查看: 2311|回復: 1
stm32下 ,ad7171芯片調試筆記
ID:826132 發表于 2020-10-6 12:11 | 顯示全部樓層 |閱讀模式
最近在做一個項目,是使用AD芯片,采集一個電壓信號 ,使用了AD77171A芯片
程序從別的地方找了,參照改了下,代碼如下
  1. /********************************************************************************
  2. Author : Akshay Kumar B U (akshay.kumar@analog.com)
  3.                                         India Applications Support Team
  4. Date : December 2013
  5. File name : AD7171.c
  6. Description : This is an executable file containing all definitions of functions used for operating AD7171 in SPI mode.
  7. Hardware Platform : ADuCM360 + AD7171
  8. ********************************************************************************/
  9. /* ADuCM360 interface with AD7171
  10. SCLK                                - P1.1
  11. PDRST                                - P1.2
  12. DOUT/RDY                - P1.3
  13. */
  14. //引腳說明 ; AD7171_SCLK =  PBout(12), Read Data= Pb.6
  15. #include "ad7171.h"
  16. #include "led.h"
  17. #include "delay.h"
  18. // UART-based external variables
  19. u8 ucTxBufferEmpty  = 0;       // Used to indicate that the UART Tx buffer is empty
  20. u8 szTemp[64] = "";            // Used to store string before printing to UART
  21. u8 nLen = 0;
  22. u8 AD_i = 0;
  23. u8 ucWaitForUart = 0;          // Used by calibration routines to wait for user input
  24. //Initializing AD7171 to default settings
  25. void InitializeAD7171(void)
  26. {
  27.         AD7171_SCLK =0;
  28.         delay_us(1);                          // 100ns delay
  29.         delay_ms(1);    //1ms delay
  30. }
  31. void SpiFunction(u16 *InputBuf, u16 *OutputBuf, u16 NoOfBytes)
  32. {
  33. int i,j;
  34. u16 TempInput = 0x00;
  35. //unsigned int TempOutput = 0x00;
  36. u16        ReceivedBit = 0x00;
  37.         for(i=0; i< NoOfBytes; i++)
  38.         {
  39.                 //TempOutput = *OutputBuf;
  40.                 for(j=0; j<8; j++)
  41.                 {
  42.                                 ////////////WRITE DATA/////////////
  43.
  44.                         TempInput<<=1;
  45.
  46.                         AD7171_SCLK =0;//ADuCM360GpioOutput(AD7171_SCLK, PIN_LOW);
  47.                         delay_us(1);//Delay(100);
  48.                         AD7171_SCLK =1;
  49.                         delay_us(1);//Delay(100);
  50.
  51.                 //if(0x80==(TempOutput & 0x80))
  52.                 //        {
  53.                 //        ADuCM360GpioOutput(AD7171_SDIN, PIN_HIGH);
  54.                 //        }
  55.                 //        else
  56.                 //        {
  57.                 //                ADuCM360GpioOutput(AD7171_SDIN, PIN_LOW);
  58.                 //        }
  59.                 //  TempOutput<<=1;
  60.                 //        Delay(1);
  61.
  62.                         ////////////WRITE DATA ENDS/////////
  63.
  64.
  65.                         ///////////READ DATA///////
  66.
  67.                         ReceivedBit = PBin(6);//ADuCM360GpioInput(AD7171_DOUTRDY);
  68.                                 if(0x1==ReceivedBit)
  69.                                         {
  70.                                                 TempInput |= 1;
  71.                                         }
  72.
  73.                         ////////////READ DATA ENDS/////////
  74.
  75.                 }
  76.                 *InputBuf = TempInput;
  77.                 OutputBuf++;
  78.                 InputBuf++;
  79.
  80.         }
  81.
  82.         AD7171_SCLK =1;//ADuCM360GpioOutput(AD7171_SCLK, PIN_HIGH);
  83.         delay_us(1);//Delay(100);
  84. }
  85. void SpiFunction2(u16 *InputBuf, u16 *OutputBuf, u16 NoOfBytes)
  86. {
  87. int i,j;
  88. u16 TempInput = 0x00;
  89. //unsigned int TempOutput = 0x00;
  90. u16        ReceivedBit = 0x00;
  91.         for(i=0; i< NoOfBytes; i++)
  92.         {
  93.                 //TempOutput = *OutputBuf;
  94.                 for(j=0; j<8; j++)
  95.                 {
  96.                         TempInput<<=1;
  97.                         AD7171_SCLK =0;//ADuCM360GpioOutput(AD7171_SCLK, PIN_LOW);
  98.                         delay_us(1);//Delay(100);
  99.                         ReceivedBit = PBin(6);//ADuCM360GpioInput(AD7171_DOUTRDY);
  100.                                 if(0x1==ReceivedBit)
  101.                                         {
  102.                                                 TempInput |= 1;
  103.                                         }
  104.       AD7171_SCLK =1;
  105.                         delay_us(1);//Delay(100);
  106.
  107.                 }
  108.                 /*
  109.
  110.         for (i = 0; i < 16; i++)
  111.         {
  112.                 SCLK = 0;
  113.                 usData = usData << 1;
  114.                 usData |= DAT;
  115.                 SCLK = 1;
  116.         }
  117.
