- #include "led_seg.h"
- #include "key.h"
- #include "mymath.h"
- typedef enum
- OPERATOR_EMPTY,
- OPERATOR_PLUS,
- OPERATOR_MINUS,
- OPERATOR_MULTIPLY,
- OPERATOR_DIVIDE,
- OPERATOR_EQUAL
- } OPERATOR;
- typedef enum
- STATE_INIT,
- STATE_INPUT_FIRST_NUM,
- STATE_INPUT_SECOND_NUM,
- STATE_CALC_SIGN,
- STATE_EQUAL
- } STATE;
- u8 timer = 0;
- double show_number = 0;
- // 用來標記小數點是否按下
- bit is_dot_press = 0;
- // 用來記錄小數點按下后鍵盤按下的數的數量
- u8 after_dot_press_number = 0;
- // (float) 等價于 (double) 6位有效數字
- void Timer0Init(void);
- void Timer0Interrupt(void);
- void update_show_number(u8);
- void update_calc_sign(OPERATOR);
- double first_number = 0;
- double second_number = 0;
- OPERATOR myoperator = OPERATOR_EMPTY;
- STATE state = STATE_INIT;
- void main()
- Timer0Init();
- while(1)
- keyscan();
- if(NO_KEY_PRESS != key_state)
- switch(key_state)
- // 1
- case 0:
- update_show_number(1);
- break;
- // 2
- case 1:
- update_show_number(2);
- break;
- // 3
- case 2:
- update_show_number(3);
- break;
- case 3:
- update_calc_sign(OPERATOR_PLUS);
- break;
- // 4
- case 4:
- update_show_number(4);
- break;
- // 5
- case 5:
- update_show_number(5);
- break;
- // 6
- case 6:
- update_show_number(6);
- break;
- case 7:
- update_calc_sign(OPERATOR_MINUS);
- break;
- // 7
- case 8:
- update_show_number(7);
- break;
- // 8
- case 9:
- update_show_number(8);
- break;
- // 9
- case 10:
- update_show_number(9);
- break;
- case 11:
- update_calc_sign(OPERATOR_MULTIPLY);
- break;
- case 12:
- is_dot_press = 1;
- break;
- // 0
- case 13:
- update_show_number(0);
- break;
- case 14:
- switch(state)
- case STATE_INIT:
- case STATE_EQUAL:
- case STATE_INPUT_FIRST_NUM:
- first_number = show_number;
- state = STATE_EQUAL;
- myoperator = OPERATOR_EMPTY;
- break;
- case STATE_INPUT_SECOND_NUM:
- second_number = show_number;
- switch(myoperator)
- case OPERATOR_PLUS:
- show_number = first_number + second_number;
- break;
- case OPERATOR_MINUS:
- show_number = first_number - second_number;
- break;
- case OPERATOR_MULTIPLY:
- show_number = first_number * second_number;
- break;
- case OPERATOR_DIVIDE:
- if(0.000000 != second_number)
- show_number = first_number / second_number;
- else
- // warning
- show_number = 0;
- break;
- default:
- break;
- is_dot_press = 0;
- after_dot_press_number = 0;
- first_number = 0;
- second_number = 0;
- break;
- case STATE_CALC_SIGN:
- break;
- default:
- break;
- break;
- case 15:
- update_calc_sign(OPERATOR_DIVIDE);
- break;
- //意外情況的處理
- default:
- break;
- key_state = NO_KEY_PRESS;
- void Timer0Init(void) //100微秒@12.000MHz
- TMOD &= 0xF0; //設置定時器模式
- TMOD |= 0x02; //設置定時器模式
- TL0 = 0x9C; //設置定時初值
- TH0 = 0x9C; //設置定時重載值
- TF0 = 0; //清除TF0標志
- TR0 = 1; //定時器0開始計時
- ET0 = 1;
- EA = 1;
- void Timer0Interrupt(void) interrupt 1
- timer++;
- if(10 == timer)
- LedShowByNum(show_number);
- timer = 0;
- keyrescan();
- void update_show_number(u8 number)
- switch(state)
- case STATE_INIT:
- case STATE_EQUAL:
- show_number = 0;
- first_number = 0;
- state = STATE_INPUT_FIRST_NUM;
- break;
- break;
- break;
- second_number = show_number = 0;
- state = STATE_INPUT_SECOND_NUM;
- break;
- default:
- break;
- if(is_dot_press)
- after_dot_press_number++;
- show_number += number / ((double)mypow(10,after_dot_press_number));
- else
- show_number *= 10;
- show_number += number;
- switch(state)
- break;
- break;
- default:
- break;
- void update_calc_sign(OPERATOR opr)
- switch(state)
- case STATE_INIT:
- first_number = 0;
- myoperator = opr;
- state = STATE_CALC_SIGN;
- break;
- case STATE_EQUAL:
- myoperator = opr;
- break;
- is_dot_press = 0;
- break;
- break;
- break;
- else
- is_dot_press = 0;
- // warning
- show_number = 0;
- first_number = 0;
- state = STATE_INIT;
- return;
- break;
- default:
- break;
- myoperator = opr;
- break;
- break;
復制代碼 全部資料51hei下載地址(仿真+程序):
09-實現一個簡便的計算器.7z
(116.72 KB, 下載次數: 47)
2020-12-4 15:23 上傳
點擊文件名下載附件
