查看: 12720|回復(fù): 7
proteus仿真溫濕度傳感器dht11,dht22程序
ID:423119 發(fā)表于 2021-1-5 15:52 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
使用1602顯示DHT22的溫濕度,精確到小數(shù)點的后一位
//           DHT21使用范例
//單片機 AT89S52 或 STC89C52RC
//功能   串口發(fā)送溫濕度數(shù)據(jù) 晶振 11.0592M 波特率 9600
//硬件   P2.0口為通訊口連接DHT22,DHT22的電源和地連接單片機的電源和地,單片機串口加MAX232連接電腦
#include <reg51.h>
#include <intrins.h>
typedef unsigned char  U8;       /* defined for unsigned 8-bits integer variable           無符號8位整型變量  */
typedef signed   char  S8;       /* defined for signed 8-bits integer variable                  有符號8位整型變量  */
typedef unsigned int   U16;      /* defined for unsigned 16-bits integer variable           無符號16位整型變量 */
typedef signed   int   S16;      /* defined for signed 16-bits integer variable           有符號16位整型變量 */
typedef unsigned long  U32;      /* defined for unsigned 32-bits integer variable           無符號32位整型變量 */
typedef signed   long  S32;      /* defined for signed 32-bits integer variable           有符號32位整型變量 */
typedef float          F32;      /* single precision floating point variable (32bits) 單精度浮點數(shù)(32位長度) */
typedef double         F64;      /* double precision floating point variable (64bits) 雙精度浮點數(shù)(64位長度) */
#define uchar unsigned char
#define uint unsigned int
#define   Data_0_time    4
#define LCD1602_DB  P0
sbit LCD1602_RS = P2^0;
sbit LCD1602_RW = P2^1;
sbit LCD1602_E  = P2^2;
/* 等待液晶準備好 */
void LcdWaitReady()
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do {
        LCD1602_E = 1;
        sta = LCD1602_DB; //讀取狀態(tài)字
        LCD1602_E = 0;
    } while (sta & 0x80); //bit7等于1表示液晶正忙,重復(fù)檢測直到其等于0為止
/* 向LCD1602液晶寫入一字節(jié)命令,cmd-待寫入命令值 */
void LcdWriteCmd(unsigned char cmd)
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 向LCD1602液晶寫入一字節(jié)數(shù)據(jù),dat-待寫入數(shù)據(jù)值 */
void LcdWriteDat(unsigned char dat)
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 設(shè)置顯示RAM起始地址,亦即光標位置,(x,y)-對應(yīng)屏幕上的字符坐標 */
void LcdSetCursor(unsigned char x, unsigned char y)
    unsigned char addr;
    if (y == 0)  //由輸入的屏幕坐標計算顯示RAM的地址
        addr = 0x00 + x;  //第一行字符地址從0x00起始
        addr = 0x40 + x;  //第二行字符地址從0x40起始
    LcdWriteCmd(addr | 0x80);  //設(shè)置RAM地址
/* 在液晶上顯示字符串,(x,y)-對應(yīng)屏幕上的起始坐標,str-字符串指針 */
void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str)
    LcdSetCursor(x, y);   //設(shè)置起始地址
    while (*str != '\0')  //連續(xù)寫入字符串數(shù)據(jù),直到檢測到結(jié)束符
        LcdWriteDat(*str++);
/* 打開光標的閃爍效果 */
void LcdOpenCursor()
        LcdWriteCmd(0x0F);
/* 關(guān)閉光標顯示 */
void LcdCloseCursor()
        LcdWriteCmd(0x0C);
/* 初始化1602液晶 */
void InitLcd1602()
    LcdWriteCmd(0x38);  //16*2顯示,5*7點陣,8位數(shù)據(jù)接口
    LcdWriteCmd(0x0C);  //顯示器開,光標關(guān)閉
    LcdWriteCmd(0x06);  //文字不動,地址自動+1
    LcdWriteCmd(0x01);  //清屏
//----------------IO口定義區(qū)--------------------//
sbit  P2_0  = P2^3 ;
//----------------定義區(qū)--------------------//
U8  U8FLAG,k;
U8  U8count,U8temp;
