#include <msp430x14x.h>
#include "displaydata.h"
typedef unsigned char uchar;
typedef unsigned int uint;
//控制位的宏定義
#define BIT(x) (1 << (x))
#define RCLK_1 P3OUT |= BIT3
#define RCLK_0 P3OUT &= ~BIT3
#define cyCS 0 //P3.0,片選信號
#define cySID 1 //P3.1,串行數(shù)據(jù)
#define cyCLK 2 //P3.2,同步時鐘
#define cyPORT P3OUT
#define cyDDR P3DIR
extern const unsigned char shuzi_table[];
uchar flag = 0;
void Send(unsigned char type,unsigned char transdata);
void Ini_Lcd(void);
void Clear_GDRAM(void);
void Disp_HZ(unsigned char addr,const unsigned char * pt,unsigned char num);
void Draw_PM(const unsigned char *ptr);
void Draw_TX(unsigned char Yaddr,unsigned char Xaddr,const unsigned char * dp) ;
void Disp_SZ(unsigned char addr,unsigned char shuzi);
函數(shù)名稱:delay_Nus
功 能:延時N個us的時間
參 數(shù):n--延時長度
返回值 :無
void delay_Nus(uint n)
uchar i;
for(i = n;i > 0;i--)
_NOP();
函數(shù)名稱:delay_1ms
功 能:延時約1ms的時間
參 數(shù):無
返回值 :無
void delay_1ms(void)
uchar i;
for(i = 150;i > 0;i--) _NOP();
函數(shù)名稱:delay_Nms
功 能:延時N個ms的時間
參 數(shù):無
返回值 :無
void delay_Nms(uint n)
uint i = 0;
delay_1ms();
函數(shù)名稱:Ini_Lcd
功 能:初始化液晶模塊
參 數(shù):無
返回值 :無
void Ini_Lcd(void)
cyDDR |= BIT(cyCLK) + BIT(cySID) + BIT(cyCS); //相應(yīng)的位端口設(shè)置為輸出
delay_Nms(100); //延時等待液晶完成復(fù)位
Send(0,0x30); /*功能設(shè)置:一次送8位數(shù)據(jù),基本指令集*/
delay_Nus(72);
Send(0,0x02); /*DDRAM地址歸位*/
delay_Nus(72);
Send(0,0x0c); /*顯示設(shè)定:開顯示,不顯示光標(biāo),不做當(dāng)前顯示位反白閃動*/
delay_Nus(72);
Send(0,0x01); /*清屏,將DDRAM的位址計數(shù)器調(diào)整為“00H”*/
delay_Nus(72);
Send(0,0x06); /*功能設(shè)置,點設(shè)定:顯示字符/光標(biāo)從左到右移位,DDRAM地址加1*/
delay_Nus(72);
函數(shù)名稱:Send
功 能:MCU向液晶模塊發(fā)送1一個字節(jié)的數(shù)據(jù)
參 數(shù):type--數(shù)據(jù)類型,0--控制命令,1--顯示數(shù)據(jù)
transdata--發(fā)送的數(shù)據(jù)
返回值 :無
void Send(uchar type,uchar transdata)
uchar firstbyte = 0xf8;
uchar temp;
uchar i,j = 3;
if(type) firstbyte |= 0x02;
cyPORT |= BIT(cyCS);
cyPORT &= ~BIT(cyCLK);
while(j > 0)
if(j == 3) temp = firstbyte;
else if(j == 2) temp = transdata&0xf0;
else temp = (transdata << 4) & 0xf0;
for(i = 8;i > 0;i--)
if(temp & 0x80) cyPORT |= BIT(cySID);
else cyPORT &= ~BIT(cySID);
cyPORT |= BIT(cyCLK);
temp <<= 1;
//三個字節(jié)之間一定要有足夠的延時,否則易出現(xiàn)時序問題
if(j == 3) delay_Nus(600);
else delay_Nus(200);
j--;
cyPORT &= ~BIT(cyCS);
函數(shù)名稱:Clear_GDRAM
功 能:清除液晶GDRAM內(nèi)部的隨機數(shù)據(jù)
參 數(shù):無
返回值 :無
