ad1674 的文獻和接口方法
包含c52單片機和ad1674的接線方法
- #include"reg51.h"
- sbit CS=P3^0;
- sbit A0=P3^1;
- sbit CE=P3^2;
- sbit RC=P3^3;
- sbit S8=P2^7;
- sbit CE1=P2^0;
- sbit BA=P2^1;
- unsigned char code Num_npt[10]={0XFC,0X60,0XDA,0XF2,0X66,0XB6,0XBE,0XE0,0XFE,0XF6};
- unsigned char code Num_pt[10]={0XFD,0X61,0XDB,0XF2,0X67,0XB7,0XBF,0XE1,0XFF,0XF7};
- unsigned char code Sel_num[4]={0x70,0xb0,0xd0,0xe0};
- void change(void);
- unsigned char read(void);
- void display(unsigned char Display);
- void delay(unsigned char n);
- unsigned char result;
- void main()
- S8=1;
- CE1=0;
- BA=0;
- while(1)
- delay(1);
- change();
- delay(1);
- result=read();
- delay(1);
- display(result);
- void change(void)
- //轉換控制過程
- CS=0;
- RC=0;
- A0=1;
- CE=1;
- delay(1);
- RC=0;
- CS=1;
- A0=1;
- CE=0;
- //讀取控制過程
- CS=0;
- A0=0;
- RC=1;
- CE=1;
- return P0;
- delay(1);
- CE=0;
- RC=1;
- CS=1;
- A0=0;
- //轉換結果處理
- unsigned char i=0,j=0;
- //顯示數據處理
- double out;
- unsigned char w10=0;
- unsigned char w1=0;
- unsigned char w01=0;
- unsigned char w001=0;
- out=Display*0.0390625;
- w10=out/10;
- w1=out/1;
- w01=(out-w1)/0.1;
- w001=(out-w1-w01*0.1)/0.01;
- //點亮相應數碼管
- for(i=0;i<4;i++)
- P3=Sel_num[i];
- if(i==0) P1=Num_npt[w10];
- if(i==1) P1=Num_pt[w1];
- if(i==2) P1=Num_npt[w01];
- if(i==3) P1=Num_npt[w001];
- delay(1);
- unsigned char l=0;
- unsigned char m=0;
- for(l=0;l<10;l++)
- for(m=0;m<n;m++);
AD1674001.7z
(2.79 MB, 下載次數: 76)
2021-3-24 22:33 上傳
點擊文件名下載附件
