查看: 5091|回復: 10
STM32F407 HAL庫驅動FSMC的TFT屏(HAL庫版)
ID:466381 發表于 2021-3-7 15:20 | 顯示全部樓層 |閱讀模式
研究了一下fsmc,終于成功解決了TFT屏的顯示(記得把KEIL的O3優化調成O0,否則會有BUG)
  1. /* Includes ------------------------------------------------------------------*/
  2. #include "main.h"
  3. #include "gpio.h"
  4. #include "fsmc.h"
  5. /* Private includes ----------------------------------------------------------*/
  6. /* USER CODE BEGIN Includes */
  7. #include "lcd.h"
  8. /* USER CODE END Includes */
  9. /* Private typedef -----------------------------------------------------------*/
  10. /* USER CODE BEGIN PTD */
  11. /* USER CODE END PTD */
  12. /* Private define ------------------------------------------------------------*/
  13. /* USER CODE BEGIN PD */
  14. /* USER CODE END PD */
  15. /* Private macro -------------------------------------------------------------*/
  16. /* USER CODE BEGIN PM */
  17. /* USER CODE END PM */
  18. /* Private variables ---------------------------------------------------------*/
  19. /* USER CODE BEGIN PV */
  20. /* USER CODE END PV */
  21. /* Private function prototypes -----------------------------------------------*/
  22. void SystemClock_Config(void);
  23. /* USER CODE BEGIN PFP */
  24. /* USER CODE END PFP */
  25. /* Private user code ---------------------------------------------------------*/
  26. /* USER CODE BEGIN 0 */
  27. /* USER CODE END 0 */
  28. /**
  29.   * @brief  The application entry point.
  30.   * @retval int
  31.   */
  32. int main(void)
  33. {
  34.   /* USER CODE BEGIN 1 */
  35.   /* USER CODE END 1 */
  36.   /* MCU Configuration--------------------------------------------------------*/
  37.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  38.   HAL_Init();
  39.   /* USER CODE BEGIN Init */
  40.   /* USER CODE END Init */
  41.   /* Configure the system clock */
  42.   SystemClock_Config();
  43.   /* USER CODE BEGIN SysInit */
  44.   /* USER CODE END SysInit */
  45.   /* Initialize all configured peripherals */
  46.   MX_GPIO_Init();
  47.   MX_FSMC_Init();
  48.   /* USER CODE BEGIN 2 */
  49.         HAL_Delay(500);
  50.         LCD_Init();           //初始化LCD FSMC接口
  51.         LCD_DisplayOn();
  52.         POINT_COLOR=DARKBLUE;      //畫筆顏色:紅色
  53.   /* USER CODE END 2 */
  54.   /* Infinite loop */
  55.   /* USER CODE BEGIN WHILE */
  56.   while (1)
  57.   {
  58.     /* USER CODE END WHILE */
  59.     /* USER CODE BEGIN 3 */
  60.                 LCD_Clear(RED);
  61.                 HAL_Delay(200);
  62.                                 LCD_Clear(BLUE);
  63.                                 HAL_Delay(200);
  64.                                 LCD_Clear(WHITE);
  65.                                 HAL_Delay(200);
  66.                                 LCD_Clear(GREEN);
  67.                                 HAL_Delay(200);
  68.                                 LCD_Clear(BLACK);
  69.                                 HAL_Delay(200);
  70.                 LCD_Clear(YELLOW);
  71.                                 HAL_Delay(200);
  72.   }
  73.   /* USER CODE END 3 */
  74. }
  75. /**
  76.   * @brief System Clock Configuration
  77.   * @retval None
  78.   */
  79. void SystemClock_Config(void)
  80. {
  81.   RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  82.   RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  83.   /** Configure the main internal regulator output voltage
  84.   */
  85.   __HAL_RCC_PWR_CLK_ENABLE();
  86.   __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  87.   /** Initializes the RCC Oscillators according to the specified parameters
  88.   * in the RCC_OscInitTypeDef structure.
