查看: 39436|回復(fù): 71
16x16點(diǎn)陣完整原理圖和程序
ID:53134 發(fā)表于 2013-8-17 01:02 | 顯示全部樓層 |閱讀模式
程序下載: 點(diǎn)陣1616.rar (314.04 KB, 下載次數(shù): 799)
評(píng)分
參與人數(shù) 9黑幣 +34 收起 理由
Scre + 1 贊一個(gè)!
qwe阿薩德23 + 2
gjh571064535 + 5 贊一個(gè)!
法師Zero + 5 回帖助人的獎(jiǎng)勵(lì)!
afdshngkjfgakl; + 1
天虹軟件 + 5 贊一個(gè)!
jacosk + 5 贊一個(gè)!
sunyuhao + 5 贊一個(gè)!
962091602 + 5 很給力!
查看全部評(píng)分
ID:262 發(fā)表于 2013-9-6 15:16 | 顯示全部樓層
好東東我頂,51hei(51黑)單片機(jī)論壇有你更精彩.
ID:52286 發(fā)表于 2013-10-14 00:26 | 顯示全部樓層
  1. #include<reg52.h>
  2. #include<74HC595.h>
  4. #define uint unsigned int
  5. uchar code table_L[]={0xff,0x7f, 0xff,0xbf, 0xff,0xdf, 0xff,0xef, 0xff,0xf7, 0xff,0xfb, 0xff,0xfd, 0xff,0xfe,
  6.                                           0x7f,0xff, 0xbf,0xff, 0xdf,0xff, 0xef,0xff, 0xf7,0xff, 0xfb,0xff, 0xfd,0xff, 0xfe,0xff};
  7. uchar code table_H[]={
  8. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
  9. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",1*/
  10. 0x00,0x08,0x40,0x04,0x40,0x02,0xFE,0x7F,0x20,0x01,0x20,0x02,0x00,0x40,0x20,0x49,
  11. 0x20,0x49,0xFE,0x3F,0x90,0x24,0x90,0x24,0x90,0x20,0x80,0x20,0x00,0x20,0x00,0x00,/*"桂",0*/
  12. 0x00,0x10,0x80,0x0C,0x80,0x02,0xF8,0x3F,0x40,0x01,0x40,0x0A,0x00,0x04,0x40,0x02,
  13. 0x40,0x01,0xFC,0x7F,0x20,0x01,0x20,0x02,0x00,0x04,0x00,0x08,0x00,0x08,0x00,0x00,/*"林",1*/
  14. 0x00,0x00,0x00,0x00,0xE0,0x01,0x20,0x06,0x20,0x05,0x20,0x05,0xFE,0x3F,0x90,0x42,
  15. 0x10,0x42,0x10,0x42,0xF0,0x41,0x00,0x40,0x00,0x40,0x00,0x38,0x00,0x00,0x00,0x00,/*"電",2*/
  16. 0x00,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x88,0x00,0x88,0x20,0x88,0x20,0xE4,0x40,
  17. 0x94,0x3F,0x4C,0x00,0x44,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x00,0x00,0x00,0x00,/*"子",3*/
  18. 0x00,0x10,0x80,0x08,0x90,0x04,0x90,0x02,0xF0,0x7F,0x48,0x01,0x44,0x01,0x00,0x02,
  19. 0x50,0x02,0xA0,0x02,0x00,0x02,0xFE,0xFF,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x00,/*"科",4*/
  20. 0x00,0x04,0x40,0x04,0x40,0x22,0xFE,0x7F,0x20,0x01,0x20,0x20,0x00,0x20,0x20,0x15,
  21. 0x20,0x09,0xFE,0x08,0x90,0x16,0x90,0x21,0x00,0x60,0x00,0x40,0x00,0x40,0x00,0x00,/*"技",5*/
  22. 0x00,0x00,0x00,0x40,0x80,0x20,0x80,0x10,0x80,0x08,0x80,0x06,0xFE,0x01,0x40,0x02,
  23. 0x40,0x04,0x40,0x08,0x40,0x10,0x40,0x20,0x00,0x60,0x00,0x40,0x00,0x40,0x00,0x00,/*"大",6*/
  24. 0x00,0x00,0x80,0x09,0xE0,0x08,0x44,0x08,0x48,0x08,0x40,0x09,0xA4,0x48,0xA8,0x86,
  25. 0xA0,0x7D,0xB0,0x04,0x2E,0x04,0x20,0x04,0x60,0x04,0x20,0x00,0x00,0x00,0x00,0x00,/*"學(xué)",7*/
