查看: 2662|回復: 0
OKdo E1開發板驅動雙色OLED屏顯示
OKdo E1開發板是一款以硬幣大小而為人稱道的開發板,它體積小巧那自然要為它配置一塊同樣小巧的顯示屏才稱得上是絕配,下面就通過I/O口來模擬I2C通訊了,使得OLED屏能夠顯示出信息來。
OLED屏與MCU的連接關系為:
SCL---PIO0_7
SDA---PIO1_0
相關引腳輸出高低電平的語句定義:
#define OLED_SCLK_Clr()  GPIO_PinWrite(GPIO, 0u, 7u, 0)
#define OLED_SCLK_Set()  GPIO_PinWrite(GPIO, 0u, 7u, 1)
#define OLED_SDIN_Clr()  GPIO_PinWrite(GPIO, 1u, 0u, 0)
#define OLED_SDIN_Set()  GPIO_PinWrite(GPIO, 1u, 0u, 1)
OLED屏引腳配置函數:
  1. void app_oled_init(void)
  2. {
  3. gpio_pin_config_t   gpioPinConfig;
  4. gpioPinConfig.pinDirection = kGPIO_DigitalOutput;
  5. gpioPinConfig.outputLogic  = 1u;
  6. GPIO_PinInit (GPIO, 0u, 7u, &gpioPinConfig);
  7. GPIO_PinInit (GPIO, 1u, 0u, &gpioPinConfig);
  8. }
OLED屏初始化函數:
  1. void OLED_Init(void)
  2. {
  3. Write_IIC_Command(0xAE); //display off
  4. Write_IIC_Command(0x20); //Set Memory Addressing Mode
  5. Write_IIC_Command(0x10);
  6. Write_IIC_Command(0xb0);//Set Page Start Address for Page Addressing Mode,0-7
  7. Write_IIC_Command(0xc8);//Set COM Output Scan Direction
  8. Write_IIC_Command(0x00);//---set low column address
  9. Write_IIC_Command(0x10);//---set high column address
  10. Write_IIC_Command(0x40);//--set start line address
  11. Write_IIC_Command(0x81);//--set contrast control register
  12. Write_IIC_Command(0xdf);
  13. Write_IIC_Command(0xa1);//--set segment re-map 0 to 127
  14. Write_IIC_Command(0xa6);//--set normal display
  15. Write_IIC_Command(0xa8);//--set multiplex ratio(1 to 64)
  16. Write_IIC_Command(0x3F);//
  17. Write_IIC_Command(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
  18. Write_IIC_Command(0xd3);//-set display offset
  19. Write_IIC_Command(0x00);//-not offset
  20. Write_IIC_Command(0xd5);//--set display clock divide ratio/oscillator frequency
  21. Write_IIC_Command(0xf0);//--set divide ratio
  22. Write_IIC_Command(0xd9);//--set pre-charge period
  23. Write_IIC_Command(0x22); //
  24. Write_IIC_Command(0xda);//--set com pins hardware configuration
  25. Write_IIC_Command(0x12);
  26. Write_IIC_Command(0xdb);//--set vcomh
  27. Write_IIC_Command(0x20);//0x20,0.77xVcc
  28. Write_IIC_Command(0x8d);//--set DC-DC enable
  29. Write_IIC_Command(0x14);//
  30. Write_IIC_Command(0xaf);//--turn on oled panel
  31. }
OLED屏顯示主程序:
  1. int main(void)
  2. {
  3. POWER_SetBodVbatLevel(kPOWER_BodVbatLevel1650mv, kPOWER_BodHystLevel50mv, false);
  4. CLOCK_EnableClock(kCLOCK_Gpio0);
  5. CLOCK_EnableClock(kCLOCK_Gpio1);
  6. BOARD_BootClockFROHF96M();
  7. app_oled_init();
  8. OLED_Init();
  9. OLED_Clear();
  10. OLED_ShowString(0,0,"OKDOE1 TEST",16);
  11. OLED_ShowString(0,2,"OLED Display",16);
  12. OLED_ShowString(0,4,"jinglixixi",16);
  13. OLED_ShowString(0,6,"2020.11.2",16);
  14. while (1);
  15. }
經程序的編譯下載,其運行效果如圖所示。
OLED屏顯示效果
主站蜘蛛池模板: 国产精品视频免费播放 | 久久青| 一区二区三区免费观看 | 亚洲国产成人av好男人在线观看 | 黄色毛片在线看 | 97在线观看 | 欧美一级二级在线观看 | 欧美综合久久 | 91成人在线视频 | 亚洲精品99 | 伊人精品国产 | 在线中文字幕第一页 | 日韩在线小视频 | 黄色一级毛片免费看 | 国产黄色av电影 | 一级片在线视频 | 性色的免费视频 | 亚洲精品日本 | 亚洲一在线 | 看av片网站 | 欧美a v在线 | 亚洲字幕在线观看 | 有码一区| a毛片 | 一区二区三区av | 国产精品一区二区视频 | 91精品国产综合久久久久久 | 久久久国产精品 | 亚洲国产aⅴ成人精品无吗 欧美激情欧美激情在线五月 | av中文字幕在线 | 亚洲美女网站 | 欧美一级二级视频 | 婷婷中文字幕 | 欧美天堂 | 久久草在线视频 | 久草网站 | 欧美视频精品 | 久久毛片| 美女国产精品 | 欧美一级在线观看 | 一区二区三区网站 |
