查看: 3653|回復: 2
51單片機12864顯示漢字源程序
ID:747099 發表于 2020-10-5 17:22 | 顯示全部樓層 |閱讀模式
#include <reg51.h>
#define LCDLCDDisp_Off   0x3e
#define LCDLCDDisp_On    0x3f
#define Page_Add         0xb8
#define LCDCol_Add       0x40
#define Start_Line       0xC0
#define data_ora P0
sbit LCD_CS1=P2^4 ;
sbit LCD_CS2=P2^3 ;
sbit RESET=P2^3 ;
sbit LCDDi=P2^2 ;
sbit LCDRW=P2^1 ;
sbit LCDEnable=P2^0 ;
char code Hz_sun[]=
0x0 ,0x2 ,0x82 ,0x82, 0xF2, 0x4A, 0x26, 0x80 ,0x60, 0x0 ,0xFF, 0x20 ,0x40 ,0x80 ,0x0 ,
        0x0 ,0x1, 0x1 ,0x40, 0x80, 0x7F ,0x4 ,0x2 ,0x1 ,0x40, 0x80, 0x7F, 0x0 ,0x0 ,0x1 ,0x3 ,0x0
char code Hz_wen[]=
0x8, 0x8 ,0x8, 0x18, 0x68, 0x88, 0x9, 0xE ,0x8, 0x8 ,0xC8, 0x38, 0x8 ,0xC, 0x8 ,0x0, 0x80,
        0x80 ,0x40, 0x40, 0x20, 0x11, 0xA ,0x4, 0xA ,0x11 ,0x10, 0x20, 0x40, 0xC0, 0x40, 0x0
char code Hz_chao[]=
0x40, 0x48, 0x48, 0xFF ,0x48 ,0x48, 0x82 ,0x42, 0x3E, 0x2 ,0x22, 0x42, 0x3F ,0x2, 0x0, 0x0 ,0x40,
        0x3F ,0x10, 0x1F ,0x22 ,0x42, 0x40, 0x5F, 0x51, 0x51 ,0x51, 0x51 ,0x5F, 0x60, 0x20, 0x0
char code Hz_zhen[]=
0x0 ,0x4, 0x4, 0xF4, 0x54 ,0x54, 0x54, 0x5F ,0x54 ,0x54 ,0x54, 0xFC, 0x16 ,0x4, 0x0, 0x0, 0x10 ,0x10 ,
        0x90 ,0x5F, 0x35 ,0x15, 0x15, 0x15 ,0x15 ,0x15, 0x35 ,0x5F, 0xD0, 0x18, 0x10, 0x0
char code Hz_shuai[]=
0x0 ,0xFC ,0x0, 0x0, 0xFF, 0x0 ,0x0, 0xF8 ,0x8, 0x8, 0xFF, 0x8, 0x8, 0xFC ,0x8, 0x0, 0x0 ,0x87, 0x40,
        0x30 ,0xF, 0x0, 0x0, 0x3F ,0x0 ,0x0 ,0xFF, 0x10 ,0x20, 0x1F, 0x0 ,0x0
char code Hz_te[]=
0x20 ,0x1C ,0x10 ,0xFF, 0x90, 0x50, 0x48, 0x48, 0x48, 0x7F ,0x48 ,0xC8, 0x4C, 0x68, 0x40, 0x0, 0x2,
        0x2 ,0x1, 0xFF, 0x0, 0x2 ,0x2 ,0x6 ,0x1A ,0x42, 0x82 ,0x7F, 0x2 ,0x3 ,0x2 ,0x0
char code Hz_mo[]=
0x0 ,0x4 ,0x4, 0xE4 ,0xA4 ,0xBF, 0xA4 ,0xA4, 0xA4, 0xBF, 0xA4 ,0xF4, 0x26 ,0x4 ,0x0 ,0x0 ,0x8 ,
        0x88 ,0x88 ,0x8B, 0x4A ,0x4A ,0x2A ,0x1E, 0x2A, 0x4A, 0x4A, 0x8B ,0x88, 0x8C, 0x8, 0x0
char code Hz_a[]=
0xFC ,0x4 ,0xFE ,0x4, 0xFE ,0x42, 0xB2 ,0xE, 0x0, 0xE2 ,0x22 ,0xF2, 0x22, 0xFF, 0x2, 0x0 ,0xF ,
        0x4 ,0xF ,0x0 ,0xFF ,0x8 ,0x11 ,0xE,0x0, 0xF, 0x4 ,0x4F, 0x80 ,0xFF ,0x0, 0x0
void LCDdelay(unsigned int t)
        unsigned int i,j;
        for(i=0;i<t;i++);
        for(j=0;j<10;j++);
void CheckState()
   unsigned char dat,DATA;
   LCDDi=0;
   LCDRW=1;
   do
      DATA=0x00;
      LCDEnable=1;
          LCDdelay(2);
          dat=DATA;
      LCDEnable=0;
      dat=0x80 & dat;
    while(dat!=0x00);
void write_com(unsigned char cmdcode)
    CheckState();
        LCDDi=0;
        LCDRW=0;
        P1=cmdcode;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
void write_data(unsigned char LCDDispdata)
    CheckState();
        LCDDi=1;
        LCDRW=0;
        P1=LCDDispdata;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
void Clr_Scr()
        unsigned char j,k;
        LCD_CS1=0;
        LCD_CS2=0;
         write_com(Page_Add+0);
         write_com(LCDCol_Add+0);
         for(k=0;k<8;k++)
                write_com(Page_Add+k);
                  for(j=0;j<64;j++)
                      write_com(LCDCol_Add+j);
                        write_data(0x00);
void hz_LCDDisp16(unsigned char page,unsigned char column, unsigned char code *hzk)
        unsigned char j=0,i=0;
        for(j=0;j<2;j++)
                write_com(Page_Add+page+j);
                write_com(LCDCol_Add+column);
                for(i=0;i<16;i++)
                        write_data(hzk[16*j+i]);
void init_lcd()
        LCDdelay(100);
        LCD_CS1=1;
        LCD_CS2=1;
        LCDdelay(100);
        write_com(LCDLCDDisp_Off);
        write_com(Start_Line+0);
        write_com(LCDLCDDisp_On);
全部資料51hei下載地址:
1.rar (446.7 KB, 下載次數: 63)
ID:830257 發表于 2020-11-24 19:01 | 顯示全部樓層
怎么修改字喲
ID:867005 發表于 2021-5-6 16:58 | 顯示全部樓層
生成字模,然后替換取模函數里的漢字內容
主站蜘蛛池模板: 91青青草 | 五月天婷婷丁香 | 黄av在线 | 欧美激情一区二区三区 | 91亚洲国产| 99视频在线精品免费观看2 | 亚洲天堂免费视频 | 三级黄网站 | 在线h片 | 蜜桃视频一区二区 | 日韩精品国产一区 | 国产精品主播一区二区 | 日韩黄色小视频 | 视色网| 国产精品成人国产乱一区 | 成人扒开伸进免费观看 | 97精品视频 | 免费网站av| 欧美二三区| 一级在线视频 | 91视频亚洲| 97人人艹 | 四虎影库 | 国产精品二 | 成人黄性视频 | 亚洲国产成人91精品 | 在线成人小视频 | 国产精品毛片va一区二区三区 | 91久久久久久久久久 | sm调教视频永久免费 | 免费久久 | 黄色网在线 | 超碰在线免费 | 国产一级视频在线观看 | 免费在线观看av | 在线免费看黄网站 | 久久99国产精品 | 亚洲精品无 | 精品黑人一区二区三区国语馆 | 日韩国产综合 | 亚洲综合区 |
