查看: 5736|回復: 4
esp8266局域網控制系統制作
  1.     wifi.setmode(wifi.SOFTAP)
  2.         cfg={}
  3.         cfg.ssid="ESP8266";
  4.         cfg.pwd="12345678"
  5.         wifi.ap.config(cfg)
  6.         print(wifi.ap.getip())
  7.     led0 = 0
  8.     led1 = 1
  9.         led2 = 2
  10.     led3 = 3
  11.         led4 = 4
  12.     led5 = 5
  13.         led6 = 6
  14.     gpio.mode(led0, gpio.OUTPUT)
  15.     gpio.mode(led1, gpio.OUTPUT)
  16.         gpio.mode(led2, gpio.OUTPUT)
  17.     gpio.mode(led3, gpio.OUTPUT)
  18.         gpio.mode(led4, gpio.OUTPUT)
  19.     gpio.mode(led5, gpio.OUTPUT)
  20.         gpio.mode(led6, gpio.OUTPUT)
  21.         gpio.write(led0, gpio.LOW);
  22.         gpio.write(led1, gpio.LOW);
  23.         gpio.write(led2, gpio.LOW);
  24.         gpio.write(led3, gpio.LOW);
  25.         gpio.write(led4, gpio.LOW);
  26.         gpio.write(led5, gpio.LOW);
  27.         gpio.write(led6, gpio.LOW);
  28.     srv=net.createServer(net.TCP)
  29.     srv:listen(80,function(conn)
  30.         conn:on("receive", function(client,request)
  31.             local buf = "";
  32.             local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
  33.             if(method == nil)then
  34.                 _, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP");
  35.             end
  36.             local _GET = {}
  37.             if (vars ~= nil)then
  38.                 for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do
  39.                     _GET[k] = v
  40.                 end
  41.             end
  42.             buf = buf.."<h1> 遠程控制系統 </h1>";
  43.             buf = buf.."<p>臥室 <a href=\"?pin=ON0\"><button>開</button></a> <a href=\"?pin=OFF0\"><button>關</button></a></p>";
  44.             buf = buf.."<p>書房 <a href=\"?pin=ON1\"><button>開</button></a> <a href=\"?pin=OFF1\"><button>關</button></a></p>";
  45.                         buf = buf.."<p>廚房 <a href=\"?pin=ON2\"><button>開</button></a> <a href=\"?pin=OFF2\"><button>關</button></a></p>";
  46.                         buf = buf.."<p>廁所 <a href=\"?pin=ON3\"><button>開</button></a> <a href=\"?pin=OFF3\"><button>關</button></a></p>";
  47.                         buf = buf.."<p>客廳 <a href=\"?pin=ON4\"><button>開</button></a> <a href=\"?pin=OFF4\"><button>關</button></a></p>";
  48.                         buf = buf.."<p>草坪燈 <a href=\"?pin=ON5\"><button>開</button></a> <a href=\"?pin=OFF5\"><button>關</button></a></p>";
  49.                         buf = buf.."<p>排風扇 <a href=\"?pin=ON6\"><button>開</button></a> <a href=\"?pin=OFF6\"><button>關</button></a></p>";
  50.             local _on,_off = "",""
  51.             if(_GET.pin == "ON1")then
  52.                   gpio.write(led1, gpio.HIGH);
  53.             elseif(_GET.pin == "OFF1")then
  54.                   gpio.write(led1, gpio.LOW);
  55.             elseif(_GET.pin == "ON2")then
  56.                   gpio.write(led2, gpio.HIGH);
  57.             elseif(_GET.pin == "OFF2")then
  58.                   gpio.write(led2, gpio.LOW);
  59.                         elseif(_GET.pin == "ON0")then
  60.                   gpio.write(led0, gpio.HIGH);
  61.             elseif(_GET.pin == "OFF0")then
  62.                   gpio.write(led0, gpio.LOW);
  63.                         elseif(_GET.pin == "ON3")then
  64.                   gpio.write(led3, gpio.HIGH);
  65.             elseif(_GET.pin == "OFF3")then
  66.                   gpio.write(led3, gpio.LOW);
  67.                         elseif(_GET.pin == "ON4")then
  68.                   gpio.write(led4, gpio.HIGH);
  69.             elseif(_GET.pin == "OFF4")then
  70.                   gpio.write(led4, gpio.LOW);
  71.                         elseif(_GET.pin == "ON5")then
  72.                   gpio.write(led5, gpio.HIGH);
  73.             elseif(_GET.pin == "OFF5")then
  74.                   gpio.write(led5, gpio.LOW);
  75.                         elseif(_GET.pin == "ON6")then
  76.                   gpio.write(led6, gpio.HIGH);
  77.             elseif(_GET.pin == "OFF6")then
  78.                   gpio.write(led6, gpio.LOW);
  79.             end
  80.             client:send(buf);
  81.             client:close();
  82.             collectgarbage();
  83.         end)
  84.     end)
收藏收藏5 分享淘帖 頂 踩
ID:568565 發表于 2020-12-4 16:35 | 只看該作者
本設備基于智能家居的基本框架、 主控選擇 Nodemcu, 操作 ESP8266 實現互聯網的連接
并建立網頁服務器, 通過手機或其他聯網設備及各種智能終端可以進行網頁連接, 通過網頁端
可以查看各用電設備的開關情況, 進而進行遠程控制各種用電設備, 實現無線遠程控制的功能。
ID:849826 發表于 2020-12-8 17:23 來自觸屏版 | 只看該作者
這是8266的程序嗎,用的8266-12F?這么多輸出端口。8266-01S可沒有這么多端口
ID:88256 發表于 2020-12-29 23:42 | 只看該作者
6313 發表于 2020-12-8 17:23
已經說明“主控選擇 Nodemcu”,你可以上X寶搜索 Nodemcu 就知道了
ID:568565 發表于 2021-1-10 14:09 | 只看該作者
NOdeMCU的,esp8266-12F刷Lua固件應該也可以的
主站蜘蛛池模板: 亚洲在线视频 | 欧美视频在线观看 | 久久午夜影院 | 欧美日韩精品一区二区 | 欧美一级片免费看 | 四虎视频| 99热播| 国产又粗又猛视频免费 | 简单av网 | 国产一区在线观看视频 | 毛片中文字幕 | 国产日韩久久 | 羞羞网站在线观看 | 国产欧美在线观看 | 五月色丁香 | 成人免费高清 | 日皮视频免费看 | 一级黄色在线观看 | 亚洲视频免费在线观看 | 好色综合| 亚洲欧美在线播放 | 成年人黄色网址 | 国产成人午夜高潮毛片 | 一区二区免费 | 丰满少妇在线观看网站 | av资源在线 | 夜夜爽天天爽 | 懂色av懂色av粉嫩av | 18在线观看免费入口 | 亚洲免费在线播放 | 深夜福利网址 | 97视频在线免费观看 | 女同一区二区 | 亚洲免费婷婷 | www.黄色片 | 一级黄色小视频 | 久久网页| 97精品国产 | 成人欧美一区二区三区白人 | 日本黄色免费视频 | 亚洲国产精品久久 |
