查看: 8258|回復: 10
單片機+BK4802N寬頻率范圍對講機的制作 附源程序
ID:795562 發表于 2021-1-3 16:30 | 顯示全部樓層 |閱讀模式
東戳戳西戳戳,戳出一篇利用MCU控制對講機制作的源程序,苦于無硬件連線圖無法仿制。求助大神們,可否從程序上面畫出硬件連線圖?
附上源程序,供大家琢磨。因為這個對講機工作頻率范圍很寬,好像可以工作在短波10米范圍。原數據手冊上寫有支持19~33Mhz,并附上芯片的數據手冊。
并求大神畫出MCU控制的硬件連接圖,和如何修改程序為工作頻率段為29.6Mhz范圍?
  1. #include "STC8F.h"
  2. #include "intrins.h"
  3. #include "IICANDDELAY.h"
  4. #include "codetab.h"
  5. sbit set=P3^7;//must connect not more than 8.2K resistor to GND
  6. //MCU and BK4802N share 3.3v VCC(STC8MCU must using 3.3v VCC)
  7. //BK4802N pin19-pin22 must connect to 3.3v.
  8. sbit ppt=P5^4;//ppt must be connected to BK4802N pin23.
  9. sbit test=P5^5;//test(p5.5) connect a LED to GND to indict 4802n IIC RUN.
  10. //DEFAULT FERQ:TX=RX=439.725mh.uSING "BK4802NCalc.exe to calculate.
  11. int rxfreq[]={
  12. 0x52BE,0xF850,0x0000};
  13. int txfreq[]={
  14. 0x52C5,0x925F,0x0000};
  15. char txinf[]="TX...";
  16. char rxinf[]="RX...";
  17. char blankinf[]="        ";
  18. char newtxfreq[6];
  19. char newrxfreq[6];
  20. unsigned char newtxfreqinf[6];
  21. //char newrxfreqinf[6];
  22. int rxreg[]={ //rx setting for register
  23. 0x0300,
  24. 0x8e04,
  25. 0xF140,
  26. 0xED00,
  27. 0x17E0,
  28. 0xe0e0,
  29. 0x8543,
  30. 0x0700,
  31. 0xA066,
  32. 0xFFFF,
  33. 0xFFE0,
  34. 0x07a0,
  35. 0x9E3C,
  36. 0x1F00,
  37. 0xD1D1,
  38. 0x200F,
  39. 0x01FF,
  40. 0xE000,
  41. 0x0340
  42. };
  43. int txreg[]={//tx setting for register
  44. 0x7C00,
  45. 0x0c04,
  46. 0xF140,
  47. 0xED00,
  48. 0x3fE0,
  49. 0xe0e0,
  50. 0x8543,
  51. 0x0700,
  52. 0xA066,
  53. 0xFFFF,
  54. 0xffe0,
  55. 0x061f,
  56. 0x9e3c,
  57. 0x1f00,
  58. 0xd1C1,
  59. 0x200f,
  60. 0x01FF,
  61. 0xE000,
  62. 0x0c00
  63. };
  64. void setchannel(char k)//setting new trx freq from EEPROM in MCU
  65.          {
  66.
  67.                  int i;
  68.
  69.                          for(i=0;i<6;i++)
  70.                          {
  71.                                 newrxfreq[i]=IapRead(i+6+k*32);
  72.                           newtxfreq[i]=IapRead(i+k*32);
  73.                          }
  74.          }
  75. void setchannelinf(char k)//setting new trx freq information display on OLED  from EEPROM in MCU
  76.          {
  77.
  78.                  int i;
  79.
  80.                          for(i=0;i<6;i++)
  81.                          {
  82.                                 newtxfreqinf[i]=IapRead(i+16+k*32);
  83.                          }
  84.          }
  85. void main()
  86. {
  87.         unsigned char i,f;// i do for 'for',f do for store channel No.
  88.         unsigned char k=0;//k is do for trx
  89.         //Start
  90.         test=1;
  91.   Delay50ms();
  92.         OLED_Init(); //OLED初始化
  93.                         for(i=0; i<8; i++)//通過點整顯示漢字 -- i表示字表數組的位置
  94.                 {
  95.                         OLED_P16x16Ch(i*16,0,i);//In the name of the Moon ,I will punish you.
  96.                          OLED_P16x16Ch(i*16,2,i+8);         //Moon promise power, make up!
  97.                 }
  98.                 OLED_P8x16Str(0,6,"BG7QKU");
  99.                 delay(10000);
  100.                 OLED_CLS();//清屏
  101.                 test=0;
  102.                 OLED_P8x16Str(0,0,"BG7QKU");
  103.                 for(i=0; i<8; i++)
  104.                  {
  105.                          OLED_P16x16Ch(i*16,6,i);
  106.                  }
  107.                 writing(0x90,23,0xa8,0XD0);//Init rx reg23.
