbit change_rate=P3^3;               //改變頻率按鍵
  8. uchar mode=0,rate=0,delay_time=0,k,p; //為波形發生模塊提供中間變量
  9. uchar *which_wave,*which_wave2;
  10. uint rate_num;
  11. uchar code Sine_wave[64]=                                    //DA輸出對應電壓值對應的數字量,正弦波
  12. {
  13.     128,114,102,90,78,66,55,45,36,28,20,14,9,5,2,1,1,1,
  14.     3,7,11,17,24,32,41,50,61,72,84,96,108,121,133,146,
  15.     158,170,182,193,204,213,222,230,237,243,247,251,253,
  16.     254,254,252,249,245,240,234,226,218,209,199,188,176,
  17.     167,158,145,135
  18. };
  19. uchar code Sawtooth_Wave[64]=                                //鋸齒波
  20. {
  21.     255,251,247,243,239,235,231,227,223,219,215,210,206,202,
  22.     198,194,190,186,182,178,174,170,166,162,158,154,150,146,
  23.     142,138,134,130,125,121,117,113,109,105,101,97,93,89,85,
  24.     81,77,73,69,61,57,53,49,45,40,36,32,28,24,20,16,12,8,4,0
  25. };
  26. uchar code Square_wave[64]=                                  //方波
  27. {
  28.     0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
  29.     0,0,0,0,255,255,255,255,255,255,255,255,255,255,255,255,
  30.     255,255,255,255,255,255,255,255,255,255,255,255,255,255,
  31.     255,255,255,255,255,255,
  32. };
  33. uchar code Triangular_Wave[64]=                              //三角波
  34. {
  35.     0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,
  36.     144,152,160,168,176,184,192,200,208,216,224,232,240,248,
  37.     248,240,232,224,216,208,200,192,184,176,168,160,152,144,
  38.     136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
  39. };
  40. void wave_delay()                         //波形延時函數
  41. {
  42.     int a,b;
  43.     for(a=1; a>0; a--)
  44.         for(b=122; b>0; b--);
  45. }
  46. void wave_init()             //波形發生模塊的初始化(外部中斷0、1)
  47. {
  48.     EA=1;
  49.     IT0=1;             //下降沿觸發
  50.     EX0=1;
  51.     IT1=1;
  52.     EX1=1;
  53. }
  54. void disp_wave(uchar *wave)   //顯示波形函數
  55. {
  56.     uchar page,i;
  57.     uint date;
  58.     select(1);        //選擇左屏
  59.     for(i=32; i<64; i++)
  60.     {
  61.         page=7-(wave[i]/4)/8;
  62.         date=7-(wave[i]/4)%8;
  63.         date=pow(2,date);
  64.         setpos(page,i);                                //選擇行列
  65.         lcd_wdat(date);
  66.     }
  67.     select(2);        //選擇右屏
  68.     for(i=0; i<64; i++)
  69.     {
  70.         page=7-(wave[i]/4)/8;
  71.         date=7-(wave[i]/4)%8;
  72.         date=pow(2,date);
  73.         setpos(page,i);                                //選擇行列
  74.         lcd_wdat(date);
  75.     }
  76. }
  77. void main()
  78. {
  79.     lcd_init();
  80.     clr_screen();
  81.     which_wave=&Sine_wave[0];
  82.     disp_chinese();
  83.     disp_function(chinese_sine);
  84.     disp_rate(400);
  85.     disp_xy();
  86.     disp_wave(which_wave);
  87.     wave_init();
  88.     while(1)
  89.     {
  90.         delay_time=rate;            //rate=0時,12mhz下,為400hz的波形。循環一次的時間為0.00025ms
  91.         DAC_OUT=*(which_wave+k);
  92.         k++;
  93.         if(k==64)
  94.             k=0;
  95.         while(delay_time)
  96.             delay_time--;
  97.     }
  98. }
  99. void int0() interrupt 0    //波形選擇中斷服務程序
  100. {
  101.     EX0=0;
  102.     wave_delay();
  103.     mode++;
  104.     if(mode==4)
  105.         mode=0;
  106.     switch(mode)
  107.     {
  108.     case 0 :        //顯示正弦波
  109.         which_wave=&Sine_wave[0];
  110.         which_wave2=&chinese_sine[0];
  111.         break;
  112.     case 1 :        //顯示三角波
  113.         which_wave=&Triangular_Wave[0];
  114.         which_wave2=&chinese_triangular[0];
  115.         break;
  116.     case 2 :        //顯示方波
  117.         which_wave=&Square_wave[0];
  118.         which_wave2=&chinese_square[0];
  119.         break;
  120.     case 3 :        //顯示鋸齒波
  121.         which_wave=&Sawtooth_Wave[0];
  122.         which_wave2=&chinese_sawtooth[0];
  123.         break;
  124.     }
  125.     wave_delay();
  126.     clr_screen();
  127.     disp_chinese();
  128.     disp_rate(400/rate);
  129.     disp_function(which_wave2);
  130.     disp_xy();
  131.     disp_wave(which_wave);
  132.     while(!change_wave);
  133.     EX0=1;
  134. }
  135. void int1() interrupt 2       //頻率選擇
  136. {
  137.     EX1=0;
  138.     wave_delay();
  139.     p++;
  140.     if(p==50)
  141.         p=0;
  142.     rate=p;
  143.     wave_delay();
  144.     rate_num=1/((0.000036+0.000006*rate)*64);
  145.     clc_rate();
  146.     disp_rate(rate_num);
  147.     while(!change_rate);
  148.     EX1=1;
  149. }
所有資料51hei提供下載(內含Proteus8.8仿真圖與代碼):
單片機51hei設計.zip (145.89 KB, 下載次數: 171)
收藏收藏6 分享淘帖 頂1 踩
ID:862092 發表于 2020-12-17 13:49 | 只看該作者
這個每個周期的采樣點是64個嗎
ID:862092 發表于 2020-12-17 19:30 | 只看該作者
jjjfff 發表于 2020-12-17 13:49
這個每個周期的采樣點是64個嗎
然后這個的頻率最大是400Hz嗎,如果想要調整到1kHz改怎么操作呢
ID:1153792 發表于 2025-6-12 20:47 | 只看該作者
66666666666666
主站蜘蛛池模板: 欧美综合一区二区三区 | 五月天激情综合网 | 女同久久另类99精品国产 | 中文字幕在线视频一区二区三区 | 久久99精品国产99久久6男男 | 日韩免费一区二区 | 精品一区二区三区四区外站 | 麻豆精品国产91久久久久久 | 天天综合网7799精品 | 亚洲视频免费播放 | 国产a视频| 中文字幕在线三区 | 欧美一区二区久久 | 日韩中文久久 | 成人精品一区二区三区中文字幕 | 性做久久久久久免费观看欧美 | 国产91av视频在线观看 | 一区二区免费在线视频 | 久久成人精品一区二区三区 | www.天天操 | 中文字幕日韩一区 | 久久久高清| 天天看片天天干 | 欧美一区二区精品 | 国产高清视频 | 波多野结衣在线观看一区二区三区 | 岛国av在线免费观看 | 中文字幕在线一区 | 久久精品a级毛片 | 殴美黄色录像 | 在线视频中文字幕 | 精精国产xxxx视频在线野外 | 一区视频在线 | 国产欧美一区二区在线观看 | 欧美在线视频一区 | 久久综合一区二区三区 | 国产精品一区二区欧美 | 亚洲国产精品福利 | 91免费在线 | 久久999 | 日本午夜免费福利视频 |
