查看: 4144|回復: 4
51單片機LCD1602計算器,如何改這個程序,把P3. 0口設(shè)置為可以十進制轉(zhuǎn)二進制的按鈕。
ID:861681 發(fā)表于 2020-12-22 00:32 來自觸屏版 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
10黑幣
#include "reg51.h"
#include "stdio.h"
#include "string.h"
#include "stdlib.h"
typedef unsigned char uint8;
typedef  int uint16;
#define over_result_h 10000
#define over_result_l -10000
#define key P1
#define key2 P3//...............新按鈕加p3口
sbit beep=P2^3;
sbit rw=P2^1;
sbit rs=P2^0;
sbit e=P2^2;
sbit k1=P3^0;//...............新加P3.0按鈕鍵
uint8 flag;
uint8 flag_denghao=0;
uint8 flag_result=0;
char zifu[30];
int k=0;
long        p=0;
uint8 anjian,num,i;
long jieguo=0;
unsigned char addflag=0,subflag=0,mulflag=0,divflag=0,changeflag=0;
long sum1=0;
void delay(uint16 z)
   while(z--);
void delayms(uint16 x)
        int i=0,j=0;
for(i=0;i<x;i++)
        for(j=0;j<110;j++);
//.................寫命令函數(shù).....................
void lcdwrc(uint8 c)
delay(1000);
rs=0;
rw=0;
e=0;
P0=c;
e=1;
delay(1000);
e=0;
//...............寫數(shù)據(jù)函數(shù)........................
void lcdwrd(uint8 dat)
delay(1000);
rs=1;
rw=0;
e=0;
P0=dat;
e=1;
delay(1000);
e=0;
rs=0;
//..............LCD1602初始化函數(shù)...................
void lcdinit()
delay(1500);
lcdwrc(0x38);//設(shè)置功能模式
delay(500);
lcdwrc(0x38);
delay(500);
lcdwrc(0x38);
delay(500);
lcdwrc(0x38);
lcdwrc(0x08);//初始地址
lcdwrc(0x01);//清屏
lcdwrc(0x06);//寫一位指針加一
lcdwrc(0x0c);// 開顯示
void keyscan()
   key=0xfe;//令第一行為0,然后判斷是哪一列按下
   if(key!=0xfe)
   delay(1000);
    if(key!=0xfe)
   {  flag=0;
      anjian=P1&0xf0;
      switch(anjian)
        case 0xe0: num=0;zifu[i]='1';while(key!=0xfe);lcdwrd(zifu[i]);i++;break;
        case 0xd0: num=1;zifu[i]='2';while(key!=0xfe);lcdwrd(zifu[i]);i++;break;
        case 0xb0: num=2;zifu[i]='3';while(key!=0xfe);lcdwrd(zifu[i]);i++;break;
        case 0x70: num=3;zifu[i]='+';while(key!=0xfe);lcdwrd(zifu[i]);i++;break;
   key=0xfd;//令第二行為0,判斷是哪一列按下
   if(key!=0xfd)
    delay(1000);
     if(key!=0xfd)
     {  flag=0;
        anjian=P1&0xf0;
        switch(anjian)
         case 0xe0: num=4;zifu[i]='4';while(key!=0xfd);lcdwrd(zifu[i]);i++;break;
         case 0xd0: num=5;zifu[i]='5';while(key!=0xfd);lcdwrd(zifu[i]);i++;break;
         case 0xb0: num=6;zifu[i]='6';while(key!=0xfd);lcdwrd(zifu[i]);i++;break;
         case 0x70: num=7;zifu[i]='-';while(key!=0xfd);lcdwrd(zifu[i]);i++;break;
   key=0xfb;//令第三行為0,判斷哪一列按下
   if(key!=0xfb);
   {delay(1000);
   if(key!=0xfb)
   { flag=0;
     anjian=P1&0xf0;
     switch(anjian)
       case 0xe0: num=8;zifu[i]='7';while(key!=0xfb);lcdwrd(zifu[i]);i++;break;
       case 0xd0: num=9;zifu[i]='8';while(key!=0xfb);lcdwrd(zifu[i]);i++;break;
       case 0xb0: num=10;zifu[i]='9';while(key!=0xfb);lcdwrd(zifu[i]);i++;break;
       case 0x70: num=11;zifu[i]='*';while(key!=0xfb);lcdwrd(zifu[i]);i++;break;
   key=0xf7;//令第四行為0,判斷哪一列按下
   if(key!=0xf7)
     delay(1000);
     if(key!=0x07)
     {  flag=1;
        anjian=P1&0xf0;
        switch(anjian)
            case 0xe0:num=12;zifu[i]='0';while(key!=0xf7);lcdwrd(zifu[i]);i++;break;
            case 0xd0:num=13;while(key!=0xf7);memset(zifu,0,sizeof(zifu));i=0;lcdwrc(0x01);flag_denghao=0;break;
            case 0xb0:num=14;zifu[i]='=';while(key!=0xf7);
//                                        lcdwrd(zifu[i]);
                                        i++;
                                        zifu[i]='\0';break;
            case 0x70:num=15;zifu[i]='/';while(key!=0xf7);lcdwrd(zifu[i]);i++;break;
//..............十進制轉(zhuǎn)二進制..............