  108.                 if(P11==0)//if default or not?
  109.                 {
  110.                         for(i=4;i<=22;i++)
  111.                         {
  112.                          writing(0x90,i,HIGHBYTE(rxreg[i-4]),LOWBYTE(rxreg[i-4]));//init default reg. ro rx
  113.                         }
  114.                         for(i=5;i>2;i--)
  115.                         {
  116.                                 writing(0x90,i-3,HIGHBYTE(rxfreq[i-3]),LOWBYTE(rxfreq[i-3]));//init default reg. to rx freq
  117.                         }
  118.                         OLED_P8x16Str(0,4,"439.725");
  119.                         OLED_P8x16Str(0,2,rxinf);
  120.                 }
  121.
  122.                 else
  123.                 {
  124.                         f=IapRead(0x0200);//read store channel No.
  125.                         if (f>3)
  126.                                 f=0;
  127.                         setchannel(f);
  128.                         setchannelinf(f);
  129.                         OLED_P8x16Str(0,4,newtxfreqinf);
  130.                         k=1;
  131.                 }
  132.
  133.                 test=1;
  134.                 while(1)
  135.                 {
  136.                         if(set==1)//teat channel change key
  137.                         {
  138.                                 Delay30ms();//kill swim
  139.                                 if(set==1)
  140.                                 {
  141.                                  Delay30ms();//down to LOW to set channel
  142.                                 if(set==0)
  143.                                 {
  144.                                         f++;
  145.                                         if(f>3)
  146.                                                 f=0;
  147.                                         IapErase(0x0200);//erase EEPROM before write
  148.                                         IapProgram(0x0200,f);//write EEPORM
  149.                                         setchannel(f);
  150.                                   setchannelinf(f);
  151.                                   OLED_P8x16Str(0,4,newtxfreqinf);
  152.
  153.                             k=1;
  154.                                 }
  155.                          }
  156.                         }
  157.                         //Only using default freq
  158.                         if(ppt==1&&k==0&&P11==0)//Set to TX if PTT =HIGH.
  159.                         {
  160.                           test=0;
  161.                                 Delay30ms();
  162.                                 if(ppt==1)
  163.                                 {
  164.                                         Delay30ms();
  165.                                           for(i=4;i<=22;i++)
  166.                 {
  167.                                    writing(0x90,i,HIGHBYTE(txreg[i-4]),LOWBYTE(txreg[i-4]));
  168.                             }
  169.
  170.                       for(i=5;i>2;i--)
  171.                       {
  172.                              writing(0x90,i-3,HIGHBYTE(txfreq[i-3]),LOWBYTE(txfreq[i-3]));
  173.                       }
  174.                                         Delay30ms();
  175.                                         OLED_P8x16Str(0,2,blankinf);
  176.                                         OLED_P8x16Str(0,2,"439.725");
  177.                                         test=1;
  178.                                         k=1;
  179.                                 }
  180.                         }
  181.                                 if(ppt==0&&k==1&&P11==0)//Set to RX.
  182.                                 {
  183.                                         test=0;
  184.                                         Delay30ms();
  185.                                 if(ppt==0)
  186.                                 {
  187.                                         Delay30ms();
  188.                                         writing(0x90,23,0xa8,0XD0);
  189.                                           for(i=4;i<=22;i++)
  190.                {
  191.                                    writing(0x90,i,HIGHBYTE(rxreg[i-4]),LOWBYTE(rxreg[i-4]));
  192.                             }
  193.
  194.                       for(i=5;i>2;i--)
  195.                       {
  196.                              writing(0x90,i-3,HIGHBYTE(rxfreq[i-3]),LOWBYTE(rxfreq[i-3]));
  197.                       }
  198.                                         Delay30ms();
  199.                                         OLED_P8x16Str(0,2,blankinf);
  200.                                         OLED_P8x16Str(0,2,"439.725");
  201.                       test=1;
  202.                                         k=0;
  203.                           }
  204.                    }
  205.                         //Using pre-set freq
  206.                         if(ppt==1&&k==0&&P11==1)//Set to TX if PTT =HIGH.
  207.                         {
  208.         test=0;
  209.                                 Delay30ms();
  210.                                 if(ppt==1)
  211.                                 {
  212.                                         setchannel(f);
  213.                                   setchannelinf(f);
  214.                                         test=0;
  215.                                         OLED_P8x16Str(0,4,newtxfreqinf);
  216.                                         Delay30ms();
  217.                                           for(i=4;i<=22;i++)
  218.                {
  219.                                    writing(0x90,i,HIGHBYTE(txreg[i-4]),LOWBYTE(txreg[i-4]));
  220.                             }
  221.
