查看: 3211|回復: 0
STM32+MQ-3酒精檢測hal庫源程序 LCD1602顯示
電路原理圖如下:
#include "main.h"
#include "stm32f1xx_hal.h"
/* USER CODE BEGIN Includes */
#include "STM32_LCD1602.h"
#include "FLSH.h"
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
ADC_HandleTypeDef hadc1;
TIM_HandleTypeDef htim4;
/* USER CODE BEGIN PV */
//下面定義關于蜂鳴器的一些
#define Beep_GPIO GPIOB
#define Beep_Pin  GPIO_PIN_0
unsigned char Beep1=0;
//下面定義IO
#define Key1 HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_13)
#define Key2 HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_14)
#define Beep_0 HAL_GPIO_WritePin(Beep_GPIO,Beep_Pin,GPIO_PIN_RESET)
#define Beep_1 HAL_GPIO_WritePin(Beep_GPIO,Beep_Pin,GPIO_PIN_SET)
#define LED0_0 HAL_GPIO_WritePin(GPIOB,GPIO_PIN_11,GPIO_PIN_RESET)
#define LED0_1 HAL_GPIO_WritePin(GPIOB,GPIO_PIN_11,GPIO_PIN_SET)
#define LED1_0 HAL_GPIO_WritePin(GPIOB,GPIO_PIN_12,GPIO_PIN_RESET)
#define LED1_1 HAL_GPIO_WritePin(GPIOB,GPIO_PIN_12,GPIO_PIN_SET)
#define JDQ_0 HAL_GPIO_WritePin(GPIOB,GPIO_PIN_10,GPIO_PIN_RESET)
#define JDQ_1 HAL_GPIO_WritePin(GPIOB,GPIO_PIN_10,GPIO_PIN_SET)
//下面定義關于按鍵用的
unsigned char key1_flag=0;
unsigned char key2_flag=0;
unsigned char sec1=0;
unsigned char sec2=0;
//下面定義關于酒精的一些變量
unsigned int  Alcohol  = 0;
unsigned char Read_ADC = 0;
unsigned char Alcohol_H = 0;
//設定關于定時器的
unsigned int Time4_ms=0;
//下面定義存儲部分用到的
unsigned char memory_flag=0;
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_ADC1_Init(void);
static void MX_TIM4_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
void memory()
{  if(memory_flag==1)
           memory_flag=0;
                 Write_flsh_byte(0x0800F000,Alcohol_H);
void read_memory()
  Alcohol_H=readFlash(0x0800F000);
        if(Alcohol_H>100) Alcohol_H=20;
void Display()
  LCD1602_write(0,0x80);
        LCD1602_writebyte(" Alcohol :");
  LCD1602_write(1,0x30+Alcohol/100%10);
  LCD1602_write(1,0x30+Alcohol/10%10);
  LCD1602_write(1,0x30+Alcohol%10);
        LCD1602_writebyte("%     ");
        LCD1602_write(0,0xC0);
        LCD1602_writebyte("Alcohol_H:");
  LCD1602_write(1,0x30+Alcohol_H/100%10);
  LCD1602_write(1,0x30+Alcohol_H/10%10);
  LCD1602_write(1,0x30+Alcohol_H%10);
void Key_Dispose()
  if(!Key1)
          if(key1_flag==1||sec1==0)
                        key1_flag=0;
                  if(Alcohol_H<100) Alcohol_H++;
          if(key1_flag==0)
                  key1_flag=1;
                        memory_flag = 1;
                sec1=2;
  if(!Key2)
          if(key2_flag==1||sec2==0)
                        key2_flag=0;
                  if(Alcohol_H>0) Alcohol_H--;
          if(key2_flag==0)
                  key2_flag=1;
                        memory_flag = 1;
                sec2=2;
void Get_ADC()
  if(Read_ADC==1)
                Read_ADC=0;
                HAL_ADC_Start(&hadc1);
                HAL_ADC_PollForConversion(&hadc1,0xffff); //等待檢測結束
                Alcohol=((HAL_ADC_GetValue(&hadc1)))/31; //就目前電路來說,測的數據是 0-2.5V電壓,也就是 0 - 3100AD 對應 0 - 100%。   2.5V-3100Ad  是因為 STM32 12位AD 3.3V=4095AD
                HAL_ADC_Stop(&hadc1); //結束AD檢測
void Police()
   if(Alcohol_H<Alcohol)
           Beep1=1;
                 LED0_1;
                 LED1_0;
                 JDQ_0;
           Beep1=0;
                 LED0_0;
                 LED1_1;
                 JDQ_1;
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim) //定時器設定的是每隔1ms執行一次