U8  U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8  U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
U8  U8comdata;
U8  outdata[5];  //定義發(fā)送的字節(jié)數(shù)
U8  indata[5];
U8  count, count_r=0;
U8 str[4];
U16 U16temp1,U16temp2;
SendData(U8 *a)
        outdata[0] = a[0];
        outdata[1] = a[1];
        outdata[2] = a[2];
        outdata[3] = a[3];
        outdata[4] = a[4];
        count = 1;
        SBUF=outdata[0];
       void Delay(U16 j)
    {      U8 i;
            for(;j>0;j--)
                for(i=0;i<27;i++);
      void  Delay_10us(void)
        U8 i;
        i--;
        i--;
        i--;
        i--;
        i--;
        i--;
        void  COM(void)
                U8 i;
       for(i=0;i<8;i++)
                       U8FLAG=2;
                   while((!P2_0)&&U8FLAG++);
                        Delay_10us();
            Delay_10us();
            Delay_10us();
                          U8temp=0;
             if(P2_0)U8temp=1;
                    U8FLAG=2;
                 while((P2_0)&&U8FLAG++);
                   //超時則跳出for循環(huán)
                    if(U8FLAG==1)break;
                   //判斷數(shù)據(jù)位是0還是1
                // 如果高電平高過預(yù)定0高電平值則數(shù)據(jù)位為 1
                   U8comdata<<=1;
                      U8comdata|=U8temp;        //0
             }//rof
        //-----濕度讀取子程序 ------------
        //----以下變量均為全局變量--------
        //----溫度高8位== U8T_data_H------
        //----溫度低8位== U8T_data_L------
        //----濕度高8位== U8RH_data_H-----
        //----濕度低8位== U8RH_data_L-----
        //----校驗 8位 == U8checkdata-----
        //----調(diào)用相關(guān)子程序如下----------
        //---- Delay();, Delay_10us();,COM();
        void RH(void)
          //主機拉低18ms
       P2_0=0;
           Delay(180);
           P2_0=1;
         //總線由上拉電阻拉高 主機延時20us
           Delay_10us();
           Delay_10us();
       Delay_10us();
           Delay_10us();
         //主機設(shè)為輸入 判斷從機響應(yīng)信號
           P2_0=1;
         //判斷從機是否有低電平響應(yīng)信號 如不響應(yīng)則跳出,響應(yīng)則向下運行
           if(!P2_0)                 //T !
           U8FLAG=2;
         //判斷從機是否發(fā)出 80us 的低電平響應(yīng)信號是否結(jié)束
           U8FLAG=2;
         //判斷從機是否發(fā)出 80us 的高電平,如發(fā)出則進入數(shù)據(jù)接收狀態(tài)
         //數(shù)據(jù)接收狀態(tài)
           COM();
           U8RH_data_H_temp=U8comdata;
           COM();
           U8RH_data_L_temp=U8comdata;
           COM();
           U8T_data_H_temp=U8comdata;
           COM();
           U8T_data_L_temp=U8comdata;
           COM();
           U8checkdata_temp=U8comdata;
           P2_0=1;
         //數(shù)據(jù)校驗
           U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
           if(U8temp==U8checkdata_temp)
                     U8RH_data_H=U8RH_data_H_temp;
                     U8RH_data_L=U8RH_data_L_temp;
                  U8T_data_H=U8T_data_H_temp;
                     U8T_data_L=U8T_data_L_temp;
                     U8checkdata=U8checkdata_temp;
           }//fi
           }//fi
//main()功能描述:  AT89C51  11.0592MHz         串口發(fā)
