查看: 3174|回復: 1
Proteus8.10 VSM Studio python編譯器仿真Raspberry_系列_48_Remote_Light
ID:371233 發表于 2020-10-16 12:10 | 顯示全部樓層 |閱讀模式
一,打開文件(可以隨文下載放置在文檔中打開)。(如下圖1所示)
圖1
二,調整原理圖大小,適合可視,另存工程文件。(如下圖2,3,4所示)
圖2
圖3
圖4
三,點擊Source Code標簽。(如下圖5所示)
圖5
四,編輯main.py Proteus8.10 VSM Studio python編譯器仿真Raspberry_系列_48_Remote_Light (如下圖6所示)
五,Main.py 代碼:
# !/usr/bin/env python3
# Generated by Proteus Visual Designer for Raspberry Pi
# Modules
from goto import with_goto
from stddef import *
import var
import pio
import resource
from datetime import datetime
# Peripheral Configuration Code (Do Not Edit)
#---CONFIG_BEGIN---
import cpu
import FileStore
import VFP
import Ports
import Generic
import Controls
def peripheral_setup () :
# Peripheral Constructors
pio.cpu=cpu.CPU ()
pio.storage=FileStore.FileStore ()
pio.server=VFP.VfpServer ()
pio.uart=Ports.UART ()
pio.LED1=Generic.LED (pio.GPIO20)
pio.IotBtn1=Controls.PushButton ("IotBtn1", )
pio.IotLED1=Controls.Indicator ("IotLED1", )
pio.IotBtn2=Controls.PushButton ("IotBtn2", )
pio.storage.begin ()
pio.server.begin (0)
# Install interrupt handlers
pio.IotBtn1.attachEventHandler(chart_OnIotBtn1)
pio.IotBtn2.attachEventHandler(chart_OnIotBtn2)
def peripheral_loop () :
pass
#---CONFIG_END---
def variables_setup () :
# Flowchart Variables
pass
# Flowchart Routines
@with_goto
def chart_SETUP () :
pio.uart.setup (9600)
pio.uart.println ("Remote Light: \r\n")
return
@with_goto
def chart_LOOP () :
return
@with_goto
def chart_OnIotBtn1 () :
pio.IotLED1.setState (True)
pio.IotBtn1.setLamp (True)
pio.LED1.on ()
pio.uart.println ("Light on.")
return
@with_goto
def chart_OnIotBtn2 () :
pio.IotBtn1.setLamp (False)
pio.IotBtn2.setLamp (False)
pio.IotLED1.setState (False)
pio.uart.println ("Light off.")
return
# Main function
def main () :
# Setup
variables_setup ()
peripheral_setup ()
chart_SETUP ()
# Infinite loop
while True :
  peripheral_loop ()
  chart_LOOP ()
# Command line execution
if __name__ == '__main__' :
   main()
六,點擊構建工程按鈕,編譯工程。(如下圖6所示)
圖6
七,點擊窗口左下方仿真按鈕,可見虛擬LED Light顯示。 (如下圖7,8,9所示)
圖7
圖8
圖9
八,選擇release,點擊構建工程按鈕,編譯工程生成Hex文件。(如下圖10所示)
圖10
附件Proteus8.10 VSM Studio python編譯器仿真Raspberry_系列_48_Remote_Light在已安裝Proteus8.10的計算機文件夾中打開即可
需要進一步了解,請加入QQ群:976235464
Raspberry_48_Remote_Light01.rar
192.46 KB, 下載次數: 6, 下載積分: 黑幣 -5
ID:288629 發表于 2021-2-1 13:23 | 顯示全部樓層
謝謝樓主,下載好好學習下
主站蜘蛛池模板: 可以在线观看的av | 1级黄色片 | 在线日韩 | 欧美日韩在线一区二区三区 | 三上悠亚激情av一区二区三区 | 中文字幕在线观看免费视频 | 亚洲美女一区 | 亚洲一区二区av | 午夜免费观看视频 | 又黄又爽又色视频 | 天天摸天天操 | 国产自产21区 | 日韩精品在线免费观看 | 日韩城人网站 | www.超碰| 日本在线视频观看 | 狠狠干天天操 | 亚洲激情一区二区 | 欧美三级在线视频 | 国产日韩综合 | 黄色在线观看免费 | 一级片免费 | 欧美日视频 | 97人人艹 | 国产黄色免费网站 | 精品成人av | 日韩成人精品一区二区 | 国产欧美日韩在线 | 快播少女爱欢乐 | 久久精品综合 | 操操操干干干 | 成人激情视频在线观看 | av大片在线观看 | 日韩中文字幕第一页 | 深夜福利在线播放 | 欧美日韩中文 | 免费在线观看毛片 | 黄色一级视频 | 一级国产片 | 亚洲欧美日韩成人 | 精品一区二区三区视频 |