  118.                 */
  119.                 *InputBuf = TempInput;
  120.                 OutputBuf++;
  121.                 InputBuf++;
  122.         }
  123.
  124.         AD7171_SCLK =1;//ADuCM360GpioOutput(AD7171_SCLK, PIN_HIGH);
  125.         delay_us(1);//Delay(100);
  126. }
  127. //Function to Read data from AD7171
  128. u16 ReadFromAD7171(void)
  129. {
  130.         u16 ready = 0x000001;
  131.         u16 DataReg = 0x000000;
  132.         u16 InputRegister[10];
  133.         u16 OutputRegister[10];
  134.         u16 StatusBar = 0x00;
  135.         int i=0;
  136.                 AD7171_SCLK =1; //ADuCM360GpioOutput  (AD7171_SCLK, PIN_HIGH);
  137.
  138.                 while(ready)                                              // Waits untill the DOUT/RDY pin goes low to indicate
  139.                 {                                                   // data is converted and is ready to be read.
  140.                         ready = PBin(6);//ADuCM360GpioInput (AD7171_DOUTRDY);
  141.                 }
  142.                 delay_ms(1);//Delay(1000);
  143.
  144.                 SpiFunction2(InputRegister, OutputRegister, NoOfByte);                                   //SPI read write
  145.                         for(i=0; i<2; i++)
  146.         {
  147.                                         DataReg        <<= 8;
  148.                                         DataReg |= InputRegister[i];
  149.                                 }
  150.
  151.                          StatusBar = (InputRegister[2] & 0x0000FF);
  152.
  153. //                ErrorCheck(InputRegister[2]);    // Performs Error Check in AD7171 Received Data. 'ErrorBit' is set to 1 if any error is present.
  154.     delay_us(1);
  155.
  156.                 do
  157.                 {
  158.                         ready = PBin(6);//ADuCM360GpioInput  (AD7171_DOUTRDY);
  159.                 }        while(ready != 0x01);
  160.     return DataReg;
  161.
  162. }
  163. /*
  164. // Performs Error Check in the received data
  165. void ErrorCheck(unsigned int Status)
  166. {
  167.         if(0x20 ==(Status & 0x20))
  168.     {
  169.               InitializeAD7171();             //Initializes the AD7171 device when the Error bit is set
  170.        //or when the pattern bits PAT2,PAT1 and PAT0 are not equal to 101
  171.                                                    //or when ID bits ID1 and ID0 are not equal to 01.
  172. //                                   sprintf ( (char*)szTemp, "Error Present as Error Bit in Status Register is set high \r\n");
  173. //                   nLen = strlen((char*)szTemp);
  174.                    if (nLen <64)
  175.                                  SendString();
  176.           }
  177.         if (0x05 != (Status & 0x05))
  178.                 {
  179.                         InitializeAD7171();
  180. //                    sprintf ( (char*)szTemp, "Error due to mismatch in Pattern Bits \r\n");
  181. //                   nLen = strlen((char*)szTemp);
  182.                    if (nLen <64)
  183.                                  SendString();
  184.           }
  185.         if (0x08 != (Status & 0x08))
  186.                 {
  187.                         InitializeAD7171();
  188. //                    sprintf ( (char*)szTemp, "Error due to mismatch in ID bits of Status Bar \r\n");
  189. //                   nLen = strlen((char*)szTemp);
  190.                    if (nLen <64)
  191.                                  SendString();
  192.           }
  193.         else if (0x0D ==(Status & 0x0D))
  194.                 {
  195. //                        sprintf ( (char*)szTemp, "No Error \r\n");
  196. //                   nLen = strlen((char*)szTemp);
  197.                    if (nLen <64)
  198.                                  SendString();
  199.                 }
  200. }
  201. */
但是發現讀到的數值 ,算出的結果,比實際的值要小些,還沒找到問題
ID:826132 發表于 2020-10-6 12:13 | 顯示全部樓層
首次發貼,自己頂下。
主站蜘蛛池模板: www.亚洲天堂 | 国内精品视频在线观看 | 天天躁日日躁狠狠躁av麻豆男男 | 国产免费自拍视频 | 久久99精品久久久久久琪琪 | 午夜影院在线观看视频 | 欧美理论片在线观看 | 国产精品一级二级 | 久久综合五月天 | 国产精品理论片 | 欧美日韩一区二区三区视频 | 日韩不卡在线 | 欧美日韩综合在线 | 黄色免费毛片 | 日本免费一级片 | 黄色成人免费网站 | 成人免费毛片网站 | 久久久久久国产 | 成人精品国产 | 久久国产99 | 精品国产一区二 | 欧美色综合网 | 91网站免费 | 亚洲午夜精品一区二区三区 | 9191av| 欧美视频一区二区三区 | 亚洲欧美在线观看视频 | 亚洲性天堂| 日韩精品不卡 | 三级在线观看视频 | 久久国产成人 | 欧美九九九 | 99视频网站 | 天天干干干 | 国产欧美综合一区二区三区 | 97在线视频观看 | 国产一级特黄 | 久久精品视频免费 | 日日操av | 国产精品成人国产乱一区 | 五月婷婷激情 |