  26. 0x00,0x20,0x40,0x11,0x40,0x0A,0x20,0x04,0xE0,0x0B,0x00,0x40,0x80,0x20,0x70,0x18,
  27. 0x4E,0x07,0x20,0x08,0xA0,0x10,0x60,0x20,0x20,0x60,0x00,0x40,0x00,0x40,0x00,0x00,/*"歡",8*/
  28. 0x80,0x10,0x80,0x10,0x88,0x12,0x90,0x1D,0x00,0x10,0xF0,0x13,0x10,0x12,0x08,0x11,
  29. 0x0C,0x20,0xE0,0x2F,0x10,0x20,0x10,0x61,0xF0,0x61,0x00,0x20,0x00,0x20,0x00,0x00,/*"迎",9*/
  30. 0x00,0x00,0x40,0x20,0x20,0x30,0xF0,0x03,0x0C,0x18,0x40,0x20,0xA0,0x41,0x18,0x48,
  31. 0x16,0x52,0xF0,0x43,0x08,0x50,0xA8,0x60,0x18,0x45,0x00,0x08,0x00,0x00,0x00,0x00,/*"您",10*/
  32. 0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x33,0xF8,0x33,0x00,0x00,0x00,0x00,0x00,0x00,
  33. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",11*/
  34. 0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x33,0xF8,0x33,0x00,0x00,0x00,0x00,0x00,0x00,
  35. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",12*/
  36. 0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,/*"-",13*/
  37. 0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,/*"-",14*/
  38. 0x00,0x00,0x00,0x06,0x80,0x03,0x00,0x00,0x00,0x10,0x00,0x20,0x00,0x40,0xFC,0x3F,
  39. 0x00,0x00,0x00,0x00,0x40,0x00,0x80,0x01,0x00,0x03,0x00,0x00,0x00,0x00,0x00,0x00,/*"小",15*/
  40. 0x00,0x04,0x40,0x02,0x40,0x01,0xFE,0x7F,0x20,0x01,0x20,0x43,0x40,0x21,0xC8,0x1E,
  41. 0x78,0x00,0x28,0x00,0x64,0xFE,0xA4,0x00,0x20,0x01,0x00,0x02,0x00,0x02,0x00,0x00,/*"橋",16*/
  42. 0x00,0x00,0x40,0x00,0x88,0x30,0x10,0x0E,0x00,0x40,0x20,0x30,0xA0,0x0D,0x60,0x01,
  43. 0xA2,0x3E,0x94,0x00,0xD0,0x1E,0x90,0x20,0x10,0x20,0x00,0x20,0x00,0x38,0x00,0x00,/*"流",17*/
  44. 0x00,0x10,0x80,0x10,0x80,0x08,0x40,0x04,0x40,0x03,0xC0,0x20,0x00,0x40,0xFC,0x7F,
  45. 0x80,0x00,0x40,0x01,0x20,0x02,0x18,0x04,0x00,0x0C,0x00,0x08,0x00,0x08,0x00,0x00,/*"水",18*/
  46. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
  47. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",1*/
  48. };
  49. uchar L=0,H=0;
  50. uint t=0,x=0;
  51. #define h sizeof(table_H)
  52. void main()
  53. {
  54. //        extern uint h;
  55.         EA=1;
  56.         ET0=1;
  57.         TMOD=0x01;
  58.         TH0=(65536-1000)/256;
  59.         TL0=(65536-1000)%256;
  60.         TR0=1;
  61. //        h=sizeof(table_H);
  62.         while(1)
  63.         {
  64.                 if(L==32)
  65.                 {
  66.                         L=0;
  67.                         H=0;
  68.                 }
  69.
