查看: 3747|回復: 2
bascom avr版仿真PID控制直流電機的例子
ID:342822 發表于 2021-5-13 13:41 | 顯示全部樓層 |閱讀模式
本帖最后由 taotie 于 2021-5-13 14:20 編輯
程序:
rem Main.bas file generated by New Project wizard
rem
rem Created:   周日 5月 9 2021
rem Processor: ATmega8
rem Compiler:  BASCOM-AVR
rem Write your code here
'name                     : PID速度控制
'copyright                : (c) 2009 by Türk Mario
'purpose                  : 直流電動機的速度控制
'micro                    : Mega8
$regfile = "m8def.dat"
$crystal = 8000000
$hwstack = 32
$swstack = 8
$framesize = 24
$baud = 9600
Config Pinb.0 = Output                                      'LED
Config Pinb.3 = Output                                      'PWM
Config Pinc.0 = Output                                      '方向
Config Pinc.1 = Output                                      '方向
Config Pind.2 = Input
Portd.2 = 1                                                 '激活上拉
Config Portd.0 = Input                                      '串口輸入
Portd.0 = 1
Dim E As Single
Dim Esum As Single
Dim Ealt As Single
Dim Kp As Single
Dim Ki As Single
Dim Kd As Single
Dim Ta As Single
Dim Proportionalteil As Single  '比例部分為單精度
Dim Integralteil As Single       '積分 部分為單精度'
Dim Differentialteil As Single    '微分部分為單精度
Dim Cv As Single
Dim Gv As Single
Dim Flanken As Integer                                      '計入側翼
Dim Flankenperturn As Integer                               '每圈側翼數
Dim Umdrehungen As Single
Dim Solldrehzahl As Single                                  '目標速度
Dim Maxdrehzahl As Single                                       '最大速度
Dim Befehl As String * 9                                    '指令
Dim Bcount As Integer                                       '計數
Dim Ar(5) As String * 5
Kp = 60
Ki = 8
Kd = 0.2
Ta = 0.04
Solldrehzahl = 10 '目標速度
Maxdrehzahl = 50   '最大速度
Flankenperturn = 30  '每圈側翼數
E = 0
Esum = 0
Ealt = 0
Config Int0 = Falling                                       '下降沿觸發中斷
Enable Interrupts
Enable Int0
On Int0 Encoder_zaehlen                                     '發生中斷時觸發編碼器計數
Config Timer1 = Timer , Prescale = 256                      'Timer1每40ms執行一次調節
On Timer1 Regler
Timer1 = 64285                                              ' 65535 - (8000000/256/Ta)   Ta = 25
Enable Timer1
Start Timer1
                                                             '定時器2負責電機PWM
Config Timer2 = Pwm , Compare Pwm = Clear Up , Pwm = On , Prescale = 64
   Ocr2 = 30
   '指定方向:
   Portc.0 = 1
   Portc.1 = 0
   '啟動PWM電機
   Enable Timer2
   Start Timer2
'$sim
Do                                                          '主程序
Input "" , Befehl
Bcount = Split(befehl , Ar(1) , ": ")     '將字符串拆分為多個數組元素。計數=拆分(源、數組(idx)、搜索)
   If Ar(1) = "Kp" Then                                     '設置和信息選項
          Kp = Val(ar(2))
   End If
    If Ar(1) = "Ki" Then
          Ki = Val(ar(2))
   End If
    If Ar(1) = "Kd" Then
          Kd = Val(ar(2) )
   End If
   If Ar(1) = "soll" Then
   Solldrehzahl = Val(ar(2))
   End If
    If Ar(1) = "max" Then
   Maxdrehzahl = Val(ar(2))
   End If
   If Ar(1) = "rps" Then
        Print Umdrehungen
   End If
    If Ar(1) = "pid" Then
        Print "Kp=" ; Kp
        Print "Ki=" ; Ki
        Print "Kd=" ; Kd
   End If
    If Ar(1) = "pwm" Then
        Print Ocr2
    End If
Loop
Encoder_zaehlen:                                            '所有邊緣都在這里計算
Incr Flanken
Return
Regler:                                                     'PID控制器算法
Timer1 = 64285
Umdrehungen = Flanken / Ta                                  '確定每秒的轉數
Umdrehungen = Umdrehungen / Flankenperturn
Flanken = 0                                                 '將邊緣計數器設置為零
E = Solldrehzahl - Umdrehungen                              '計算控制偏差
Esum = Esum + E                                             '加總錯誤
Proportionalteil = Kp * E                                   '計算比例項
Integralteil = Ki * Ta                                      '計算積分項
Integralteil = Integralteil * Esum
Differentialteil = E - Ealt                                 '計算微分項
Differentialteil = Differentialteil / Ta
Differentialteil = Differentialteil * Kd
Cv = Proportionalteil + Integralteil                        '匯總所有鏈接
Cv = Cv + Differentialteil
Gv = Maxdrehzahl / 255                                      '轉移到PWM占空比
Gv = Gv * Cv
If Gv < 0 Then Gv = 0
If Gv > 255 Then Gv = 255
Ocr2 = Gv                                    '電機PWM進行了相應的調整
Ealt = E                                                    '注意下一次運行的規則錯誤
Return
工程文件:用8.9版打開
新建文件夾 (3).zip (205.6 KB, 下載次數: 14)
ID:830831 發表于 2021-5-15 15:26 | 顯示全部樓層
結果如何? 可能分析一下?
ID:342822 發表于 2021-5-15 17:46 | 顯示全部樓層
本帖最后由 taotie 于 2021-5-16 15:29 編輯
Highnose 發表于 2021-5-15 15:26
結果如何? 可能分析一下?
筆記本沒有COM口
主站蜘蛛池模板: 黄色一级大片在线免费看国产一 | 在线免费观看日韩av | 免费黄色片视频 | 免费成人小视频 | 日韩精品一级 | 婷婷狠狠| 四虎三级 | 波多野结衣乳巨码无在线观看 | 国产又粗又猛 | 特一级黄色片 | 欧美亚洲激情 | 四虎1515 | 99re在线观看视频 | 亚洲精品一二 | 毛片毛片毛片 | 青青草在线免费视频 | 伊人免费 | 伊人久久中文字幕 | 久久av一区二区 | 国产精品一区视频 | 精品第一页 | 精品国产一区二区三 | www.天堂av| 久久久久久毛片 | 伊人影院久久 | 久久久久亚洲精品 | 免费观看av网站 | 夜夜操夜夜 | 亚洲欧美久久 | 91麻豆产精品久久久久久夏晴子 | 午夜黄视频 | 中文字幕精品一区久久久久 | 欧美成人a | 亚洲欧美日韩在线 | 黄色网av| 一级中国毛片 | 特黄毛片| 日韩成人免费视频 | 国产精品嫩草影院桃色 | 日日不卡av | 99视频+国产日韩欧美 |
