STM32F103C8T6的FreeRtos工程。
帶部分中文注釋。希望可以幫組初學(xué)者。
單片機(jī)源程序如下:
- /* Standard includes. */
- #include <stdio.h>
- /* Scheduler includes. */
- #include "FreeRTOS.h"
- #include "task.h"
- #include "queue.h"
- /* Library includes. */
- #include "stm32f10x_it.h"
- /* Demo app includes. */
- #include "lcd.h"
- #include "LCD_Message.h"
- #include "BlockQ.h"
- #include "death.h"
- #include "integer.h"
- #include "blocktim.h"
- #include "partest.h"
- #include "semtest.h"
- #include "PollQ.h"
- #include "flash.h"
- #include "comtest2.h"
- /* Task priorities. */
- #define mainQUEUE_POLL_PRIORITY ( tskIDLE_PRIORITY + 2 )
- #define mainCHECK_TASK_PRIORITY ( tskIDLE_PRIORITY + 3 )
- #define mainSEM_TEST_PRIORITY ( tskIDLE_PRIORITY + 1 )
- #define mainBLOCK_Q_PRIORITY ( tskIDLE_PRIORITY + 2 )
- #define mainCREATOR_TASK_PRIORITY ( tskIDLE_PRIORITY + 3 )
- #define mainFLASH_TASK_PRIORITY ( tskIDLE_PRIORITY + 1 )
- #define mainCOM_TEST_PRIORITY ( tskIDLE_PRIORITY + 1 )
- #define mainINTEGER_TASK_PRIORITY ( tskIDLE_PRIORITY )
- /* Constants related to the LCD. */
- #define mainMAX_LINE ( 240 )
- #define mainROW_INCREMENT ( 24 )
- #define mainMAX_COLUMN ( 20 )
- #define mainCOLUMN_START ( 319 )
- #define mainCOLUMN_INCREMENT ( 16 )
- /* The maximum number of message that can be waiting for display at any one
- time. */
- #define mainLCD_QUEUE_SIZE ( 3 )
- /* The check task uses the sprintf function so requires a little more stack. */
- #define mainCHECK_TASK_STACK_SIZE ( configMINIMAL_STACK_SIZE + 50 )
- /* Dimensions the buffer into which the jitter time is written. */
- #define mainMAX_MSG_LEN 25
- /* The time between cycles of the 'check' task. */
- #define mainCHECK_DELAY ( ( TickType_t ) 5000 / portTICK_PERIOD_MS )
- /* The number of nano seconds between each processor clock. */
- #define mainNS_PER_CLOCK ( ( unsigned long ) ( ( 1.0 / ( double ) configCPU_CLOCK_HZ ) * 1000000000.0 ) )
- /* Baud rate used by the comtest tasks. */
- #define mainCOM_TEST_BAUD_RATE ( 115200 )
- /* The LED used by the comtest tasks. See the comtest.c file for more
- information. */
- #define mainCOM_TEST_LED ( 3 )
- * Configure the clocks, GPIO and other peripherals as required by the demo.
- static void prvSetupHardware( void );
- * Configure the LCD as required by the demo.
- static void prvConfigureLCD( void );
- * The LCD is written two by more than one task so is controlled by a
- * 'gatekeeper' task. This is the only task that is actually permitted to
- * access the LCD directly. Other tasks wanting to display a message send
- * the message to the gatekeeper.
- static void vLCDTask( void *pvParameters );
- * Retargets the C library printf function to the USART.
- int fputc( int ch, FILE *f );
- * Checks the status of all the demo tasks then prints a message to the
- * display. The message will be either PASS - and include in brackets the
- * maximum measured jitter time (as described at the to of the file), or a
- * message that describes which of the standard demo tasks an error has been
- * discovered in.
- * Messages are not written directly to the terminal, but passed to vLCDTask
- * via a queue.
- static void vCheckTask( void *pvParameters );
- * Configures the timers and interrupts for the fast interrupt test as
- * described at the top of this file.
