查看: 4457|回復: 0
51單片機設計秒表計時器,proteus仿真程序
27,28兩個按鍵用于控制時間的暫停和重新計數
  1. #include <reg51.h>
  2. #include <absacc.h>
  3. #include <intrins.h>
  4. #define BIT0  0x01
  5. #define BIT1  0x02
  6. #define BIT2  0x04
  7. #define BIT3  0x08
  8. #define BIT4  0x10
  9. #define BIT5  0x20
  10. #define BIT6  0x40
  11. #define BIT7  0x80
  12. #define KeyInPort   XBYTE[0xE800]
  13. #define KeyOutPort  XBYTE[0xEC00]
  14. typedef unsigned int u16;          //對數據類型進行聲明定義
  15. typedef unsigned char u8;
  16. u16 Timer0_flag = 0;
  17. u16 time100ms_cnt = 0;//100ms計數變量
  18.
  19. u8 xdata smgduan[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,//0x00全滅
  20.                                         0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71, 0x00};//顯示0~F的值,18不顯示
  21. u8 xdata smgduan_num[] = { 0x00, 0x20, 0x10, 0x08, 0x04, 0x02, 0x01, 0xff};//0xff選中所有數碼管
  22. u8 code KeyOutTAB[] = {
  23.      0xFF, // 湊數的
  24.     ~BIT0,
  25.     ~BIT1,
  26.     ~BIT2,
  27.     ~BIT3,
  28.     ~BIT4,
  29.     ~BIT5,
  30.           ~BIT6,
  31.     ~BIT7,
  32. };
  33. u8 code conKeyFunCode[] = {
  34.    3, // 湊數
  35.    0x81,// 0
  36.          0x22,// 1
  37.    0x42,// 2
  38.    0x82,// 3
  39.    0x83,// 4
  40.    0x43,// 5
  41.    0x23,// 6
  42.    0x84,// 7
  43.    0x44,// 8
  44.    0x24,// 9
  45.    0x14,// A
  46.    0x13,// B
  47.    0x12,// C
  48.    0x11,// D
  49.    0x21,// E
  50.    0x41,// F
  51.    0x00,// 空鍵 16
  52.    0x85,// 17
  53.    0x45,// 18
  54.    0x25,// 19
  55.    0x15,// 20
  56.    0x86,// 21
  57.    0x46,// 22
  58.    0x26,// 23
  59.    0x16,// 24
  60.    0x0C,// 25
  61.    0x0B,// 26
  62.    0x0A,// 27
  63.    0x09,// 28
  64. };
  65. u16 smgduan_addr     = 0XE3FF;   //E3FF是PS0的地址,段碼的8位數據
  66. u16 smgduan_num_addr = 0XE7FF;   //E7FF是PS1的地址,選擇那一個數碼管亮
  67. u16 key_out_addr     = 0XEFFF;   //EFFF是PS3的地址,矩陣按鍵輸出地址
  68. u16 key_in_addr      = 0XEBFF;   //EBFF是PS2的地址,矩陣按鍵讀地址
  69. u8 Key_Flag = 0;
  70. u8 Sys_Key = 0; // 鍵值存放在這里
  71. u8 duanma_mode = 0;
  72. u8 preKey = 0;
  73. u8 curKey = 0;
  74. u8 SameKeyNum = 0;
  75.           bit Flag_1ms = 0;
  76. unsigned char Cnt_1ms  = 0;
  77.           bit Flag_10ms = 0;
  78. unsigned char Cnt_10ms  = 0;
  79.           bit Flag_100ms = 0;
  80. unsigned char Cnt_100ms  = 0;
  81.           bit Flag_1s = 0;
  82. unsigned char Cnt_1s  = 0;
  83.
  84. void Fun_KeyScan( void ){
  85.
  86.     unsigned char Temp = 0;
  87.     unsigned char LineNum = 0;
  88.
  89.     // 1、獲取鍵值
  90.      for( LineNum = 6; LineNum > 0; LineNum-- ){
  91.         KeyOutPort = KeyOutTAB[LineNum];  // 輸出
  92.         Temp  = KeyInPort;           // 讀取
  93.         Temp  = ~Temp;               // 取反,有按下的是低電平
  94.         Temp &= 0x1F;                // 屏蔽,0001 1111
  95.         if( Temp ){                  // 如果有鍵按下
  96.             break;                   // 則跳出循環
  97.         }                            // 否則繼續掃描
  98.     }
  99.
  100.     // 2、拼合鍵值
  101.     Temp <<= 3;//左移3位
  102.     Temp |= LineNum;//6 = 110B
  103.