uchar i,j,k;
Send(0,0x34); //打開擴展指令集
i = 0x80;
for(j = 0;j < 32;j++)
Send(0,i++);
Send(0,0x80);
for(k = 0;k < 16;k++)
Send(1,0x00);
i = 0x80;
Send(0,i++);
Send(0,0x88);
Send(1,0x00);
Send(0,0x30); //回到基本指令集
函數(shù)名稱:Disp_HZ
功 能:顯示漢字程序
參 數(shù):addr--顯示位置的首地址
pt--指向顯示數(shù)據(jù)的指針
num--顯示數(shù)據(jù)的個數(shù)
返回值 :無
void Disp_HZ(uchar addr,const uchar * pt,uchar num)
uchar i;
Send(0,addr);
for(i = 0;i < (num*2);i++)
Send(1,*(pt++));
函數(shù)名稱:Draw_PM
功 能:在整個屏幕上畫一個圖片
參 數(shù):ptr--指向保存圖片位置的指針
返回值 :無
void Draw_PM(const uchar *ptr)
uchar i,j,k;
i = 0x80;
Send(0,i++);
Send(0,0x80);
Send(1,*ptr++);
i = 0x80;
Send(0,i++);
Send(0,0x88);
Send(1,*ptr++);
Send(0,0x36); //打開繪圖顯示
函數(shù)名稱:Draw_TX
功 能:在液晶上描繪一個16*16的圖形
參 數(shù):Yaddr--Y地址,
Xaddr--X地址
dp--指向保存圖形數(shù)據(jù)的指針
返回值 :無
void Draw_TX(uchar Yaddr,uchar Xaddr,const uchar * dp)
uchar j;
uchar k = 0;
Send(0,0x34); //使用擴展指令集,關(guān)閉繪圖顯示
for(j = 0;j < 16;j++)
Send(0,Yaddr++); //Y地址
Send(0,Xaddr); //X地址
Send(1,dp[k++]); //送兩個字節(jié)的顯示數(shù)據(jù)
Send(1,dp[k++]);
Send(0,0x30); //回到基本指令集模式
函數(shù)名稱:Disp_SZ
功 能:顯示一個兩位數(shù)字
參 數(shù):addr--顯示地址
數(shù)字--顯示的數(shù)字
返回值 :無
void Disp_SZ(uchar addr,uchar shuzi)
uchar tmp0,tmp1;
tmp0 = shuzi / 10;
tmp1 = shuzi % 10;
Send(0,addr);
Send(1,shuzi_table[tmp0]);
Send(1,shuzi_table[tmp1]);
/************************主函數(shù)***********************/
void main(void)
uchar i,j;
WDTCTL = WDTPW + WDTHOLD; //關(guān)閉看門狗
TACTL = TASSEL_1 + MC_1; //計數(shù)時鐘ACLK, 增計數(shù)模式
CCR0 = 32768 - 1;
CCTL0 |= CCIE; //使能CCR0比較中斷
_EINT();
Ini_Lcd();
while(1){
Disp_HZ(0x81,line1,6);
Disp_HZ(0x8a,line2,4);
flag = 0;
while(flag < 3); //等待三秒鐘
Send(0,0x01); //清屏
CCR0 = (32768 - 1) / 5;
flag = 0;
for(i = 0; i < 4; i++)
Send(0, 0x0f); //打開游標(biāo)
switch(i)
case 0: Send(0,0x81);break;
case 1: Send(0,0x91);break;
case 2: Send(0,0x89);break;
case 3: Send(0,0x99);break;
for(j = 0; j < 12; j++)
Send(1, shige[i*12 + j]);
if(j == 11)
Send(0, 0x0c); //關(guān)閉游標(biāo)
flag = 0;
while(!flag); //等待1/5秒
CCR0 = 32768 - 1;
flag = 0;
while(flag < 2); //等待2秒鐘
Send(0,0x01); //清屏
Draw_PM(school); //顯示文字型畫面
flag = 0;
Draw_PM(QQ); //顯示QQ形象
flag = 0;
Send(0,0x01); //清屏
Disp_HZ(0x92,jieshu,4); //結(jié)束文字
函數(shù)名稱:TimerA_ISR
功 能:定時器A的中斷服務(wù)函數(shù)
參 數(shù):無
返回值 :無
#pragma vector=TIMERA0_VECTOR
__interrupt void TimerA_ISR(void)
flag++;
