查看: 8284|回復: 3
STM32 TM1621驅動以及顯示程序
ID:399215 發(fā)表于 2020-11-13 16:27 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
驅動程序使用的STM32F103的庫寫的
  1. #include "../HARDWARE/TM1621/TM1621.h"
  2. #define WRITE PCout(15)
  3. #define CS          PDout(0)
  4. #define DATA  PCout(14)
  5. //unsigned char Smg[16]={0xad,0xad,0xad,0xad,0x8e,0x8e,0x8e,0x8e,0x8e,0x8e,0x8e,0x8e,0x8e,0x8e,0x8e,0x8e};  //0~F字型碼
  6. /* 0-0 1-1 15-15 16-空格 17-0x04-負號 18-0x0B -L        */
  7. unsigned char Smg0[30]={0xeb,0x60,0xc7,0xE5,0x6C,0xAD,0xaf,0xE0,0xef,0xed,0xee,0x2f,0x8b,0x67,0x8f,0x8e,0x00,0x04,0x0B};   //0~F字型碼 //正確字形
  8. unsigned char Smg1[30]={0xbe,0x06,0x7c,0x5E,0xC6,0xDA,0xFA,0x0E,0xFE,0xDE,0xEE,0xF2,0xB8,0x76,0xf8,0xe8,0x00,0x40,0xB0};          //0~F字型碼 //反向字形
  9. unsigned char Smg2[30]={0xeb,0x60,0xc7,0xE5,0x6C,0xAD,0xaf,0xE0,0xef,0xed,0xee,0x2f,0x8b,0x67,0x8f,0x8e};
  10. unsigned char Tab0[30]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}; //清屏
  11. /********************延時函數(shù)*************************/
  12. void delay_nms(uint n)
  13. {
  14.         uint i;
  15.         while (n--)
  16.                 for (i=0;i<500;i++);
  17. }
  18. /********************從高位寫入數(shù)據(jù)*************************/
  19. void Write_Data_H(uchar Data, uchar Cnt)           //Data的高cnt位寫入TM1621,高位在前
  20. {
  21.         uchar i;
  22.         for (i=0;i<Cnt;i++)
  23.         {
  24.                 WRITE=0;
  25.                 if (Data&0x80)                                 //從最高位發(fā)送
  26.                         DATA=1;
  27.                 else
  28.                         DATA=0;
  29.                 nop;
  30.                 nop;
  31.                 WRITE=1;
  32.                 Data<<=1;
  33.         }
  34.         WRITE=0;
  35.         DATA=0;
  36. }
  37. /********************從低位寫入數(shù)據(jù)*************************/
  38. void Write_Data_L(uchar Data,uchar Cnt)        //Data 的低cnt位寫入TM1621,低位在前
  39. {
  40.         unsigned char i;
  41.         for (i=0;i<Cnt;i++)
  42.         {
  43.                 WRITE=0;
  44.                 if (Data&0x01)                               //從低位發(fā)送
  45.                         DATA=1;
  46.                 else
  47.                         DATA=0;
  48.                 nop;
  49.                 nop;
  50.                 WRITE=1;
  51.                 Data>>=1;
  52.         }
  53.         WRITE=0;
  54.         DATA=0;
  55. }
  56. /********************寫入控制命令*************************/
  57. void WriteCmd(uchar Cmd)
  58. {
  59.         CS=0;
  60.         nop;
  61.         Write_Data_H(0x80,4);     //寫入命令標志100
  62.         Write_Data_H(Cmd,8);      //寫入命令數(shù)據(jù)
  63.         CS=1;
  64.         nop;
  65. }
  66. /*********指定地址寫入數(shù)據(jù),實際寫入后4位************/
  67. void WriteOneData(uchar Addr, uchar Data)
  68. {
  69.         CS=0;
  70.         Write_Data_H(0xa0,3);     //寫入數(shù)據(jù)標志101
  71.         Write_Data_H(Addr<<2,6);  //寫入地址數(shù)據(jù)(A5-A4-A3-A2-A1-A0)從高位開始寫數(shù)據(jù)
  72.         Write_Data_L(Data,4);     //寫入數(shù)據(jù)
  73.         CS=1;
  74.         nop;
  75. }
  76. /*********連續(xù)寫入方式,每次數(shù)據(jù)為8位,寫入數(shù)據(jù)************/
  77. void WriteAllData(uchar Addr,uchar *p,uchar cnt)
  78. {
  79.         uchar i;
  80.         CS=0;
  81.         Write_Data_H(0xa0,3);      //寫入數(shù)據(jù)標志101
  82.         Write_Data_H(Addr<<2,6);   //寫入地址數(shù)據(jù)
  83.         for(i=0;i<cnt;i++)            //寫入數(shù)據(jù)
  84.         {
  85.                 Write_Data_L(*p,8);
  86.                 p++;
  87.         }
  88.         CS=1;
  89.         nop;
  90. }
  91. /***************這個子程序暫時沒用,注釋掉******************/
  92. /*******************TM1621初始化**********************/
  93. void TM1621_Gpio_Init(void)
  94. {
  95.         GPIO_InitTypeDef GPIO_InitStructure;
  96.
