查看: 10032|回復: 1
51單片機基礎實驗程序:LCD9648液晶
LCD9648液晶刷屏、顯示圖片、顯示文字程序
  1. #include<reg51.h>
  2. sbit CS0  = P0^0;                //片選
  3. sbit RST  = P0^1;                //復位
  4. sbit RS   = P2^7;                 //數據命令選擇端
  5. sbit SCL  = P2^6;                //SPI時鐘端
  6. sbit SDA  = P2^5;                //SPI數據端
  7. void Delay10ms(unsigned int c)   //誤差 0us
  8. {
  9.     unsigned char a,b;
  10.     for(;c>0;c--)
  11.         for(b=38;b>0;b--)
  12.             for(a=130;a>0;a--);
  13. }
  14. void  SendDataSPI(unsigned char dat)
  15. {
  16.    unsigned char i;
  17.
  18.    for(i=0; i<8; i++)
  19.    {
  20.       if( (dat&0x80)!=0 ) SDA = 1;
  21.         else SDA = 0;
  22.       dat <<= 1;
  23.           SCL = 0;
  24.     SCL = 1;
  25.    }
  26. }
  27. void WriteComm(unsigned int i)
  28. {
  29.     CS0 = 0;
  30.         RS  = 0;
  31.         SendDataSPI(i);
  32.         CS0 = 1;
  33. }
  34. void WriteData(unsigned int i)
  35. {
  36.     CS0 = 0;
  37.         RS  = 1;
  38.         SendDataSPI(i);
  39.         CS0 = 1;
  40. }
  41. void LCD_Init(void)
  42. {
  43.         unsigned int i;
  44.         RST=1;
  45.         for(i = 0; i < 1000; i++);
  46.
  47.         RST=0;
  48.         for(i = 0; i < 1000; i++);
  49.         RST=1;
  50.         for(i = 0; i < 1000; i++);
  51.   WriteComm(0xe2);                  //軟件復位
  52.         WriteComm(0xc8);                  //0xA0段方向選擇正常方向(0xA1為反方向
  53.         WriteComm(0xa0);                  //0xC8普通方向選擇選擇反向,0xC0為正常方向
  54.         WriteComm(0x2f);
  55.         WriteComm(0x26);
  56.         WriteComm(0x81);                  //背景光對比度
  57.         WriteComm(0x10);                  //0x10設置列高地址
  58.         WriteComm(0xaf);                  //開啟顯示
  59.         //WriteComm(0xa4);
  60. }
  61. void Clear()
  62. {
  63.         unsigned char i,j;
  64.
  65.   WriteComm(0x40);
  66.         for(i=0; i < 9; i++)//一共九頁
  67.         {
  68.                 WriteComm(0xb0+i);//頁地址
  69.                 WriteComm(0x10);//列地址
  70.                 WriteComm(0x00);//列地址
  71.
  72.                 for(j = 0; j < 96; j++)
  73.                 {
  74.                         WriteData(0x00);
  75.                 }
  76.         }
  77. }
  78. void Displine(void)                          //行掃屏
  79.   {
  80.    unsigned int i,k;
  81.         for(i = 0 ; i <6; i++)
  82.         {
  83.             WriteComm(0x40);  //set scroll line         設置滾動一行
  84.             WriteComm(0xb0+i);//set page address                設置頁地址
  85.             WriteComm(0x10); //column  msb                列最高位
  86.             WriteComm(0x00); //column  lsb                列最低位
  87.             for(k=0;k<96;k++)
  88.             {
  89.                      WriteData(0XF0);
  90.                          Delay10ms(1);
  91.              }
  92.     }
  93.         Clear();
  94. }
  95. void Clear_Lcd()
  96. {
  97.         unsigned char i,j;
  98.         for(i = 0; i < 6; i++)
  99.         {
  100.                 WriteComm(0x40);
  101.                 WriteComm(0XB0+i);
  102.                 WriteComm(0x10);
  103.                 WriteComm(0x00);
  104.                 for(j = 0; j < 96; j++)
  105.                 {
  106.                         WriteData(0xff);
  107.                         Delay10ms(1);
  108.                 }
  109.         }
  110.         for(i = 0; i < 7; i++)
  111.         {
  112.                 WriteComm(0XB0+i);
  113.                 WriteComm(0x10);
  114.                 WriteComm(0x00);
  115.                 for(j = 0; j < 96; j++)
  116.                 {
  117.                         WriteData(0x00);
  118.                         Delay10ms(1);
  119.                 }
  120.         }
  121. }
  122. void main()
  123. {
  124.         LCD_Init();
  125.         Clear();
  126.         while(1)
  127.         {
  128.                 //Displine();
  129.                 Clear_Lcd();
  130.         }
  131. }
實驗30:LCD9648液晶.7z (596.06 KB, 下載次數: 105)
收藏收藏1 分享淘帖 頂1 踩
ID:883423 發表于 2021-3-18 11:20 | 只看該作者
好,非常好,verygood
主站蜘蛛池模板: 日本一区二区三区免费观看 | 人人草在线视频 | 秋霞一区二区 | 国产欧美日韩在线观看 | 精品欧美一区二区三区久久久 | 久久精品欧美一区 | 91女人18毛片水多国产 | 人人爽人人爽人人 | 羞羞的视频在线观看 | 激情影院在线观看 | 欧美三级又粗又硬 | 国产免费a| 五月伊人网 | 国产999视频 | 亚洲欧美中文字幕 | 国产中文字幕一区 | 日韩一级免费 | 亚洲综合二区 | 日韩一级av毛片 | 欧美成人猛片aaaaaaa | 久久a视频 | 欧美黄色一区 | 欧美日韩亚洲一区二区 | 国产免费黄色片 | 欧美不卡| 一本一道久久a久久精品蜜桃 | 中文字幕伊人 | 91国产丝袜在线播放 | 亚洲午夜av | 在线观看一区 | 国产特黄| 国产成人在线观看免费网站 | 欧美一区二区三区的 | av在线免费播放 | 黄免费视频 | 天天色天天色 | 欧美一级片在线 | 色在线播放| 伊人久久综合 | 日韩毛片在线观看 | 亚洲视频免费观看 |
