查看: 4015|回復: 3
一個用C#寫的小學數學出題聯系系統源代碼
ID:851418 發表于 2020-11-29 23:26 | 顯示全部樓層 |閱讀模式
c#寫的小學數學二年級自動出題系統,實現自動隨機出題;四則運算。對于剛學C#的朋友掌握光標獲取、鎖定光標,TAB切換、回車鍵綁定、隨機數產生、列表框顯示運用等有幫助!
源程序如下:
  1. using System;
  2. using System.Collections.Generic;
  3. using System.ComponentModel;
  4. using System.Data;
  5. using System.Drawing;
  6. using System.Linq;
  7. using System.Text;
  8. using System.Threading.Tasks;
  9. using System.Windows.Forms;
  10. namespace WindowsFormsApp4
  11. {
  12.     public partial class Form1 : Form
  13.     {
  14.         public Form1()
  15.         {
  16.             InitializeComponent();
  17.         }
  18.         int a, b,aaa,bbb,bb;
  19.         string op;
  20.          string op1;
  21.          string op2;
  22.          int result;
  23.          int result1;
  24.          int result2;
  25.
  26.
  27.         Random rnd = new Random();
  28.         private void Form1_Load(object sender, EventArgs e)
  29.         {
  30.
  31.
  32.         }
  33.         private void Button1Click(object sender, EventArgs e)
  34.         {
  35.
  36.             a = rnd.Next(10) + 1;
  37.             b = rnd.Next(10) + 1;
  38.             if (a<=b)
  39.                     a=a+b;
  40.
  41.
  42.             aaa = rnd.Next(10) + 1;
  43.             bbb = rnd.Next(10) + 1;
  44.              if (aaa<=bbb)
  45.                     aaa=aaa+bbb;
  46.             bb = rnd.Next(8) + 1;
  47.             int c = rnd.Next(3);
  48.             int cc = rnd.Next(3);
  49.                         int ccc = rnd.Next(2);
  50.             switch (c)
  51.             {
  52.                 case 0: op = "+"; result = a + b; break;
  53.                 case 1: op = "-"; result = a - b; break;
  54.                 case 2: op = "×"; result = a * b; break;
  55.                 case 3: op = "÷"; result = a / b; break;
  56.             }
  57.               switch (cc)
  58.             {
  59.                 case 0: op1 = "+"; result1 = aaa + bbb ; break;//OP1表示當前運算符號和結果,運算結果result1等于加數+加數
  60.                 case 1: op1 = "-"; result1 = aaa - bbb ; break;//OP1表示當前運算符號和結果,運算結果result1等于被減數-減數
  61.                 case 2: op1 = "×"; result1 = aaa * bbb ; break;//OP1表示當前運算符號和結果,運算結果result1等于乘數*乘數
  62.                 case 3: op1 = "÷"; result1 = aaa / bbb ; break;//OP1表示當前運算符號和結果,運算結果result1等于除數/除數
  63.             }
  64.                switch (ccc)
  65.             {
  66.                 case 0: op2 = "+"; result2 = result1 +  bb; break;
  67.
  68.                 case 1: op2 = "×"; result2 = result1 *  bb; break;
  69.
  70.             }
  71.
  72.                     textBox2.Text = a.ToString();//算式1中的從左邊到右第一個數
  73.             textBox3.Text = b.ToString();//算式1中的從左邊到右第二個數
  74.
  75.             textBox4.Text = aaa.ToString();//算式2中的從左邊到右第一個數
  76.             textBox5.Text = bbb.ToString();//算式2中的從左邊到右第二個數
  77.             textBox6.Text = bb.ToString();//算式2中的從左邊到右第三個數
  78.             label2.Text = op;//算式1中的運算符號,隨機產生對應的符號
  79.             label1.Text = op1;//算式2中的運算符號,隨機產生對應的符號
  80.             label6.Text = op2;//算式2中的運算符號,隨機產生對應的符號
  81.             textBox1.Text="";//按鍵后清空文本框的內容!
  82.             textBox7.Text="";//按鍵后清空文本框的內容!
  83.             textBox1.Focus();
  84.         }
  85.         private void Button2Click(object sender, EventArgs e)
  86.         {
  87.
  88.                 //if (textBox1.Text =="")
  89.                 //        MessageBox.Show("請輸入數字,不能為空");
  90.
  91.                 //else
  92.                         // MessageBox.Show("輸入的數字正確");
  93.
  94.