     if(htim==&htim4)
         Time4_ms++;
                                if(Time4_ms%50==0) Key_Dispose();
        if(Time4_ms%100==0)
                                  if(Beep1==1)  Beep_GPIO->ODR^= Beep_Pin;
                                        else Beep_0;
                                if(Time4_ms%1000==0)
                                  Read_ADC=1;
                                        if(sec1!=0) sec1--;
                                        if(sec2!=0) sec2--;
                                if(Time4_ms>=2000)  Time4_ms=0;
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval None
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_ADC1_Init();
  MX_TIM4_Init();
  /* USER CODE BEGIN 2 */
        HAL_Delay(100);
        LCD1602_cls();
  HAL_TIM_Base_Start_IT(&htim4);
        read_memory();
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
                memory();
                Display();
                Get_ADC();
                Police();
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI_DIV2;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL16;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADC;
  PeriphClkInit.AdcClockSelection = RCC_ADCPCLK2_DIV6;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/* ADC1 init function */
  ADC_ChannelConfTypeDef sConfig;
    /**Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc1.Init.ContinuousConvMode = DISABLE;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.NbrOfConversion = 1;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    /**Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_9;
  sConfig.Rank = ADC_REGULAR_RANK_1;
  sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
/* TIM4 init function */
  TIM_ClockConfigTypeDef sClockSourceConfig;
  TIM_MasterConfigTypeDef sMasterConfig;
  htim4.Instance = TIM4;
  htim4.Init.Prescaler = 63;
  htim4.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim4.Init.Period = 1000;
  htim4.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim4.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  if (HAL_TIM_Base_Init(&htim4) != HAL_OK)
  sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  if (HAL_TIM_ConfigClockSource(&htim4, &sClockSourceConfig) != HAL_OK)
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim4, &sMasterConfig) != HAL_OK)
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0|GPIO_PIN_10, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOB, GPIO_PIN_11|GPIO_PIN_12, GPIO_PIN_SET);
  /*Configure GPIO pins : PB0 PB10 PB11 PB12 */
  GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_10|GPIO_PIN_11|GPIO_PIN_12;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_PULLUP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  /*Configure GPIO pins : PB13 PB14 */
  GPIO_InitStruct.Pin = GPIO_PIN_13|GPIO_PIN_14;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
代碼: STM32.7z (2.9 MB, 下載次數: 70)
主站蜘蛛池模板: 国产精品美女久久久久久久久 | 久久香蕉国产 | 欧美一级黄色片 | 一级黄色片免费观看 | 欧美日韩成人一区二区三区 | 国产福利视频在线观看 | 网站av | 日韩欧美精品 | 99热国产在线| 久久在线播放 | 四虎精品在线 | 亚洲黄色片 | 国产精品自拍一区 | 一区视频在线 | 亚洲青青草 | 五月色综合 | 欧美日韩性| 国产精品毛片一区二区在线看 | 综合一区二区三区 | 中文字幕91| 对白刺激国产子与伦 | 99re视频在线 | 国产性生活视频 | 日韩精品视频免费在线观看 | 成人在线免费视频观看 | 视频一二区 | 国产欧美精品一区二区 | 日韩欧美网站 | 欧美在线免费 | 成人免费高清视频 | 青青草手机视频 | aaa级片| 91在线免费视频观看 | 一级片大全 | 久久免费国产 | 色视频www在线播放国产人成 | 国产美女一区 | 成人午夜毛片 | 98在线视频 | 欧美xxx视频 | 一级做a爱片性色毛片 |
