查看: 4452|回復: 0
單片機DAC0832+LM324波形發生器程序設計 Proteus仿真PCB原理圖
ID:786759 發表于 2020-11-26 23:14 | 顯示全部樓層 |閱讀模式
關于8051單片機的波形發生器的設計的程序和原理圖
波形發生器仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
Altium Designer畫的波形發生器原理圖和PCB圖如下:(51hei附件中可下載工程文件)
  1. #include <reg51.h>
  2. #include<string.h>
  4. #define uint unsigned int
  5. sbit RS=P3^0;
  6. sbit RW=P3^1;
  7. sbit EN=P3^3;
  8. sbit K1=P2^0;
  9. sbit K2=P2^1;
  10. sbit K3=P2^2;
  11. sbit K4=P2^3;
  12. sbit K5=P2^4;
  13. uchar WaveChoice=1;
  14. uchar ys=30;
  15. uchar i,a=0;
  16. uchar sqar_num=128;
  17. uint freq;
  18. uchar code Sin[]={"Sine      "};
  19. uchar code Squ[]={"Square    "} ;
  20. uchar code Tri[]={"Triangle  "};
  21. uchar code Saw[]={"Sawtooth  "} ;
  22. uchar code No[]={"No Signal out "};
  23. uchar code Wave[]={"Wave :"};
  24. uchar code Fre[]={"Freq :"};
  25. uchar code tosin[256]=
  26. {0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,
  27. 0xae,0xb1,0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,
  28. 0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1,0xf2,0xf4,
  29. 0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
  30. 0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,
  31. 0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,
  32. 0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,
  33. 0xa8,0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,
  34. 0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,
  35. 0x51,0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,
  36. 0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16,0x15,0x13,0x11,0x10,0x0e,
  37. 0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,
  38. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02 ,0x02,0x03,0x04,
  39. 0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15,0x16,0x18,
  40. 0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,
  41. 0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e ,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66 ,
  42. 0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80 };
  43. void DelayMS(uchar ms)
  44. {
  45.         uchar i;
  46.         while(ms--) for(i=0;i<120;i++);
  47. }
  48. void Delay1(uint y)
  49. {
  50.         uint i;
  51.         for(i=y;i>0;i--);
  52. }
  53. uchar Busy_Check()
  54. {
  55.         uchar LCD_Status;
  56.         RS=0;  //        寄存器選擇
  57.         RW=1; //讀狀態寄存器
  58.         EN=1;  // 開始讀
  59.         DelayMS(1);
  60.         LCD_Status=P1;
  61.         EN=0;
  62.         return  LCD_Status;
  63. }
  64. void Write_LCD_Command(uchar cmd)
  65. {
  66.            while((Busy_Check()&0x80)==0x80);   //忙等待
  67.            RS=0;  //選擇命令寄存器
  68.            RW=0;  //寫
  69.            EN=0;
  70.            P1=cmd;EN=1;DelayMS(1);EN=0;
  71. }
  72. void Write_LCD_Data(uchar dat)
  73. {
  74.          while((Busy_Check()&0x80)==0x80);   //忙等待
  75.           RS=1;  RW=0; EN=0; P1=dat;EN=1;DelayMS(1);EN=0;
  76. }
  77. void Init_LCD()
  78. {
  79.         Write_LCD_Command(0x38);
  80.         DelayMS(1);
  81.         Write_LCD_Command(0x01); //清屏
  82.         DelayMS(1);
  83.         Write_LCD_Command(0x06); //字符進入模式:屏幕不動,字符后移
  84.         DelayMS(1);
  85.         Write_LCD_Command(0x0C); //顯示開、關光標
  86.         DelayMS(1);
  87. }
  88. void Write_freq(uint k)
  89. {
  90.         uchar qian,bai,shi,ge;
  91.         qian=k/1000;
  92.         bai=k/100%10;
  93.         shi=k/10%10;
  94.         ge=k%10;
  95.         Write_LCD_Command(0x86+0x40);
  96.         Write_LCD_Data(0x30+qian);
  97.         Write_LCD_Data(0x30+bai);
  98.         Write_LCD_Data(0x30+shi);
  99.         Write_LCD_Data(0x30+ge);
  100.         Write_LCD_Data(0x48);
  101.         Write_LCD_Data(0x5a);
  102. }
  103.   void Xianshi_f()
  104. {
  105.   if(WaveChoice==1)
  106.   {
  107.      freq=(10000000/(50000+2860*ys));
  108.          Write_freq(freq);
  109.   }
  110.   if(WaveChoice==2)
  111.   {
  112.      freq=(10000000/(50000+2300*ys));
  113.          Write_freq(freq);
  114.   }
  115.    if(WaveChoice==3)
  116.   {
  117.      freq=(10000000/(14000+2300*ys));
  118.          Write_freq(freq);
  119.   }
  120.     if(WaveChoice==4)
  121.   {
  122.      freq=(10000000/(15000+2300*ys));
  123.          Write_freq(freq);
  124.   }
  125. }
  126. void Write_wave(uchar  t )
  127. {
  128.         switch(t)
  129.         {
  130.                 case 0:
  131.                                  Write_LCD_Command(0x86);
  132.                                    DelayMS(5);
  133.                                     for (i=0;i<sizeof(No)-1;i++)
  134.                                         {
  135.                                                 Write_LCD_Data(No[i]);
  136.                                                 DelayMS(5);
  137.                                         }
  138.                                         break;
  139.                 case 1:
  140.                                 ys=25;
  141.                                 Write_LCD_Command(0x86);
  142.                                    DelayMS(5);
  143.                                     for (i=0;i<sizeof(Sin)-1;i++)
  144.                                         {
  145.                                                 Write_LCD_Data(Sin[i]);
  146.                                                 DelayMS(5);
  147.                                         }
  148.                                 break;
  149.                 case 2:
  150.                                 ys=30;
  151.                                 Write_LCD_Command(0x86);
  152.                                    DelayMS(5);
  153.                                     for (i=0;i<sizeof(Squ)-1;i++)
  154.                                         {
  155.                                                 Write_LCD_Data(Squ[i]);
  156.                                                 DelayMS(5);
  157.                                          }
  158.
