本帖最后由 dori 于 2020-12-18 23:10 編輯
完成一個體重計算器的應用程序開發。
MainActivity文件: import androidx.appcompat.app.AppCompatActivity;
import android.content.Intent;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.RadioGroup;
public class MainActivity extends AppCompatActivity {
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
Button bn=findViewById(R.id.bn);
final RadioGroup male=findViewById(R.id.male);
//綁定監視器
bn.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View v) {
EditText et = findViewById(R.id.editText);
Boolean sex = male.getCheckedRadioButtonId()==R.id.rb1?true:false;//true為男,false為女
String height = et.getText().toString();
//創建Intent
Intent intent = new Intent(MainActivity.this, Activity.class);
intent.putExtra("sex", sex);
intent.putExtra("height", height);
startActivity(intent);
Activity.java文件:
import android.widget.TextView;
public class Activity extends AppCompatActivity {
@Override
setContentView(R.layout.result);
TextView tv1 = findViewById(R.id.gender);
TextView tv2 = findViewById(R.id.height);
TextView tv3 = findViewById(R.id.weight);
//獲得intent
Intent intent = getIntent();
//獲得性別和身高信息
Boolean sex =intent.getBooleanExtra("sex", true);
Integer height = Integer.parseInt(intent.getStringExtra("height"));
if (sex) //男
tv1.setText("你是一名男性");
tv2.setText("你的身高是" + height + "厘米");
Double weight = (height - 80) * 0.7;
tv3.setText("你的標準體重是" + weight + "公斤");
} else {
tv1.setText("你是一名女性");
Double weight = (height - 70) * 0.6;
activity_main.xml文件:
<?xml version="1.0" encoding="utf-8"?>
<androidx.constraintlayout.widget.ConstraintLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
xmlns:tools="http://schemas.android.com/tools"
android:layout_width="match_parent"
android:layout_height="match_parent"
tools:context=".MainActivity">
<LinearLayout
android:id="@+id/linearLayout"
android:orientation="vertical"
app:layout_constraintTop_toTopOf="parent"
tools:layout_editor_absoluteX="-148dp">
<TextView
android:id="@+id/textView2"
android:layout_height="40dp" />
<TextView
android:id="@+id/textView"
android:layout_height="wrap_content"
android:text="計算標準體重"
android:textSize="30sp" />
<TableRow
android:orientation="vertical">
<TextView
android:id="@+id/textView3"
android:layout_width="73dp"
android:text="性別:"
android:textSize="20sp" />
<RadioGroup
android:id="@+id/male"
android:layout_width="337dp"
android:orientation="horizontal">
<RadioButton
android:id="@+id/rb1"
android:layout_width="142dp"
android:text="男性"
<RadioButton
android:id="@+id/rb2"
android:layout_width="147dp"
android:text="女性"
</RadioGroup>
</TableRow>
<TableRow
android:layout_height="wrap_content">
<TextView
android:id="@+id/height"
android:text="身高:"
<EditText
android:id="@+id/editText"
android:layout_width="175dp"
android:ems="10"
android:inputType="number"
android:textColor="#E91E63" />
<TextView
android:id="@+id/textView5"
android:layout_width="72dp"
android:text="cm"
</TableRow>
<TableRow
android:layout_width="400dp"
android:layout_height="60dp">
<TextView
android:id="@+id/textView6"
android:layout_width="314dp"
android:layout_height="wrap_content" />
<Button
android:id="@+id/bn"
android:layout_width="wrap_content"
android:text="計算"
android:textSize="25sp" />
</TableRow>
</LinearLayout>
</androidx.constraintlayout.widget.ConstraintLayout>
result.xml文件:
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical" android:layout_width="match_parent"
android:layout_height="match_parent">
<TextView
android:id="@+id/textView10"
android:layout_height="158dp" />
<TextView
android:id="@+id/gender"
android:layout_height="52dp" />
<TextView
<TextView
android:id="@+id/weight"
</LinearLayout>
使用Intent在Activity間傳輸數據.rar
(8.52 MB, 下載次數: 5)
2020-12-18 23:09 上傳
點擊文件名下載附件