         P3=0x01;
         key2=P3; //原始P3.0=0x01
        if(key2=0x00)//是否已按下
   delay(500);// 消抖延時
    if(key2=0x00)//是否抖動
   {  flag=0;
      anjian=key2&0x00;
      switch(anjian)
        case 0x00:num=16;while(key2=0x01);break;//case按鍵值=P3口的電位信息,在此處P3.0口被按下后(沒按前P3.0=1,P3=0x01),P3.0=0,P3=0x00
void zhuanhuan()
   changeflag++;
         subflag=mulflag=divflag=addflag=0;
long caculate(uint8* zifu)
uint8 lable[10]={0};
long int num[10];
uint16 len=strlen(zifu);
uint8 cnt=0;
uint8 index=0;
long int tmp;
long int result;
int t,y,m;
for(y=len-1;y>=0;y--)//錯誤使用
        if(                                        (  zifu[len-2]>0x39||zifu[len-2]<0x30  )//最后一位為符號位
                                ||                 (  zifu[0]>0x39||zifu[0]<0x30  )//第一位為符號位
                                ||    ( (  zifu[y]>0x39||zifu[y]<0x30)&&(  zifu[y-1]>0x39||zifu[y-1]<0x30) )//連續(xù)兩個符號
                                ||                (                zifu[y]=='0'&&        zifu[y-1]=='/')
                if  (  (zifu[0]=='+')   ||  (zifu[0]=='-')  )
                flag_result=0;
                flag_result=1;
                break;
                flag_result=0;
for(k=0;k<len;k++)
  if(zifu[k]>0x39||zifu[k]<0x30)
     lable[cnt]=zifu[k];
     zifu[k]='\0';
     num[cnt]=atol(zifu+index);
     cnt++;
     index=k+1;
num[cnt++]=atol(zifu+index);
   for(k=0;k<=len-1;k++)
      if(lable[k]=='*'||lable[k]=='/')//判斷加減乘除優(yōu)先級
      if(lable[k]=='*')
      tmp=num[k]*num[k+1];
      else if(lable[k]=='/')
      tmp=num[k]/num[k+1];
      lable[k]='%';
      num[k+1]=tmp;
      num[k]=0;
      if(lable[k]=='%')//判斷加減乘除優(yōu)先級
                                m=k;//記錄下第一個%位置
                                while(lable[k]=='%')
                                        lable[k]='+';
                                        k++;
                                        num[m]=num[m]+num[k];
                                num[k]=0;
   result=num[0];
//         lcdwrc(0x45+0x80);
//        lcdwrc(0x04);
//         m=0;
//         while(lable[m]!=0)
//        {lcdwrd(lable[m]);
//                m++;
   for(t=0;t<len-1;t++)
     if(lable[t]=='+')
        result+=num[t+1];
     if( lable[t]=='-')
        result-=num[t+1];
return result;
void display(long jieguo)
p=jieguo;
if(p==0)
lcdwrd('0');
if(p<0)
jieguo=-jieguo;
while(jieguo!=0)
{lcdwrd(0x30+jieguo%10);
jieguo=jieguo/10;
if(p<0)
lcdwrd('-');//如果為負數(shù),顯示負號
//memset(zifu,0,sizeof(zifu));
//i=0;
flag_denghao=1;
if(changeflag)  //十進制轉(zhuǎn)換二進制
                lcdwrc(0X4f+0x80);//從第二行最末向前顯示