  89.   */
  90.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  91.   RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  92.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  93.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  94.   RCC_OscInitStruct.PLL.PLLM = 4;
  95.   RCC_OscInitStruct.PLL.PLLN = 168;
  96.   RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  97.   RCC_OscInitStruct.PLL.PLLQ = 4;
  98.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  99.   {
  100.     Error_Handler();
  101.   }
  102.   /** Initializes the CPU, AHB and APB buses clocks
  103.   */
  104.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  105.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  106.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  107.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  108.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  109.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  110.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
  111.   {
  112.     Error_Handler();
  113.   }
  114.   /** Enables the Clock Security System
  115.   */
  116.   HAL_RCC_EnableCSS();
  117. }
  118. /* USER CODE BEGIN 4 */
  119. /* USER CODE END 4 */
  120. /**
  121.   * @brief  This function is executed in case of error occurrence.
  122.   * @retval None
  123.   */
  124. void Error_Handler(void)
  125. {
  126.   /* USER CODE BEGIN Error_Handler_Debug */
  127.   /* User can add his own implementation to report the HAL error return state */
  128.   __disable_irq();
  129.   while (1)
  130.   {
  131.   }
  132.   /* USER CODE END Error_Handler_Debug */
  133. }
  134. #ifdef  USE_FULL_ASSERT
  135. /**
  136.   * @brief  Reports the name of the source file and the source line number
  137.   *         where the assert_param error has occurred.
  138.   * @param  file: pointer to the source file name
  139.   * @param  line: assert_param error line source number
  140.   * @retval None
  141.   */
  142. void assert_failed(uint8_t *file, uint32_t line)
  143. {
  144.   /* USER CODE BEGIN 6 */
  145.   /* User can add his own implementation to report the file name and line number,
  146.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  147.   /* USER CODE END 6 */
  148. }
  149. #endif /* USE_FULL_ASSERT */
FSMC_F4(SHENJIAJIA).7z (6.76 MB, 下載次數: 87)
ID:466381 發表于 2021-3-7 15:21 | 顯示全部樓層
MCU:STM32F407VET6
MCU:STM32F407VET6
板子和TFT: MCUDEV配套的
ID:142284 發表于 2021-10-1 16:59 | 顯示全部樓層
目前正在學習FSMC驅動TFTLCD屏
ID:881187 發表于 2022-2-25 09:53 | 顯示全部樓層
屏幕是什么型號的
ID:688045 發表于 2022-3-18 00:42 | 顯示全部樓層
你好,請問驅動8位的LCD和16位的有什么區別嗎
樓主有8位lcd的驅動歷程嗎
ID:759466 發表于 2022-8-10 18:51 | 顯示全部樓層
下下來移植到GD32上面,看看行不行
ID:459376 發表于 2023-1-8 19:25 | 顯示全部樓層
剛好在了解這方面的。謝謝!
ID:1100592 發表于 2023-11-21 08:23 | 顯示全部樓層
剛好在了解這方面的,我的也是VET6,很了解這個用法
ID:1100592 發表于 2023-11-24 08:59 | 顯示全部樓層
好想要這個數據來試試內容
主站蜘蛛池模板: 一区二区三区视频在线 | 成人欧美日韩 | 色八区| 日韩1级片| 国产精品成人国产乱 | 午夜影院黄 | 免费黄色av | 久久性色| 色天天综合 | 欧美精品亚洲精品 | 黄色网址av| 九九色综合 | 欧美爱爱视频 | 久久中文网 | 亚洲激情另类 | 国产乱码一区二区 | 少妇福利视频 | 亚洲欧美国产精品 | 五月婷婷综合激情 | 欧美一级在线 | 国产一区免费 | 成人免费视频一区二区 | www.成人| 9.1成人看片 | 免费午夜视频 | 免费性爱视频 | 日本少妇久久 | 玖草视频| 免费一级a毛片 | 中文字幕免费 | 日韩欧美在线视频观看 | 亚洲国产精品久久 | 久久狠狠干 | 曰韩毛片 | 天天色视频 | 久久性生活视频 | 日韩久久精品 | 日日夜夜天天操 | 一区二区三区四区在线 | 日韩视频二区 | 亚洲亚洲人成综合网络 |