  70.         }
  71. }
  72. void T0_time() interrupt 1
  73. {
  74.         TH0=(65536-1000)/256;
  75.         TL0=(65536-1000)%256;
  76.         Input(table_L[L]);
  77.         Input(table_L[L+1]);
  78.         Input(table_H[H+x]);
  79.         Input(table_H[H+x+1]);
  80.         Output();
  81.         L=L+2;
  82. //        if(L==32)L=0;
  83.         H=H+2;
  84. //        if(H==32)H=0;
  85.         t++;
  86.         if(t==100)//移動(dòng)
  87.         {
  88.                 t=0;
  89.                 x=x+2;
  90.                 if(x>=h-32)x=0;
  91.         }
  92. }
ID:55638 發(fā)表于 2013-10-14 23:07 | 顯示全部樓層
收走  先拿來(lái)參考
ID:55947 發(fā)表于 2013-10-15 02:00 來(lái)自觸屏版 | 顯示全部樓層
還好還好 51黑論壇有你更精彩。
ID:37147 發(fā)表于 2013-10-31 17:46 | 顯示全部樓層
謝謝  學(xué)習(xí)學(xué)習(xí)!
ID:55219 發(fā)表于 2013-11-29 15:06 | 顯示全部樓層
正在學(xué)習(xí),拿來(lái)參考,謝謝分享。。。。。。。。
ID:50943 發(fā)表于 2013-12-1 08:42 | 顯示全部樓層
怎么不上PROTEL 99SE的 原文件  呢?
ID:60372 發(fā)表于 2014-4-5 18:36 | 顯示全部樓層
厲害,   厲害
ID:52249 發(fā)表于 2014-4-14 18:20 | 顯示全部樓層
很實(shí)用,謝謝!
ID:50727 發(fā)表于 2014-4-24 13:27 | 顯示全部樓層
謝謝
ID:61332 發(fā)表于 2014-5-1 22:39 | 顯示全部樓層
看起來(lái)不錯(cuò)啊
ID:48266 發(fā)表于 2014-5-16 18:14 | 顯示全部樓層
多謝分享
ID:62453 發(fā)表于 2014-6-3 22:00 | 顯示全部樓層
下載來(lái)學(xué)習(xí),好東西就要支持,感謝分享
ID:65962 發(fā)表于 2014-9-9 17:38 | 顯示全部樓層
感謝樓主分享
ID:47760 發(fā)表于 2014-9-13 05:02 | 顯示全部樓層
感謝樓主分享
ID:80238 發(fā)表于 2015-5-17 11:42 | 顯示全部樓層
這么厲害。。
ID:97137 發(fā)表于 2015-11-25 20:46 | 顯示全部樓層
CON2  CON3是什么元件。看笊
ID:98493 發(fā)表于 2015-12-5 21:43 | 顯示全部樓層
感謝樓主分享
ID:98493 發(fā)表于 2015-12-5 22:06 | 顯示全部樓層
謝謝樓主想 好東西 頂起來(lái)
ID:99833 發(fā)表于 2015-12-21 16:18 | 顯示全部樓層
ID:104865 發(fā)表于 2016-2-1 14:54 | 顯示全部樓層
你的input  output函數(shù)呢?
ID:106400 發(fā)表于 2016-2-26 08:50 | 顯示全部樓層
haodongdong!!!!
ID:110633 發(fā)表于 2016-3-24 21:20 | 顯示全部樓層
這個(gè)不錯(cuò)。。。。。。。。。。。。。。。。
ID:99680 發(fā)表于 2016-4-8 13:24 | 顯示全部樓層
好東西!