  222.                       for(i=5;i>2;i--)
  223.                       {
  224.                              writing(0x90,i-3,newtxfreq[2*(i-3)],newtxfreq[2*(i-3)+1]);
  225.                       }
  226.                                         Delay30ms();
  227.                                         OLED_P8x16Str(0,2,blankinf);
  228.                                         OLED_P8x16Str(0,2,txinf);
  229.                                         test=1;
  230.                                         k=1;
  231.                                 }
  232.                         }
  233.                                 if(ppt==0&&k==1&&P11==1)//Set to RX.
  234.                                 {
  235.                                         Delay30ms();
  236.                                 if(ppt==0)
  237.                                 {
  238.                                         test=0;
  239.                                         Delay30ms();
  240.                                         writing(0x90,23,0xa8,0XD0);
  241.                                           for(i=4;i<=22;i++)
  242.                {
  243.                                    writing(0x90,i,HIGHBYTE(rxreg[i-4]),LOWBYTE(rxreg[i-4]));
  244.                             }
  245.
  246.                       for(i=5;i>2;i--)
  247.                       {
  248.                              writing(0x90,i-3,newrxfreq[2*(i-3)],newrxfreq[2*(i-3)+1]);
  249.                       }
  250.                                         Delay30ms();
  251.                                         OLED_P8x16Str(0,2,blankinf);
  252.                                         OLED_P8x16Str(0,2,rxinf);
  253.                                         test=1;
  254.                                         k=0;
  255.                           }
  256.                    }
  257.                 }
  258. }
第三個程序,增加到16個信道,以及顯示月野兔開機圖片.zip (4.13 MB, 下載次數: 110)
BK4802_datasheet.pdf (753.36 KB, 下載次數: 114)
ID:795562 發表于 2021-1-3 16:34 | 顯示全部樓層
這個是原作者寫的論壇帖子,一并附上。求解單片機和BK4802的連線控制圖
自己研究的STC單片機控制對講芯片程序 摘錄.docx
418.23 KB, 下載次數: 121, 下載積分: 黑幣 -5
ID:390569 發表于 2022-11-14 12:03 來自觸屏版 | 顯示全部樓層
這是我寫的源程序,可以在我github上搜索作者“BG7QKU”,我在上面相關研究成果(后來升級修改成為了DIY小玩意
ID:230742 發表于 2022-11-15 11:57 | 顯示全部樓層
快兩年遇上原作者了。緣分啊。
ID:1041279 發表于 2023-8-8 11:41 | 顯示全部樓層
現在BK4802的資料都找不到了
ID:69038 發表于 2023-8-9 08:39 | 顯示全部樓層
kendu1982 發表于 2023-8-8 11:41
現在BK4802的資料都找不到了
我有。好多年前收的
ID:1041279 發表于 2023-8-9 11:04 | 顯示全部樓層
zhuls 發表于 2023-8-9 08:39
我有。好多年前收的
謝謝!樓主的程序夠用了,PDF在這里還有
753.36 KB, 下載次數: 59, 下載積分: 黑幣 -5
ID:1010505 發表于 2024-4-25 23:05 | 顯示全部樓層
mark下,還有可以傳數據的型號,不過資料好像不好找
ID:122152 發表于 2024-4-26 14:36 | 顯示全部樓層
好資料謝謝提供!
ID:369845 發表于 2024-6-8 18:20 | 顯示全部樓層
kendu1982 發表于 2023-8-9 11:04
感謝!終于找到了比較全的datasheet了,我之前看半導小芯的datasheet,內容有刪減。
ID:283207 發表于 2024-6-24 14:21 | 顯示全部樓層
感謝原作者和搬運者,mark下,有空再仔細研究
主站蜘蛛池模板: 久久中文字幕视频 | 国产成人毛片 | 91中文字幕在线 | 中文字幕视频一区 | 黄色在线观看免费 | 黄色精品网站 | 国产日韩欧美一区二区 | 精品99视频 | 综合一区二区三区 | 电家庭影院午夜 | 黄色片网站在线观看 | 免费的黄色网址 | 亚洲综合二区 | 免费在线观看黄 | 日韩在线精品视频 | 久久精品一区二区国产 | 免费成人深夜夜行网站 | 日韩av在线影院 | 欧美一级片在线 | 久久久久女人精品毛片九一 | 在线观看日韩视频 | 久久精品二区 | 精品欧美黑人一区二区三区 | 午夜不卡视频 | 日韩欧美色 | 亚洲三级视频在线观看 | 国产综合亚洲精品一区二 | 日韩精品视频在线免费观看 | 一级片免费 | 天天躁日日躁狠狠躁av麻豆男男 | 伊人久操 | 日韩一级片视频 | 亚洲精品www | 在线亚洲精品 | 天天有av | 成人福利网站 | 丁香色婷婷 | 欧美爱爱网 | 日韩无遮挡 | 国产理论在线观看 | www.一区|
