查看: 1698|回復: 1
hc-05藍牙小車 stc89c52
ID:812531 發表于 2021-2-8 10:06 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit IN1=P1^0;
sbit IN2=P1^1;
sbit IN3=P1^2;
sbit IN4=P1^3;
sbit IN5=P1^4;
sbit IN6=P1^5;
sbit IN7=P1^6;
sbit IN8=P1^7;
sbit L_PWM=P3^4;           //左輪調速,接驅動模塊ENA使能端,在這里輸入PWM信號
sbit R_PWM=P3^5;           //右輪調速,接驅動模塊ENB使能端,在這里輸入PWM信號
sbit jd=P0^0;
void send_char();
unsigned char txd;
uchar buf;
#define  L_go   IN1=1; IN2=0;//左前//左后輪前進
#define L_back    IN1=0; IN2=1; //左輪后退
#define L_stop      IN1=0; IN2=0;        //左輪停止,兩個輸出1也可以
#define   R_go      IN3=1;IN4=0; //右后輪前進
#define R_back          IN3=0;IN4=1; //右輪后退
#define R_stop          IN3=0;IN4=0; //右輪停止,兩個輸出1也可以
#define leftzhuan                                  IN7=1;IN8=0;
#define rightzhuan                           IN7=0;IN8=1;
#define stopzhuan                     IN7=0;IN8=0;
#define shangyang             IN5=0;IN6=1;
#define xiayang                  IN5=1;IN6=0;
#define stopyang                  IN5=0;IN6=0;
#define car_go                                L_go;R_go;                //小車前進
#define car_back                        L_back;R_back        //小車后退
#define car_left                        R_go;L_stop                //小車左轉彎
#define car_right                        L_go;R_stop                //小車右轉彎
#define car_stop                        L_stop;R_stop        //小車停車
#define car_left_360        R_go;L_back                //小車向左360度轉,也可以認為是大轉彎
#define car_right_360        L_go;R_back                //小車向右360度轉,也可以認為是大轉彎
unsigned char l_tt=0;        //定時器計數用
unsigned char l_Lpwm=0;        //左輪PWM占空比值,我們設計10個格,0-90為停止,9為全速
        //右輪PWM占空比值,我們設計10個格,0-90為停止,9為全速
void timer0()interrupt 1   using 2
        TH0=0XFC;          //定時1毫秒,10格調速,為100HZ頻率,此頻率下效果比較好,過大有噪聲,過小振動大
        TL0=0X17;
        l_tt++;
        if(l_tt>30)l_tt=0;        //比較用,10格調速
        if(l_tt<=l_Lpwm){//左調速,占空比數值越大,輸出高電平時間越寬,電機轉速越高,我們設計10個格,0-90為停止,9為全速
                 L_PWM=1;
        else{
                L_PWM=0;
void delayms(unsigned int xms)
  unsigned i,j;
         for(i=xms;i>0;i--)
            for(j=110;j>0;j--);
void main (void)
SCON=0x50;//????????01010000
PCON=0x00;
TMOD=0x20;
EA=1;
ES=1;
TL1=0xfd;
TH1=0xfd;
TR1=1;
jd=0;
while (1)
void serial() interrupt 4
ES=0;
        if(RI==1)
RI=0;
buf=SBUF;
        send_char();
switch (buf)
//以下是字符型 依次是1 2 3 4 5 6 7 8  a b c d e
case 0x31: car_go; break;
case 0x32: car_back; break;
case 0x33: car_stop; break;
case 0x34: car_left_360; break;
case 0x35: car_right_360; break;
case 0x36: l_Lpwm=3;shangyang; break;
case 0x37: l_Lpwm=3;stopyang; break ;
case 0x38: l_Lpwm=3;xiayang        ; break ;
case 0x61: leftzhuan ; break ;
case 0x62:        stopzhuan ;break ;
case 0x63:         rightzhuan        ;break;
case 0x64:        jd=1;break;
case 0x65:        jd=0;break;
ES=1;
void send_char()
        SBUF = buf;
        while(!TI);                                // ??????
        TI = 0;                                        // ????????
ID:918467 發表于 2021-6-8 19:06 | 只看該作者
請問我想將HC-05接在5V工作電壓的STC89C52單片機上,是可以直接接,還是需要降壓處理,資料里說需要LDO處理,請大神指導,謝謝
主站蜘蛛池模板: 亚洲久久久 | 97色综合 | 免费看黄色录像 | 国产人成一区二区三区影院 | 国产一区二区三区久久 | 天天操天天碰 | 日韩国产精品一区二区 | 国产一区二区三区视频在线 | 久久天天操 | 香港三日本三级少妇66 | 国产精品麻豆视频 | 国产理论片在线观看 | 精品国产一区二区在线观看 | 午夜久久久 | 成人在线播放视频 | 日韩av资源 | 国产一级黄色大片 | 午夜精品视频 | 欧美中文字幕在线观看 | 成人久久视频 | 国产欧美成人 | 亚洲国产天堂 | 中文在线字幕 | 不用播放器的av | 欧美成人高清 | 成年视频在线观看 | 91精品国产色综合久久不卡98 | 亚洲精品一区二区三区精华液 | 久久久一区二区三区 | 色综合久久天天综合网 | 亚洲黄色在线 | 免费看的黄色片 | 日韩 欧美 亚洲 | 日韩精品中文字幕在线观看 | 久视频在线 | 亚洲精品成人网 | 欧美综合一区 | 中文字字幕在线 | 国产午夜三级一区二区三 | 日本不卡在线视频 | 久久视频一区二区 |