  97.
  98.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOD |RCC_APB2Periph_GPIOB, ENABLE);//開C口時鐘,復用時鐘。
  99.
  100.     GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);//使能JTAGDisable,即禁用JTAG接口
  101.
  102.
  103.         PWR_BackupAccessCmd(ENABLE);//允許修改RTC 和后備寄存器
  104.         RCC_LSEConfig(RCC_LSE_OFF);//關閉外部低速外部時鐘信號功能 后,PC13 PC14 PC15 才可以當普通IO用。
  105.         BKP_TamperPinCmd(DISABLE);//關閉入侵檢測功能,也就是 PC13,也可以當普通IO 使用
  106.
  107.
  108.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_14 | GPIO_Pin_15;//PC14-Data   PC15-WR
  109.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //設置成輸出
  110.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  111.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  112.
  113.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_15 | GPIO_Pin_3;//PB15 - 背光
  114.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  115.
  116.         GPIO_ResetBits(GPIOB,GPIO_Pin_15);/*低電平開啟背光 高電平關閉背光*/
  117.
  118.         GPIO_ResetBits(GPIOB,GPIO_Pin_3);
  119.         GPIO_SetBits(GPIOB,GPIO_Pin_3);
  120.
  121.
  122.         GPIO_PinRemapConfig(GPIO_Remap_PD01,ENABLE);/*映射PD01的使能*/
  123.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_0;//PD0-CS
  124.         GPIO_Init(GPIOD, &GPIO_InitStructure);
  125.
  126.         PWR_BackupAccessCmd(DISABLE);/* 禁止修改RTC和后備寄存器*/
  127.         BKP_ITConfig(DISABLE);
  128. }
  129. void TM1621_init(void)
  130. {
  131.         TM1621_Gpio_Init();
  132.
  133.         CS=1;
  134.         WRITE=1;
  135.         DATA=1;
  136.
  137.         nop;
  138.         delay_nms(1);
  139.         WriteCmd(BIAS);                 //1/3偏壓 4公共口
  140.         WriteCmd(RC);                         //內部RC振蕩
  141.         WriteCmd(SYSDIS);                 //關系統(tǒng)振蕩器和LCD偏壓發(fā)生器
  142.         WriteCmd(WDTDIS);                 //禁止看門狗
  143.         WriteCmd(SYSEN);                 //打開系統(tǒng)振蕩器
  144.         WriteCmd(LCDON);                 //開LCD偏壓
  145.
  146. }
  147. /*************TM1621清屏函數(shù)*****************/
  148. //void Clear1621()
  149. //{
  150. //        uchar i;
  151. //        for(i=9;i<22;i++)
  152. //        {
  153. //                WriteOneData(i, 0x00);
  154. //        }
  155. //}
  156. /*******************************************************************************
  157. * 函數(shù)名稱                   :1621顯示函數(shù)顯示
  158. * 函數(shù)功能                   :
  159. * 輸    入         : 無
  160. * 輸    出         : 無
  161. *******************************************************************************/
  162. //void Disp1621(uchar Addr, uchar Data)
  163. //{
  164. //        WriteOneData(Addr, Data);
  165. //}
  166. void Display1621(unsigned char * bmp , unsigned char dot)
  167. {
  168.         //unsigned char cwDispalyAddress = 11;
  169.         /* 地址 11*/
  170.         /* 數(shù)組bmp第一個數(shù)據(jù)對應顯示最左邊數(shù)碼管 第二個對應第二個數(shù)碼管 以此類推 */
  171.
  172.
  173.         /* void WriteOneData(uchar Addr, uchar Data)   */
  174.         /* WriteAllData(uchar Addr,uchar *p,uchar cnt) */
  175.
  176.         WriteAllData(18,Smg0+(0+bmp[0]),1);                //0
  177.
  178.         WriteAllData(20,Smg0+(0+bmp[1]),1);                //1
  179.
  180.         WriteOneData(22,Smg0[0+bmp[2]]);                //2
  181.         WriteOneData(17,Smg0[0+bmp[2]]>>4);                //2
  182.
  183.         WriteAllData(15,Smg1+(0+bmp[3]),1);                //3
  184.
  185.         WriteAllData(13,Smg1+(0+bmp[4]),1);                //4
  186.
  187.         WriteAllData(11,Smg1+(0+bmp[5]),1);                //5
  188.         if(RTData[40] == 2)        //如果是標定界面  則顯示小數(shù)點
  189.                 dot = 3;
  190.
  191.         if(dot != 5){
  192.                 if(dot <= 1 ){        //繪制小數(shù)點
  193.                         Smg0[bmp[dot]] |= 0x10;
  194.                 }else if(dot == 2){
  195.                         Smg0[bmp[dot]] |= 0x10;
  196.                 }else if(dot >  2){
  197.                         Smg1[bmp[dot]] |= 0x01;
  198.                 }
  199.
  200.                 if(RTData[40] == 0 || RTData[40] == 2){        // 只有在實時值顯示界面和標定界面才顯示小數(shù)點
  201.
