查看: 2850|回復(fù): 1
Proteus8.10 VSM Studio python編譯器仿真Raspberry_系列_43_ili9341
ID:371233 發(fā)表于 2020-10-15 01:42 | 顯示全部樓層 |閱讀模式
一,打開文件(可以隨文下載放置在文檔中打開)。(如下圖1所示)
圖1
二,調(diào)整原理圖大小,適合可視,另存工程文件。(如下圖2,3,4所示)
圖2
圖3
圖4
三,點(diǎn)擊Source Code標(biāo)簽。(如下圖5所示)
圖5
四,編輯main.py Proteus8.10 VSM Studio python編譯器仿真Raspberry_系列_43_ili9341 (如下圖6所示)
五,Main.py 代碼:
# !/usr/bin/env python3
# Generated by Proteus Visual Designer for Raspberry Pi
# Modules
from goto import with_goto
from stddef import *
import var
import pio
import resource
from datetime import datetime
# Peripheral Configuration Code (Do Not Edit)
#---CONFIG_BEGIN---
import cpu
import FileStore
import VFP
import Displays
def peripheral_setup () :
# Peripheral Constructors
pio.cpu=cpu.CPU ()
pio.storage=FileStore.FileStore ()
pio.server=VFP.VfpServer ()
pio.LCD1=Displays.TFTDisplay (pio.GPIO18, pio.GPIO23)
pio.storage.begin ()
pio.server.begin (0)
# Install interrupt handlers
def peripheral_loop () :
pass
#---CONFIG_END---
def variables_setup () :
# Flowchart Variables
var.file = None
# Flowchart Routines
@with_goto
def chart_Init () :
pio.LCD1.setFill (255, 0, 0)
pio.LCD1.drawCircle (150, 150, 50)
pio.LCD1.setFill (0, 0, 255)
pio.LCD1.drawEllipses (80, 100, 20, 40)
pio.LCD1.newPolygon (10, 10)
pio.LCD1.addPolygonPoint (30, 10)
pio.LCD1.addPolygonPoint (30, 30)
pio.LCD1.addPolygonPoint (10, 30)
pio.LCD1.addPolygonPoint (0, 20)
pio.LCD1.drawPolygon ()
pio.LCD1.setFill (0, 200, 0)
pio.LCD1.drawRectangle (20, 210, 100, 200)
return
@with_goto
def chart_Txts1 () :
pio.LCD1.setFill (255, 255, 0)
pio.LCD1.setTextFont (16, 0)
pio.LCD1.drawText ("Kaillen Workshop  ", 40, 10, 0)
sleep((3))
pio.LCD1.setFill (255, 0, 255)
pio.LCD1.drawText ("Welcome You!  ", 40, 32, 0)
sleep((3))
return
@with_goto
def chart_SETUP () :
pio.LCD1.clear ()
return
@with_goto
def chart_LOOP () :
pio.LCD1.setFill (200, 200, 200)
pio.LCD1.fillScreen ()
chart_Init ()
chart_Txts1 ()
pio.LCD1.clear ()
pio.LCD1.setFill (255, 255, 255)
chart_Init ()
chart_Tsts2 ()
pio.LCD1.clear ()
return
@with_goto
def chart_Tsts2 () :
pio.LCD1.setTextFont (18, 2)
pio.LCD1.drawText ("Code Made by:", 40, 10, 0)
sleep((100)*0.001)
pio.LCD1.setFill (0, 255, 255)
pio.LCD1.drawText (" --Ziegler Yin", 40, 32, 0)
sleep((3))
return
# Main function
def main () :
# Setup
variables_setup ()
peripheral_setup ()
chart_SETUP ()
# Infinite loop
while True :
  peripheral_loop ()
  chart_LOOP ()
# Command line execution
if __name__ == '__main__' :
   main()
六,點(diǎn)擊構(gòu)建工程按鈕,編譯工程。(如下圖6所示)
圖6
七,點(diǎn)擊窗口左下方仿真按鈕,可見虛擬LCD ili9341顯示。 (如下圖7,8,9所示)
圖7
圖8
圖9
八,選擇release,點(diǎn)擊構(gòu)建工程按鈕,編譯工程生成Hex文件。(如下圖10所示)
圖10
附件Proteus8.10 VSM Studio python編譯器仿真Raspberry_系列_43_ili9341在已安裝Proteus8.10的計(jì)算機(jī)文件夾中打開即可
需要進(jìn)一步了解,請(qǐng)加入QQ群:976235464
Raspberry_43_ili9341_LCD_01.rar
130.29 KB, 下載次數(shù): 19, 下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
ID:625395 發(fā)表于 2020-10-15 08:43 | 顯示全部樓層
樓主把你的電腦桌面截個(gè)圖發(fā)一下,學(xué)習(xí)一下你們平時(shí)都用到什么開發(fā)工具,謝謝。
主站蜘蛛池模板: 岛国精品在线播放 | 久久福利影院 | 国产一区二区三区在线 | 99精品成人 | 精品国产福利 | 97自拍视频 | 亚洲日本久久 | 黄色天堂 | 国产日本在线 | 久久在线免费视频 | 亚洲91精品 | 久久伊人影院 | 日韩av在线免费 | 国产精品国产三级国产 | 国产九九 | 激情视频网址 | 国产精品一级二级三级 | 国产特级黄色片 | 超碰av在线播放 | 精品免费在线观看 | 免费av片 | 中文字幕理伦片免费看 | 色综合视频在线观看 | 99精品视频免费观看 | 蜜桃视频一区二区三区 | 黑人精品xxx一区一二区 | 黄色在线播放 | 国产成人精品一区 | 欧美日韩视频在线 | 免费成人深夜夜国外 | 亚洲精品第一 | 国产精品美女久久 | 欧美日韩中文字幕在线观看 | 午夜成人在线视频 | 黄色大片在线播放 | 黄色网址在线免费观看 | 一级黄视频| 少妇av在线 | 中国av片| 在线国产91| 一区二区三区四区在线视频 |