//送溫濕度數(shù)據(jù),波特率 9600
U16 wendu = 0;
U16 shidu = 0;
U8 wendu_zu[4];
U8 shidu_zu[4];
        //uchar str[6]={"RS232"};
        /* 系統(tǒng)初始化 */
        TMOD = 0x20;          //定時器T1使用工作方式2
        TH1 = 253;        // 設(shè)置初值
        TL1 = 253;
        TR1 = 1;          // 開始計時
        SCON = 0x50;          //工作方式1,波特率9600bps,允許接收
        ES = 1;
        EA = 1;           // 打開所以中斷
        TI = 0;
        RI = 0;
        SendData(str) ;   //發(fā)送到串口
        Delay(10);         //延時100US(12M晶振)
        InitLcd1602();
           //調(diào)用溫濕度讀取子程序
           RH();
           //串口顯示程序
     wendu = (((U16)U8RH_data_H<<8)|(U16)U8RH_data_L);
                 shidu = (((U16)U8T_data_H<<8)|(U16)U8T_data_L);
           wendu_zu[3]=wendu%10 + '0';
                 wendu_zu[2]='.';
           wendu_zu[1]=(wendu/10)%10+ '0';
           wendu_zu[0]=wendu/100+ '0';
                 shidu_zu[3] = shidu%10 + '0';
                 shidu_zu[2] = '.';
           shidu_zu[1] = (shidu/10)%10+ '0';
           shidu_zu[0] = shidu/100 + '0';
     LcdShowStr(0,0,wendu_zu);
     LcdShowStr(0,1,shidu_zu);
           //讀取模塊數(shù)據(jù)周期不宜小于 2S
           Delay(2000);
        }//elihw
}// main
//void RSINTR() interrupt 4 using 2
//        U8 InPut3;
//        if(TI==1) //發(fā)送中斷
//                TI=0;
//                if(count!=5) //發(fā)送完5位數(shù)據(jù)
//                        SBUF= outdata[count];
//                        count++;
//        if(RI==1)         //接收中斷
//                InPut3=SBUF;
//                indata[count_r]=InPut3;
//                count_r++;
//                RI=0;
//                if (count_r==5)//接收完4位數(shù)據(jù)
//                //數(shù)據(jù)接收完畢處理。
//                        count_r=0;
//                str[0]=indata[0];
//                 str[1]=indata[1];
//                   str[2]=indata[2];
//                         str[3]=indata[3];
//                                 str[4]=indata[4];
//                                 P0=0;
全部資料51hei下載地址:
DHT22 .zip (62.48 KB, 下載次數(shù): 344)
收藏收藏7 分享淘帖 頂 踩
ID:336823 發(fā)表于 2021-4-7 17:14 | 只看該作者
仿真了一下,LCD不顯示
ID:925265 發(fā)表于 2021-8-20 08:04 | 只看該作者
能顯示
ID:984835 發(fā)表于 2021-11-26 10:54 | 只看該作者
為什么我的lcd顯示不了啊
ID:262 發(fā)表于 2021-11-27 03:30 | 只看該作者
幻夜行 發(fā)表于 2021-4-7 17:14
仿真了一下,LCD不顯示
我用Proteus8.8版本測試ok  你換個版本看看
ID:996196 發(fā)表于 2021-12-23 16:53 | 只看該作者
不錯,程序沒問題
ID:1071099 發(fā)表于 2023-4-17 17:14 | 只看該作者
下載了咋沒程序
ID:262 發(fā)表于 2023-4-17 19:06 | 只看該作者
main.c這個文件就是程序,如果懶得在文件包里面找 就直接從網(wǎng)頁上復(fù)制粘貼吧,網(wǎng)頁上也有完整的程序
主站蜘蛛池模板: 欧美大白屁股 | 日韩一区二区三区四区 | 羞羞的网站| 久久国产一区二区三区 | 欧美乱强伦 | 一二三四区在线观看 | 国产不卡在线视频 | 午夜精品一区二区三区在线视频 | 天天爽夜夜爽 | 欧美性猛交xxxx黑人交 | 国产精品福利在线观看 | 一区二区三区黄色 | 一本一道久久a久久精品蜜桃 | 欧美一级在线观看 | av大片在线观看 | 日日夜夜综合网 | 中文字幕无人区二 | 97在线免费观看 | 天天射一射 | 黄色一节片 | www久久久 | 九九热在线视频 | 国产精品久久久一区二区三区 | 91av视频| 91精品久久久久久久久久 | 黄色大片视频 | 精品视频久久 | 国产伦精品一区二区三区视频网站 | 新香蕉视频 | 日本少妇中文字幕 | 青娱乐av | 一区二区三区视频在线 | 精品国产视频 | 欧美黄网站 | 亚洲国产成人精品女人 | 中文日韩欧美 | 国产精品911| 国产小视频在线 | 在线日韩视频 | 欧美三级精品 | 成人av一区二区三区在线观看 |