ID:92810 發(fā)表于 2016-4-9 11:01 | 顯示全部樓層
感覺不錯(cuò)的樣子,,,
ID:119026 發(fā)表于 2016-5-7 11:27 | 顯示全部樓層
正在學(xué)習(xí),謝謝
ID:119026 發(fā)表于 2016-5-7 11:28 | 顯示全部樓層
非常謝謝,正在研究點(diǎn)陣
好東西,正在研究
ID:122925 發(fā)表于 2016-5-24 17:32 | 顯示全部樓層
正好需要?jiǎng)t額課題
ID:127592 發(fā)表于 2016-6-21 19:44 | 顯示全部樓層
真好測(cè)試一下
ID:132987 發(fā)表于 2016-7-19 18:13 | 顯示全部樓層
可以告訴我用的那個(gè)字模軟件嗎
ID:132987 發(fā)表于 2016-7-21 15:59 | 顯示全部樓層
        Input(table_L[L]);
        Output();
        L=L+2;
//        if(L==32)L=0;
        H=H+2;
//        if(H==32)H=0;
        t++;
                t=0;
                x=x+2;
                if(x>=h-32)x=0;
        } 這是什么意思啊
ID:132987 發(fā)表于 2016-7-21 16:11 | 顯示全部樓層
//SCK上升沿讀取數(shù)據(jù)(由高位送數(shù)據(jù)),RCK上升沿輸出鎖存數(shù)據(jù)  。沒有嚴(yán)格的時(shí)間要求
sbit SI=P3^4;//數(shù)據(jù)口
sbit SCK=P3^6;//數(shù)據(jù)輸入時(shí)鐘線
sbit RCK=P3^5;//數(shù)據(jù)輸出時(shí)鐘線
void  Input(unsigned char dat)
        char i;
        for(i=0;i<8;i++)
                dat=dat>>1;
                SCK=1;
                SI=CY;//取出最高位
                SCK=0;//上升沿
void Output()
        RCK=0;
        RCK=1;
        RCK=0;//上升沿輸出鎖存數(shù)據(jù)
ID:132987 發(fā)表于 2016-7-21 16:12 | 顯示全部樓層
求大神幫忙啊
ID:98545 發(fā)表于 2016-8-2 11:44 | 顯示全部樓層
好東東  頂
ID:126449 發(fā)表于 2016-8-13 15:27 | 顯示全部樓層
請(qǐng)問(wèn)樓主你的字模是怎么取的呢
ID:111256 發(fā)表于 2016-8-13 17:36 | 顯示全部樓層
這資料不錯(cuò),謝謝樓主了。
ID:142101 發(fā)表于 2016-10-9 21:44 | 顯示全部樓層
可以移屏顯示嗎
ID:142153 發(fā)表于 2016-10-10 10:43 | 顯示全部樓層
厲害厲害,有空我也試試。
主站蜘蛛池模板: 中文字幕97 | 亚洲综合在线视频 | 人人爽人人爽 | 欧美成人黄色 | aaa黄色片 | 午夜成人免费视频 | 自拍偷拍欧美日韩 | 毛片aaa | 免费看黄色小视频 | 欧美成人小视频 | 日韩大片在线观看 | 亚洲综合免费 | 亚洲精品少妇 | 亚洲国产精| 欧美日韩国产中文 | 免费一区二区视频 | 一区二区三区在线看 | 午夜一级片 | 谁有毛片网站 | 欧美视频一二三区 | 国内精品一区二区 | 欧美一区二区三区的 | 成年在线观看 | 国产视频黄色 | 黄色小说视频 | 黄色免费小视频 | 蜜桃视频一区二区三区 | 欧美日韩国产中文 | 日本免费不卡视频 | 中文字幕播放 | 久久久久久黄色 | 狠狠干综合网 | 成人做受黄大片 | 色涩av | 国产一级生活片 | 日韩激情一区二区 | 中国女人真人一级毛片 | 黄色网址av | 日本特级淫片 | 黄色影视大全 | 国产在线视频网站 |