  104.     // 3、獲取功能碼
  105.     for( LineNum = 29; LineNum > 0; LineNum-- ){//一共30個數,但是第一個數是無效數,從29掃描到1
  106.         if( Temp == conKeyFunCode[ LineNum ] ){
  107.             break;
  108.         }
  109.     }
  110.
  111.     if( LineNum > 0 ){ LineNum--; }
  112.
  113.     // 4、數字濾波
  114.     curKey = LineNum;
  115.     if( curKey != preKey ){//判斷下一次掃描的是不是還是上一個按鍵
  116.         preKey = curKey;
  117.         SameKeyNum = 0;
  118.     }
  119.     else{
  120.         SameKeyNum++;
  121.         if( SameKeyNum == 30 ){ Key_Flag = 1; Sys_Key = curKey; }
  122.         if( SameKeyNum == 80 ){ Key_Flag = 1; Sys_Key = curKey; }
  123.         if( SameKeyNum >= 100 ){ Key_Flag = 1; Sys_Key = curKey; SameKeyNum = 80; }
  124.     }
  125.
  126. }
  127. bit key28_down = 0;
  128. bit key28_up = 0;
  129. bit key27_down = 0;
  130. bit key27_up = 0;
  131. bit time_start = 1;
  132. void InitTimer0(void)
  133. {
  134.     TMOD = 0x01;
  135.     TH0 = 0x0FC;
  136.     TL0 = 0x18;
  137.     EA = 1;
  138.     ET0 = 1;
  139.     TR0 = 1;
  140. }
  141. void delay1ms(void)   //誤差 0us
  142. {
  143.     unsigned char a,b,c;
  144.     for(c=1;c>0;c--)
  145.         for(b=142;b>0;b--)
  146.             for(a=2;a>0;a--);
  147. }
  148. void main(void)
  149. {
  150.     InitTimer0();
  151.           while(1)
  152.                 {
  153.                         Fun_KeyScan();
  154.                         if (Sys_Key == 28)//當28號鍵按下去然后在松開,key28_up == 1
  155.                         {
  156.                                         key28_down = 1;
  157.                         }
  158.                         if(key28_down == 1 && Sys_Key == 16)
  159.                         {
  160.                                         key28_down = 0;
  161.                                         key28_up = 1;
  162.                         }
  163.                         if(key28_up == 1)
  164.                         {
  165.                                         key28_up = 0;
  166.                                   time_start = ~time_start;
  167.                         }
  168.
  169.                         if (Sys_Key == 27)//當27號鍵按下去然后在松開,key27_up == 1
  170.                         {
  171.                                         key27_down = 1;
  172.                         }
  173.                         if(key27_down == 1 && Sys_Key == 16)
  174.                         {
  175.                                         key27_down = 0;
  176.                                         key27_up = 1;
  177.                         }
  178.                         if((key27_up == 1) && (time_start == 0))
  179.                         {
  180.                                         key27_up = 0;
  181.                                   duanma_mode++;
  182. //          if(duanma_mode >= 3)
  183. //                                        {
  184. //                                            duanma_mode = 0;
  185. //                                        }
  186.                         }
  187.
  188.                         if(duanma_mode == 1)
  189.                         {
  190.                                   time100ms_cnt = 0;
  191.                         }
  192.                         if(duanma_mode == 2)
  193.                         {
  194.                                   duanma_mode = 0;
  195.                                   time_start = 1;
  196.                         }
  197.                   XBYTE[smgduan_num_addr] = smgduan_num[1];
  198. ……………………
  199. …………限于本文篇幅 余下代碼請從51黑下載附件…………
51.zip (69.18 KB, 下載次數: 19)
主站蜘蛛池模板: 日韩一级av毛片 | 亚洲国产成人在线 | 视频一区二区在线 | 亚洲天堂男人天堂 | 在线观看福利影院 | 青青操国产 | 国产精品久久久一区二区 | 午夜性视频 | 日韩一区二区三区四区 | 99热最新网址 | 一区二区三区高清 | 中文字幕1区 | 欧美大片黄 | 亚洲精品视频免费在线观看 | 国产成人a亚洲精品 | 国产欧美一区二区 | 大桥未久在线视频 | 这里都是精品 | 日韩免费一级片 | 免费成人在线观看 | 日韩av免费在线播放 | 精品成人在线 | 成人免费激情视频 | 美丽的姑娘观看在线播放 | 成人黄色大片 | 91av视频| 日韩成人在线观看视频 | 91精品国产99久久久久久红楼 | 在线看片a | 中文字幕在线观看免费 | 五月婷婷深深爱 | 久久久午夜 | 亚洲欧美成人 | 午夜激情在线观看 | 欧美顶级黄色大片免费 | 精品一区久久 | www.色中色 | 亚洲精品一区二区三区在线观看 | av免费看网站 | 欧美一区二区在线 | 在线视频日韩 |