  95.           if (textBox1.Text  == "")//判斷是否輸入的用戶名,如果沒有輸入,顯示下面的提示,否則跳到else
  96.             {
  97.                 MessageBox.Show("答案不能為空!", "警告", MessageBoxButtons.OK, MessageBoxIcon.Warning);
  98.             }
  99.           if  (textBox7.Text  == "")//判斷是否輸入的用戶名,如果沒有輸入,顯示下面的提示,否則跳到else
  100.             {
  101.                 MessageBox.Show("答案不能為空!", "警告", MessageBoxButtons.OK, MessageBoxIcon.Warning);
  102.             }
  103.             else
  104.                 {
  105.                     string str = textBox1.Text;//文本框輸入為等式的結果,結果答案輸入處。
  106.                     string str1 = textBox7.Text;
  107.
  108.                  double d = double.Parse(str);
  109.             double dd = double.Parse(str1);
  110.                  string disp =  "       " + a + op + b + "=" + str + " ";
  111.                            string disp1 = "       " + aaa + op1 + bbb + op2 + bb + "=" + str1 + " ";
  112.
  113.
  114.
  115.            if (d == result) // if( Math.Abs(d-result)< 1e-3 )
  116.
  117.                     disp += "√       答案正確       劉穎穎你真棒";
  118.
  119.             else
  120.
  121.                           disp += "╳       答案錯誤       加油重新列算式運算";
  122.              if (dd == result2) // if( Math.Abs(d-result)< 1e-3 )
  123.                      disp1 += "√       答案正確       劉穎穎你真棒";
  124.
  125.                      else
  126.                 disp1 += "╳       答案錯誤       加油重新列算式運算";
  127.
  128.                                   lstDisp.Items.Add(disp);
  129.                                   lstDisp.Items.Add(disp1);
  130.                                   textBox1.Text="";//清空上一次輸入的結果!
  131.                                   textBox7.Text="";//清空上一次輸入的結果!
  132.
  133.             }
  134.
  135.     }
  136.                 void TextBox1KeyPress(object sender, KeyPressEventArgs e)
  137.                 {
  138.                         if(!(char.IsNumber(e.KeyChar))&& e.KeyChar !=(char)8)
  139.                         {
  140.                                 e.Handled = true;//判定為數字,可以輸入
  141.                         }
  142.                 }
  143.                 void LstDispSelectedIndexChanged(object sender, EventArgs e)
  144.                 {
  145.                         if (lstDisp.Text.Length >10)
  146.                                 lstDisp.Text = "";
  147.                 }
  148.                 void TextBox7KeyPress(object sender, KeyPressEventArgs e)
  149.                 {
  150.         if(!(char.IsNumber(e.KeyChar))&& e.KeyChar !=(char)8)
  151.                         {
  152.                                 e.Handled = true;//判定為數字,可以輸入
  153.                         }
  154.                 }
  155.                 void Button3Click(object sender, EventArgs e)
  156.                 {
  157.                         lstDisp.Items.Clear();
  158.                 }
  159.
  160.     }
  161. }
全部資料51hei下載地址:
運算1.4版本.7z (4.44 MB, 下載次數: 20)
ID:851418 發表于 2020-11-30 00:56 | 顯示全部樓層
怎么上傳附件
ID:328014 發表于 2020-12-2 05:46 | 顯示全部樓層
ID:563034 發表于 2021-8-7 15:06 | 顯示全部樓層
不錯,學習了。實測可運行
主站蜘蛛池模板: 色男人的天堂 | 殴美黄色录像 | 国产免费一区二区三区最新6 | 欧美专区在线观看 | 国产精品18久久久久久白浆动漫 | 国产欧美日韩在线 | 日本高清中文字幕 | 免费在线观看一区二区三区 | 中文字幕二区 | 亚洲精品一区二区三区在线 | 在线视频99 | 精品视频久久久 | 国产成人精品久久久 | 欧美美女一区二区 | 日韩在线视频免费观看 | 精品国产乱码久久久久久蜜柚 | 91成人在线 | 欧美激情精品久久久久久免费 | 欧美一区二区免费 | 亚洲精品色 | 91影院| av天天看 | 影音先锋中文字幕在线观看 | 国产精品综合色区在线观看 | 一级片毛片 | 亚洲国产精品人人爽夜夜爽 | 国产一区二区三区四区三区四 | 男女视频免费 | 国产成人精品一区二区三区四区 | 午夜天堂精品久久久久 | 日韩av网址在线观看 | 亚洲国产一区二区三区 | 盗摄精品av一区二区三区 | 日韩在线中文 | 99久久久久国产精品免费 | 99re视频在线| 久久国产亚洲 | 日韩一区二区三区在线 | 色播99| 成人妇女免费播放久久久 | 欧美精品二区三区 |