- extern void vSetupTimerTest( void );
- /* The queue used to send messages to the LCD task. */
- QueueHandle_t xLCDQueue;
- int main( void )
- #ifdef DEBUG
- debug();
- #endif
- prvSetupHardware();
- /* Create the queue used by the LCD task. Messages for display on the LCD
- are received via this queue. */
- xLCDQueue = xQueueCreate( mainLCD_QUEUE_SIZE, sizeof( xLCDMessage ) ); //創(chuàng)建LCD列隊,并返回列隊編號
- /* Start the standard demo tasks. */
- vStartBlockingQueueTasks( mainBLOCK_Q_PRIORITY ); //創(chuàng)建了6個任務(wù),處理三組參數(shù)
- vCreateBlockTimeTasks(); //創(chuàng)建兩個block任務(wù) 阻塞任務(wù)
- vStartSemaphoreTasks( mainSEM_TEST_PRIORITY ); //
- vStartPolledQueueTasks( mainQUEUE_POLL_PRIORITY ); //創(chuàng)建列隊測試任務(wù) 待挖掘
- vStartIntegerMathTasks( mainINTEGER_TASK_PRIORITY ); //
- vStartLEDFlashTasks( mainFLASH_TASK_PRIORITY ); //創(chuàng)建LED翻轉(zhuǎn)任務(wù),創(chuàng)建了3個相同的任務(wù),每個對應(yīng)不同的燈
- vAltStartComTestTasks( mainCOM_TEST_PRIORITY, mainCOM_TEST_BAUD_RATE, mainCOM_TEST_LED ); //創(chuàng)建串口收發(fā)任務(wù),收和發(fā)是兩個任務(wù)
- /* Start the tasks defined within this file/specific to this demo. */
- xTaskCreate( vCheckTask, "Check", mainCHECK_TASK_STACK_SIZE, NULL, mainCHECK_TASK_PRIORITY, NULL ); //創(chuàng)建LCD內(nèi)容顯示設(shè)置任務(wù)
- xTaskCreate( vLCDTask, "LCD", configMINIMAL_STACK_SIZE, NULL, tskIDLE_PRIORITY, NULL ); //創(chuàng)建LCD顯示任務(wù)
- /* The suicide tasks must be created last as they need to know how many
- tasks were running prior to their creation in order to ascertain whether
- or not the correct/expected number of tasks are running at any given time. */
- vCreateSuicidalTasks( mainCREATOR_TASK_PRIORITY ); //創(chuàng)建一批可以自動刪除的任務(wù)
- /* Configure the timers used by the fast interrupt timer test. */
- vSetupTimerTest(); //初始化定時器
- /* Start the scheduler. */
- vTaskStartScheduler(); //啟動調(diào)度器,開始操作系統(tǒng)
- /* Will only get here if there was not enough heap space to create the
- idle task. */
- return 0;
- void vLCDTask( void *pvParameters )
- xLCDMessage xMessage;
- /* Initialise the LCD and display a startup message. */
- prvConfigureLCD();
- LCD_DrawMonoPict( ( unsigned long * ) pcBitmap );
- for( ;; )
- /* Wait for a message to arrive that requires displaying. */
- while( xQueueReceive( xLCDQueue, &xMessage, portMAX_DELAY ) != pdPASS ); //從序列中讀取數(shù)據(jù),返回有沒有
- /* Display the message. Print each message to a different position. */
- printf( ( char const * ) xMessage.pcMessage );
- TickType_t xLastExecutionTime;
- static signed char cPassMessage[ mainMAX_MSG_LEN ];
- extern unsigned short usMaxJitter;
- xLastExecutionTime = xTaskGetTickCount();
- xMessage.pcMessage = cPassMessage;
- for( ;; )
- /* Perform this check every mainCHECK_DELAY milliseconds. */
- vTaskDelayUntil( &xLastExecutionTime, mainCHECK_DELAY ); //絕對延時,如果某個延時被任務(wù)耽擱了,會在下一次調(diào)用時補(bǔ)償回來
- /* Has an error been found in any task? */
- if( xAreBlockingQueuesStillRunning() != pdTRUE )
- xMessage.pcMessage = "ERROR IN BLOCK Q\n";
- else if( xAreBlockTimeTestTasksStillRunning() != pdTRUE )
- xMessage.pcMessage = "ERROR IN BLOCK TIME\n";
- else if( xAreSemaphoreTasksStillRunning() != pdTRUE )
- xMessage.pcMessage = "ERROR IN SEMAPHORE\n";
- else if( xArePollingQueuesStillRunning() != pdTRUE )
- xMessage.pcMessage = "ERROR IN POLL Q\n";
- else if( xIsCreateTaskStillRunning() != pdTRUE )
- xMessage.pcMessage = "ERROR IN CREATE\n";
- else if( xAreIntegerMathsTaskStillRunning() != pdTRUE )
- xMessage.pcMessage = "ERROR IN MATH\n";
- else if( xAreComTestTasksStillRunning() != pdTRUE )
- xMessage.pcMessage = "ERROR IN COM TEST\n";
- else
- sprintf( ( char * ) cPassMessage, "PASS [%uns]\n", ( ( unsigned long ) usMaxJitter ) * mainNS_PER_CLOCK );
- /* Send the message to the LCD gatekeeper for display. */
- xQueueSend( xLCDQueue, &xMessage, portMAX_DELAY );
- /* Start with the clocks in their expected state. */
- RCC_DeInit();
FreeRTOS-project STM32.7z
(3.09 MB, 下載次數(shù): 57)
2020-10-16 18:43 上傳
點擊文件名下載附件
STM32FreeRtos例程 下載積分: 黑幣 -5
