查看: 5613|回復: 2
PIC單片機4X4矩陣鍵盤檢測原理及實現C語言程序
ID:51707 發表于 2013-7-11 02:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<pic.h>
#define uchar unsigned char
#define uint  unsigned int
__CONFIG(0x3B31);
const uchar table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar key_num;
void delay(uint x);
void init();
void scan();
void didi(uchar num);
void disp();
    init();
        scan();
        disp();
void delay(uint x)
    uint a,b;
    for(a=x;a>0;a--)
        for(b=110;b>0;b--);
void init()
    TRISB=0x0f;
    TRISD=0;
    TRISA=0;
    TRISE0=0;
    RE0=0;
    PORTD=0;
    PORTA=0xff;
void scan()
    uchar key_tem;
    PORTB=0x7f;//0111 1111
    key_num=PORTB;
    key_num=key_num&0x0f;
    if(key_num!=0x0f)
        delay(10);
        key_num=PORTB;
        if(key_num!=0x0f)
            key_tem=key_num;
            didi(1);
            while(key_tem!=0x0f)
                key_tem=PORTB;
                key_tem=key_tem&0x0f;
            key_num=key_num|0x70;
        PORTB=0xBf;//1011 1111
        key_num=PORTB;
        if(key_num!=0x0f)
            delay(10);
            key_num=PORTB;
            if(key_num!=0x0f)
                key_tem=key_num;
                didi(1);
                    key_tem=PORTB;
                key_num=key_num|0xb0;
            PORTB=0xdf;//1101 1111
            key_num=PORTB;
            if(key_num!=0x0f)
                delay(10);
                key_num=PORTB;
                if(key_num!=0x0f)
                    key_tem=key_num;
                    didi(1);
                        key_tem=PORTB;
                    key_num=key_num|0xd0;
                PORTB=0xef;//1011 1111
                key_num=PORTB;
                if(key_num!=0x0f)
                    delay(10);
                    key_num=PORTB;
                    if(key_num!=0x0f)
                        key_tem=key_num;
                        didi(1);
                            key_tem=PORTB;
                        key_num=key_num|0xe0;
void disp()
    switch(key_num)
        case 0xee:PORTD=table[0];break;//1110
        case 0xed:PORTD=table[1];break;//1101
        case 0xeb:PORTD=table[2];break;//1011
        case 0xe7:PORTD=table[3];break;//0111
        case 0xde:PORTD=table[4];break;
        case 0xdd:PORTD=table[5];break;
        case 0xdb:PORTD=table[6];break;
        case 0xd7:PORTD=table[7];break;
        case 0xbe:PORTD=table[8];break;
        case 0xbd:PORTD=table[9];break;
        case 0xbb:PORTD=table[10];break;
        case 0xb7:PORTD=table[11];break;
        case 0x7e:PORTD=table[12];break;
        case 0x7d:PORTD=table[13];break;
        case 0x7b:PORTD=table[14];break;
        case 0x77:PORTD=table[15];break;
    uchar di_num;
    for(di_num=num;di_num>0;di_num--)
        RE0=1;
        delay(50);
        RE0=0;
        delay(20);
ID:53440 發表于 2013-8-23 16:07 | 只看該作者
微芯 單片機,用的地方很多, 我做這個不久, 公司各方面很有優勢,Q,Q:需要的 可以互相了解。值得
ID:53860 發表于 2013-9-1 19:30 | 只看該作者
貼一個經典的按鍵檢測程序供大家參考,帶長按鍵檢測的:  http://blog.csdn.net/libiaojs/article/details/9445103
主站蜘蛛池模板: 精品久久av | 精品视频一区二区三区在线观看 | 国产一级在线 | 超碰操| 亚洲视频欧美视频 | 国产精品亚洲欧美日韩一区在线 | 99国产精品久久久 | 国产亚洲一区二区精品 | 97超级碰碰 | 7777奇米影视| 成人黄色电影在线播放 | 最新av在线网址 | 最近日韩中文字幕 | 羞羞视频在线网站观看 | 国产一区二区三区四区在线观看 | 99久久久国产精品 | 成人在线一区二区 | 久久精品视频播放 | 国产精品亚洲综合 | 天堂亚洲网 | 日韩高清三区 | 色黄网站 | 日韩中文字幕视频在线观看 | 精品三区| 精品国产18久久久久久二百 | 亚洲精品视频免费看 | 国产精品久久久久久久久久久久冷 | 免费人成激情视频在线观看冫 | 日韩免费视频一区二区 | 一区二区在线 | 亚洲欧洲日韩精品 中文字幕 | 久久精品网 | 精品一区二区三区四区 | 亚洲最大的成人网 | 成人久久久 | 91国在线 | 成人高清在线视频 | 欧美日韩成人在线观看 | 精品在线一区 | 国产精品观看 | 一区视频 |