                lcdwrc(0x04);//指針光標自動減1 整屏不移動
                while(sum1!=0)
                   lcdwrd(0x30+sum1%2);
                         sum1/=2;
                  lcdwrd('=');
                  changeflag=0;
        beep=0;
        lcdinit();
                while(flag_denghao)
                {keyscan();}
                                keyscan();
                if(anjian==0xb0&&flag==1)
                        jieguo=caculate(zifu);
                        lcdwrc(0x4f+0x80);
                        lcdwrc(0x04);
                        if(flag_result==0)//
                                if(( jieguo>100000000 )||(jieguo<-100000000))//高溢出  100000000  9個位
                                        lcdwrc(0x45+0x80);
                                        lcdwrd('r');
                                        lcdwrd('e');
                                        lcdwrd('v');
                                        lcdwrd('o');
                                        beep=1;
                                        delayms(1000);
                                        beep=0;
                                        display(jieguo);
                                        lcdwrc(0x45+0x80);
                                        lcdwrd('r');
                                        lcdwrd('o');
                                        lcdwrd('r');
                                        lcdwrd('r');
                                        lcdwrd('e');
                                        beep=1;
                                        delayms(1000);
                                        beep=0;
                        flag=0;
收藏收藏 分享淘帖 頂1 踩
ID:584814 發(fā)表于 2020-12-23 09:25 | 只看該作者
連這行是啥意思看不懂,所以呵呵呵好像幫不了
ID:750420 發(fā)表于 2020-12-23 10:08 | 只看該作者
增加一個或運算將輸入連接到P3.0 輸出連接到外部中斷,使能外部中斷,觸發(fā)后在外部中斷函數(shù)中比較你需要的幾個按鍵并進行判斷把相應的標志位置位進行相應操作
ID:861681 發(fā)表于 2020-12-23 19:41 來自觸屏版 | 只看該作者
wyqf 發(fā)表于 2020-12-23 10:08
增加一個或運算將輸入連接到P3.0 輸出連接到外部中斷,使能外部中斷,觸發(fā)后在外部中斷函數(shù)中比較你需要的 ...
謝謝你給的思路,但是還是不會寫外部中斷服務函數(shù)里面的內(nèi)容
ID:161164 發(fā)表于 2024-5-8 10:16 | 只看該作者
什么亂七八糟的代碼
num有啥用?
主站蜘蛛池模板: 欧美三级欧美一级 | 中文字幕免费 | 欧美一区二区免费 | 国产成人在线免费视频 | 男人的天堂在线视频 | 日韩不卡在线 | 成人免费在线视频观看 | 五月婷婷网站 | 国产极品在线观看 | 欧美成人猛片aaaaaaa | 国产精品一区二区久久 | 国产欧美综合一区二区三区 | 91看片在线 | 国产在线观看不卡 | 国产乱码精品一品二品 | 精品日韩一区二区三区 | 国产无遮挡又黄又爽免费网站 | 中文字幕在线看片 | 欧美日韩一区二区三区视频 | 亚洲国产精品久久久久久 | 亚洲一区在线看 | 黄在线免费观看 | 国产美女免费视频 | 91网站免费| 午夜视频一区二区 | 国产黄色精品视频 | 亚洲最大的网站 | 成年人在线观看 | 在线观看av的网站 | 亚洲一区二区三区视频 | 成年免费视频黄网站在线观看 | 日韩一区二区三区免费视频 | 免费黄色片网站 | 亚洲天堂网在线观看 | 亚洲视频不卡 | 黄免费视频 | 日韩中文字幕一区二区三区 | av女优天堂 | 精品欧美黑人一区二区三区 | 精品久久久久久 | 免费色视频 |