  202.                         switch(dot)
  203.                         {
  204.                                 case 0:
  205.                                         WriteAllData(18,Smg0+(0+bmp[0]),1);                //0
  206.
  207.                                 break;
  208.
  209.                                 case 1:
  210.                                         WriteAllData(20,Smg0+(0+bmp[1]),1);                //1
  211.
  212.                                 break;
  213.
  214.                                 case 2:
  215.                                         WriteOneData(22,Smg0[0+bmp[2]]);                //2
  216.                                         WriteOneData(17,Smg0[0+bmp[2]]>>4);                //2
  217.
  218.                                 break;
  219.
  220.                                 case 3:
  221.                                         WriteAllData(15,Smg1+(0+bmp[3]),1);                //3
  222.
  223.                                 break;
  224.
  225.                                 case 4:
  226.                                         WriteAllData(13,Smg1+(0+bmp[4]),1);                //4
  227.
  228.                                 break;
  229.                         }
  230.
  231.
  232.                         if(dot <= 1 ){        //繪制小數(shù)點
  233.                                 Smg0[bmp[dot]] &= 0xef;
  234.                         }else if(dot == 2){
  235.                                 Smg0[bmp[dot]] &= 0xef;
  236.                         }else if(dot > 2){
  237.                                 Smg1[bmp[dot]] &= 0xfe;
  238.                         }
  239.                 }
  240.         }
  241. }
  242. /*
  243. * @brief 將整型數(shù)轉換為字符并顯示
  244. *
  245. *
  246. */
  247. void DisplayNum(int num , unsigned dot)
  248. {
  249.         unsigned char cwchar[6]={0,0,0,0,0,0};
  250.         u8 b[6];
  251.         u8 j=0,k=0,m;
  252.         int i;
  253.
  254.         if(num>999999)
  255.                 num=999999;
  256.         if(num<-99999)
  257.                 num=-99999;
  258.
  259.         if(num>=0){
  260.                 b[5]=0;//正數(shù)
  261.         }
  262.         else{
  263.                 num=-num;
  264.                 //num[0]=45;
  265.                 b[5]=1;//負數(shù)
  266.         }
  267.         for(i=5 ; i>=0 ; i--){                        //整型數(shù)轉字符數(shù)
  268.
  269.                 if(num!=0)        //判斷是否
  270.                         cwchar[i]=(num%10);
  271.                 else{                                                  //無數(shù)字
  272.                         if(j==0)j=i;                        //數(shù)據(jù)位數(shù)
  273.
  274.                         if(!b[5]){
  275.                                 if((dot<5-i))                //&&(RTData[11]!=2&&RTData[11]!=3)&&RTData[13]!=2
  276.                                         cwchar[i]=16;
  277.                         }else{
  278.
  279.                                 if((dot<5-i)){                //&&(RTData[11]!=2&&RTData[11]!=3)&&RTData[13]!=2
  280.                                         cwchar[i]=16;
  281.                                         if(k==0)
  282.                                         k=i;//負數(shù)小數(shù)點首位位數(shù)定位
  283.                                 }
  284.                         }
  285.                 }
  286.                 num/=10;
  287.         }
  288. ……………………
  289. …………限于本文篇幅 余下代碼請從51黑下載附件…………
只需要將關鍵引腳替換即可正常使用
TM1621.zip (3.52 KB, 下載次數(shù): 305)
根據(jù)下圖和TM1621的引腳更換其顯示腳
收藏收藏4 分享淘帖 頂 踩
ID:1036413 發(fā)表于 2022-9-29 11:25 | 只看該作者
RTData是啥,哪里有定義?
ID:1096768 發(fā)表于 2023-10-21 11:18 | 只看該作者
RTData是啥,哪里有定義?
ID:1015352 發(fā)表于 2025-4-23 14:26 | 只看該作者
辛苦了,很好!謝謝
主站蜘蛛池模板: 台湾av在线 | 激情视频一区 | 欧美日韩亚洲另类 | 国产小视频网站 | 国产中文字幕在线播放 | 99福利视频| 超碰成人在线观看 | 伊人精品在线 | 91精品国产麻豆国产自产在线 | 国产精品成人一区二区网站软件 | 午夜免费av | 午夜国产一区 | a毛片在线观看 | 蜜桃精品一区二区 | 亚洲天天看 | 日韩欧美不卡 | www.操| 九九色综合 | 丁香婷婷在线 | 免费观看av | 久久久久人 | 欧美黄色网 | 91av在线免费观看 | 日韩视频在线观看免费 | 97精品超碰一区二区三区 | 欧美精品第一页 | 精品国产乱码一区二区三 | 欧美日韩 | 日韩亚洲欧美在线观看 | 精品乱子伦一区二区三区 | 亚洲免费黄色 | 日韩欧美国产高清91 | 国产永久免费视频 | 国产女人高潮毛片 | 特黄毛片| 久久a级片 | www国产亚洲精品久久网站 | 成人网战 | 97人人插 | 精品一区二区三区视频 | 天堂中文字幕免费一区 |
