查看: 3951|回復: 3
STM32F4-ADXL355驅動程序
ID:848226 發表于 2020-11-24 10:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
*        文件名稱 : bsp_ADXL355.c
*        版    本 : V1.0
*        說    明 : ACC-ADXL355 模塊驅動文件
*        作    者 : Mr. Albert Chen
#include "bsp_ADXL355.h"
u8 res=0;
*        函 數 名: ADXL355_SPI2_Init
*        功能說明: 配置ADXL355的硬件SPI2的GPIO端口和硬件SPI2的相關設置,并將SPI2初始化
*        形    參: 無
*        返 回 值: 無
void ADXL355_SPI2_Init(void)
        GPIO_InitTypeDef        GPIO_InitStructure;
        SPI_InitTypeDef                SPI_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);        //使能GPIOB時鐘
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);        //使能SPI2時鐘
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource13,GPIO_AF_SPI2);         //PB13復用為 SPI2
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource14,GPIO_AF_SPI2);         //PB14復用為 SPI2
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource15,GPIO_AF_SPI2);         //PB15復用為 SPI2
        //GPIOB_12,13,14,15初始化設置
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;                        //PB12-SPI2_NCS
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;                //普通輸出模式
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;                //推挽輸出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //50MHz
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;                //上拉
        GPIO_Init(GPIOB, &GPIO_InitStructure);                                //初始化
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;                        //PB13-SPI2_SCLK
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;                //復用功能
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;                        //PB14-SPI2_MISO
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;                        //PB15-SPI2_MOSI
        //這里對SPI口初始化
        RCC_APB1PeriphResetCmd(RCC_APB1Periph_SPI2,ENABLE);        //使能復位SPI2
        RCC_APB1PeriphResetCmd(RCC_APB1Periph_SPI2,DISABLE);//停止復位SPI2
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;  //雙全工
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                                                  //主機
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                                          //8位數據傳輸模式
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;                                                  //空閑時低電平                |CPOL=0|
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;                                                 //第一個時鐘開始采樣        |CPHA=0|
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                                                          //軟件控制NSS
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_32;        //sclk<10MHz        32分頻 84M/32=2.6M
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;                                         //高位在前
    SPI_InitStructure.SPI_CRCPolynomial = 7;                                                         //CRC校驗
    SPI_Init(SPI2, &SPI_InitStructure);        //初始化SPI2
        SPI_Cmd(SPI2, ENABLE);        //使能SPI2
        CS_ADXL355_HIGH;                //將SPI片選端口拉高,初始化SPI2后先不使能它
*        函 數 名: ADXL355_SPI_Write
*        功能說明: 通過STM32的硬件SPI向ADXL355中寫入數據、命令、寄存器地址
*        形    參: address                 - ACC register address
                          Data                         - value to be written in 1 register write
                          Data2                 - 2nd value to be written in 2 register write
                          enWriteData         - write mode
*        返 回 值: 無
*        備          注:
void ADXL355_SPI_Write(uint8_t address, uint8_t Data, uint8_t Data2, enWriteData enMode)
        uint8_t writeAddress;
        writeAddress = ((address <<1)|ADXL355_WRITE);
        if(enMode == SPI_WRITE_ONE_REG)
                CS_ADXL355_LOW;
                /* Send register address */
                while(SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_TXE) != SET);
                SPI_I2S_SendData(SPI2,writeAddress);
                /** Wait until received */
                while(SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_RXNE) != SET);
                SPI_I2S_ReceiveData(SPI2);
                /* Send value to be written */
                SPI_I2S_SendData(SPI2,Data);
                Delay_us(2);
                CS_ADXL355_HIGH;
        if(enMode == SPI_WRITE_TWO_REG)
                CS_ADXL355_LOW;
                /* Send 1st value to be written */
                /* Send 2nd value to be written */
                SPI_I2S_SendData(SPI2,Data2);
                Delay_us(2);
                CS_ADXL355_HIGH;
*        函 數 名: ADXL355_SPI_Read
*        功能說明: 通過STM32的硬件SPI從ADXL355中讀取數據一個地址或兩個地址的數據
*        形    參: address        - register address
