查看: 2448|回復: 0
邏輯回歸算法 Python源程序
ID:780408 發表于 2020-12-18 11:03 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
Python源程序如下:
  1. import pandas as pd
  2. import numpy as np
  3. test = pd.read_table('horseColicTest.txt',header=None)
  4. train = pd.read_table('horseColicTraining.txt',header=None)
  5. train.head()
  6. train.shape
  7. train.info()
  8. print(train.head())
  9. # print(test)
  10. # print(train)
  11. #
  12. # def sigmoid(inX):
  13. #     s = 1/(1+np.exp(-inX))
  14. #     return s
  15. # def classify(inX,weight):
  16. #     p = sigmoid(sum(inX*weight))
  17. #     if p <0.5:
  18. #         return 0
  19. #     else:
  20. #         return 1
  21. # def regularize(xMat):
  22. #     inMat = xMat.copy()
  23. #     inMeans = np.mean(inMat,axis = 0)
  24. #     inVar = np.std(inMat,axis = 0)
  25. #     inMat = (inMat-inMeans)/inVar
  26. #     return inMat
  27. # def SGD_LR(dataSet,alpha=0.001,maxCycles=500):
  28. #     dataSet = dataSet.sample(maxCycles,replace=True)
  29. #     dataSet.index = range(dataSet.shape[0])
  30. #     xMat = np.mat(dataSet.iloc[:,:-1].values)
  31. #     yMat = np.mat(dataSet.iloc[:,-1].values).T
  32. #     xMat = regularize(xMat)
  33. #     m,n = xMat.shape
  34. #     weights = np.zeros((n,1))
  35. #     for i in range(m):
  36. #         grad = xMat[i].T*(xMat[i]*weights-yMat[i])
  37. #         weights = weights-alpha*grad
  38. #     return weights
  39. #
  40. # def get_acc(train,test,alpha=0.001,maxCycles=5000):
  41. #     weights = SGD_LR(train,alpha,maxCycles=maxCycles)
  42. #     xMat = np.mat(test.iloc[:,:-1].values)
  43. #     xMat = regularize(xMat)
  44. #     result = []
  45. #     for inX in xMat:
  46. #         label = classify(inX,weights)
  47. #         result = []
  48. #         for inX in xMat:
  49. #             label = classify(inX,weights)
  50. #             result.append(label)
  51. #         retest = test.copy()
  52. #         retest['predict']=result
  53. #         acc= (retest.iloc[:,-1]==retest.iloc[:,-2]).mean()
  54. #         print(f'模型準確率為:{acc}')
  55. #         return retest
  56. # print(get_acc(train,test,alpha=0.001,maxCycles=5000))
  57. #
全部資料51hei下載地址:
邏輯回歸算法.zip (15.02 KB, 下載次數: 12)
主站蜘蛛池模板: 成人一级视频 | 日韩欧美在线观看 | 欧美日韩性 | 国产欧美视频在线观看 | 国产精品va | 丁香花在线观看 | 国产精品毛片va一区二区三区 | 金银在线 | 黄av在线| 黄色三级视频网站 | 九九在线观看高清免费 | 国产三级在线播放 | 黄色国产视频 | 特黄一级片 | 午夜久久精品 | 免费看大片a| 国产又粗又长又爽 | 色婷婷av一区二区 | 日韩在线一区二区三区 | 一级黄色免费看 | 国产精品免费在线播放 | 午夜国产在线观看 | 日本少妇做爰全过程毛片 | 亚洲激情欧美激情 | 国产精品视频免费在线观看 | 久久久久久久久久久久久久久久久久久 | 国产三级午夜理伦三级 | 色人人 | 国产在线中文字幕 | 亚洲一二区 | 深夜视频在线观看 | 午夜视频免费看 | 9999精品视频 | 成年在线观看 | 久久h| 欧美激情综合 | 久久久久婷婷 | 日韩精品久久久久久久酒店 | 中文字幕亚洲综合 | 天堂а√在线中文在线新版 | 免费黄网站在线观看 |