  159.                                 break;
  160.                 case 3:
  161.                                 ys=30;
  162.                                 Write_LCD_Command(0x86);
  163.                                    DelayMS(5);
  164.                                     for (i=0;i<sizeof(Tri)-1;i++)
  165.                                         {
  166.                                                 Write_LCD_Data(Tri[i]);
  167.                                                 DelayMS(5);
  168.                                         }
  169.                                 break;
  170.                 case 4:
  171.                                 ys=30;
  172.                                    Write_LCD_Command(0x86);//液晶顯示位置
  173.                                    DelayMS(5);
  174.                                     for (i=0;i<sizeof(Saw)-1;i++)
  175.                                         {
  176.                                                 Write_LCD_Data(Saw[i]);
  177.                                                 DelayMS(5);
  178.                                          }
  179.                                 break;
  180.         }
  181. }
  182. void Out_Wave(uchar i)
  183. {         uchar j;
  184.         switch(i)
  185.         {
  186.                 case 0:        P0=0x00;break;
  187.                 case 1:
  188.                                 for (j=0;j<255;j++)
  189.                                 {
  190.                                         P0=tosin[j];
  191.                                         Delay1(ys);
  192.                                 }
  193.                                  break;
  194.                 case 2:
  195.                                                 {
  196.                                         if(a<sqar_num)
  197.                                                 {
  198.                                                         P0=0xff;
  199.                                                         Delay1(ys);
  200.                                                 }
  201.                                         else
  202.                                                 {
  203.                                                         P0=0x00;
  204.                                                         Delay1(ys);
  205.                                                 }
  206.                                                 a++;
  207.                                 }  break;
  208.                 case 3:
  209.                                 {
  210.                                         if(a<128)
  211.                                                 {
  212.                                                         P0=a;
  213.                                                         Delay1(ys);
  214.                                                 }
  215.                                         else
  216.                                                 {
  217.                                                         P0=255-a;
  218.                                                         Delay1(ys);
  219.                                                 }
  220.                                                 a++;
  221.                                 }   break;
  222.                 case 4:
  223.                                 {
  224.                                          if(a<255)
  225.                                         {
  226.                                                 P0=a;
  227.                                                 Delay1(ys);
  228.                                         }
  229.
  230.                                 a++;
  231.                         if(a==255)
  232.                                 {
  233.                                         a=0;
  234.                                 }   break;
  235.                 }
  236.         }
  237. }
  238. void keyscanf()
  239. {
  240.         if(K2==0)
  241.         {
  242.                 DelayMS(5);
  243.                 if(K2==0)
  244.                 {
  245.                         while(!K2);
  246.                         ys--;
  247.                         if(ys==0)
  248.                         ys=20;
  249.                 }
  250.         }
  251.         if(K3==0)
  252.         {
  253.                 DelayMS(5);
  254.                 if(K3==0)
  255.                 {
  256.                         while(!K3);
  257.                         ys++;
  258.                         if(ys>22)
  259.                         ys=20;
  260.                 }
  261.         }
  262.         if(K4==0)
  263.         {
  264.                 DelayMS(5);
  265.                 if(K4==0)
  266.                 {
  267.                         while(!K4);
  268.                         if(WaveChoice==2)
  269.                         sqar_num=sqar_num+2;
  270.                         if(sqar_num==238)
  271.                                 sqar_num=128;
  272.                 }
  273.         }
  274.         if(K5==0)
  275.         {
  276.                 DelayMS(5);
  277.                 if(K5==0)
  278.                 {
  279.                         while(!K5);
  280.                         if(WaveChoice==2)
  281.                         sqar_num=sqar_num-2;
  282.                         if(sqar_num==18)
  283.                                 sqar_num=128;
  284.                 }
  285.         }
  286. ……………………
  287. …………限于本文篇幅 余下代碼請從51黑下載附件…………
波形發生器.zip (949.58 KB, 下載次數: 99)
主站蜘蛛池模板: 免费网站观看www在线观 | 午夜精品久久久久 | 亚洲视频在线一区 | 黑人巨大精品欧美一区二区 | 国产免费小视频 | 国产91精品看黄网站在线观看 | 免费观看全黄做爰的视频 | 久操福利| 少妇免费视频 | 日韩看片| 99在线播放 | 精品亚洲国产成人av制服丝袜 | 日韩有码在线视频 | 污视频网站在线观看 | 亚洲免费福利视频 | 青青草免费在线视频 | 国产一区二区三区免费视频 | 国产黄色大片 | 成人午夜在线 | 亚洲精品乱码久久久久久动漫 | 精品一区二区三区视频 | 亚洲欧美日韩一区 | 久久久一本 | 91亚洲精品在线 | 国产精品99久久久久久久久 | 日本午夜网站 | 国产精品一区二区三区不卡 | 青青草网站 | 中文字幕在线观看亚洲 | 亚洲一区久久 | 美女在线播放 | 黄色片免费网站 | 国产激情一区二区三区 | 亚洲男人天堂网 | 999久久久久久久久6666 | 最新中文字幕在线观看 | 免费成人小视频 | 久久久久久久久久久久久久久久久久久 | 国产精品美女久久久久av爽 | 欧美1区2区| 野外(巨肉高h) |