                          enRegs        - register number
*        返 回 值: 讀取的結果
*        備          注:
uint32_t ADXL355_SPI_Read(uint8_t address, enRegsNum enRegs)
        uint32_t Result = 0;
        uint32_t valueL = 0;
        uint32_t valueM = 0;
        uint32_t valueH = 0;
        writeAddress = ((address <<1)|ADXL355_READ);
        CS_ADXL355_LOW;
        if(enRegs == SPI_READ_ONE_REG)
                /* Wait until received */
                /* 發送偽字節去得到寄存器收到的數據 */
                SPI_I2S_SendData(SPI2,0xAA);
                valueL = SPI_I2S_ReceiveData(SPI2);        /* One dummy read */
                Result = valueL;        /* Set read result*/
        if(enRegs == SPI_READ_TWO_REG)                /* Only used for Temp & X,Y,Z offset and threshold registers*/
                valueH = SPI_I2S_ReceiveData(SPI2);        /* One dummy read */
                Result = ((valueH << 8) | valueL);        /* Set read result*/
        if(enRegs == SPI_READ_THREE_REG)        /* Only used for X,Y,Z axis data registers*/
                valueM = SPI_I2S_ReceiveData(SPI2);        /* One dummy read */
                Result = ((valueH << 16) | (valueM << 8) | valueL); /* Set read result*/
        CS_ADXL355_HIGH;
        return Result;
*        函 數 名: ADXL355_Init
*        功能說明: 配置ADXL355的寄存器,將加速度計初始化
*        形    參: 無
*        返 回 值: 無
*        備          注: 各寄存器詳見頭文件
void ADXL355_Init(void)
//        ADXL355_SPI_Write(RANGE, 0x82, 0x00, SPI_WRITE_ONE_REG);                /* Set sensor range 4G */
//        Delay_ms(20);
//        ADXL355_SPI_Write(FILTER,0x04, 0x00, SPI_WRITE_ONE_REG);                /* ODR 250Hz,LPF 62.5Hz*/
//        Delay_ms(20);
        //這里按照金亮師兄的進行修改
        ADXL355_SPI_Write(RESET, 0x52,0x00,SPI_WRITE_ONE_REG);
        Delay_ms(20);
  res=ADXL355_SPI_Read(PARTID,SPI_READ_ONE_REG);
        if(res==0xED){
        Delay_ms(20);
        Delay_ms(20);
//        uint32_t volatile ui32test ,ui32test2 ,ui32test3 ,ui32test4;
//        ui32test  = ADXL355_SPI_Read(DEVID_AD, SPI_READ_ONE_REG);                  /* Read the ID register */
//        ui32test2 = ADXL355_SPI_Read(DEVID_MST, SPI_READ_ONE_REG);                  /* Read the ID register */
//        ui32test3 = ADXL355_SPI_Read(PARTID, SPI_READ_ONE_REG);                  /* Read the ID register */
//        ui32test4 = ADXL355_SPI_Read(RANGE, SPI_READ_ONE_REG);                 /* Read the ID register */
*        函 數 名: ADXL355_Start_Sensor
*        功能說明: 開啟ADXL355測量模式
*        形    參: 無
*        返 回 值: 無
*        備          注:
void ADXL355_Start_Sensor(void)
        uint8_t temp;
        temp = (uint8_t)ADXL355_SPI_Read(POWER_CTL, SPI_READ_ONE_REG);        /* Read POWER_CTL register, before modifying it */
        temp = temp & 0xFE;        /* Set measurement bit in POWER_CTL register */
        ADXL355_SPI_Write(POWER_CTL, 0x00, 0x00, SPI_WRITE_ONE_REG);        /* Write the new value to POWER_CTL register */
*        函 數 名: ADIS16445_AccRead
*        功能說明: Reads the accelerometer data.
*        形    參: *AccData_original
*        返 回 值: 無
*        備          注: 1.因為spi讀取存在一個周期的時間差,因此發送XACCL_OUT地址后下一個周期讀的數才為X軸數據
*                            以此類推
*                          2.緩存【1】original_data_buf        IMU輸出的原始數據
int32_t ADXL355_Acceleration_Data_Conversion (uint32_t SensorData)
   int32_t volatile Conversion = 0;
   SensorData = (SensorData  >> 4);
   SensorData = (SensorData & 0x000FFFFF);
   if((SensorData & 0x00080000)  == 0x00080000){
         Conversion = (SensorData | 0xFFF00000);
   else{
         Conversion = SensorData;
   return Conversion;
void ADXL355_Data_Scan(int32_t *AccData_original_32)
        uint32_t SensorX,SensorY,SensorZ;
        //SensorX = ADXL355_SPI_Read(XDATA3, SPI_READ_THREE_REG);
        SensorY = ADXL355_SPI_Read(YDATA3, SPI_READ_THREE_REG);
        SensorZ = ADXL355_SPI_Read(ZDATA3, SPI_READ_THREE_REG);
        AccData_original_32[0] = ADXL355_Acceleration_Data_Conversion(SensorY);
        AccData_original_32[1] = -ADXL355_Acceleration_Data_Conversion(SensorX);
        AccData_original_32[2] = ADXL355_Acceleration_Data_Conversion(SensorZ);
全部資料51hei下載地址:
BSP_ADXL355.rar (3.85 KB, 下載次數: 95)
ID:1025134 發表于 2022-5-9 17:30 | 只看該作者
超棒的帖子 頂一個!
ID:659609 發表于 2022-8-11 14:08 | 只看該作者
要是一個完整的工程文件就好了,不過也很有用,謝謝樓主了
ID:685093 發表于 2023-7-20 22:23 | 只看該作者
好的,謝謝,要是有DMA讀FIFO數據就更好了
主站蜘蛛池模板: 丰满少妇高潮在线观看 | 精品福利一区 | 免费看av的网址 | 欧美午夜精品 | 日韩精品免费视频 | 一区视频在线 | 日韩在线观看一区 | 中文字幕第5页 | 美日韩丰满少妇在线观看 | 91视频亚洲| 午夜激情小视频 | 国产成人免费视频 | 亚洲国产精品自拍 | 国产一区精品在线观看 | 毛茸茸性猛交xxxx | 亚洲第一毛片 | 欧美成人猛片aaaaaaa | 日韩欧美在线一区二区 | 性欧美69| 中文字幕不卡视频 | 精品一区av | 亚洲免费a| www.欧美精品 | 四虎永久在线视频 | 中文字幕在线看 | 黄色片免费在线观看 | 欧美日韩一二区 | 九九久久精品 | 久久精品在线播放 | 成人b站 | 在线小视频 | 黄色片免费在线观看 | av综合网站 | 欧美激情一区二区 | 亚洲性生活片 | 亚洲69视频 | 欧美日韩一区二区三区视频 | 五月天激情影院 | 中文字幕www | 中文字幕伊人 | 97超碰在线播放 |
