- #include <reg52.h> //調用單片機頭文件
- #define uchar unsigned char //無符號字符型 宏定義 變量范圍0~255
- #define uint unsigned int //無符號整型 宏定義 變量范圍0~65535
- #include <intrins.h>
- sbit K1=P1^0;
- sbit K2=P1^1;
- sbit K3=P1^2;
- sbit K4=P1^3;
- sbit beep = P1^7; //蜂鳴器IO口定義
- sbit LED=P3^4;
- sbit SH = P3^5;
- sbit ST = P3^6;
- sbit DS = P3^7;
- sbit DCMOTOR=P3^3; //L298電機驅動控制引腳
- uchar num_jin;
- uchar num_chu;
- uchar num_car;
- uchar code zz[]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09}; //??
- uchar code fz[]={0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01}; //??
- void DCmotorOpen();
- void DCmotorClose();
- void motor_ting(uint n);
- #include "lcd1602.h"
- /***********************1ms延時函數*****************************/
- void delay_1ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<120;j++);
- /****步進電機驅動模塊****/
- void delay(uint ms)
- uint t;
- while(ms--)
- for(t=0;t<120;t++);
- void motor_zz(uint n)
- uint i,j;
- for(i=0;i<5*n;i++)
- for(j=0;j<8;j++)
- P2=zz[j];
- LED=1;
- delay(20);
- void motor_fz(uint n)
- uint i,j;
- for(j=0;j<8;j++)
- P2=fz[j];
- LED=0;
- delay(20);
- P2=0x00;
- delay(2000);
- void write_74hc595(unsigned int num)
- int i;
- ST = 0;
- for(i=0; i<16; i++)
- SH = 0;
- if (num & 0x0001)
- DS = 1;
- else
- DS = 0;
- SH = 1;
- num >>= 1;
- ST = 1;
- unsigned int num_2_led(unsigned int num)
- int i;
- unsigned int ret=0;
- if (num >= 16)
- return 0xFFFF;
- for(i=0;i<num;i++)
- ret |= 1<<i;
- return ret;
- void key() //獨立按鍵程序
- if(!K1) // 汽車進入
- delay_1ms(20);
- if(!K1)
- while(!K1);
- motor_zz(1);//步進電機啟動開閘門
- motor_ting(2);
- if(num_car==16)
- beep=0; delay_1ms(200); beep=1;
- if(num_car<16)
- num_car++;
- motor_fz(1);//步進電機啟動開閘門
- if(num_car>=6)
- DCmotorOpen();
- if(num_jin<=255)
- num_jin++;
- write_sfm2(1,4,num_jin);
- write_sfm2(1,12,num_chu);
- write_sfm2(2,4,num_car);
- write_sfm2(2,12,16-num_car);
- write_74hc595(num_2_led(num_car));
- if(!K2) // // 汽車駛出
- delay_1ms(20);
- if(!K2)
- while(!K2);
- motor_zz(1);
- motor_ting(2);
- if(num_car>=1)
- num_car--;
- motor_fz(1);
- if(num_chu<=255)
- num_chu++;
- /***********************手動修改小區內停車位*************************************/
- if(!K3) // 人工調節
- delay_1ms(20);
- if(!K3)
- while(!K3);
- if(num_car<16)
- num_car++;
- if(!K4) // // 人工調節
- delay_1ms(20);
- if(!K4)
- while(!K4);
- if(num_car>=1)
- num_car--;
滿分51hei設計單片機的停車場車位管理系統.7z
(3.09 MB, 下載次數: 219)
2021-4-28 17:24 上傳
點擊文件名下載附件
