STM32F10x RS485 modbus通訊源程序,經(jīng)測(cè)試可用!
單片機(jī)源程序如下:
- #include "system.h"
- #include "SysTick.h"
- #include "led.h"
- #include "rs485.h"
- #include "crc16.h"
- * 函 數(shù) 名 : main
- * 函數(shù)功能 : 主函數(shù)
- * 輸 入 : 無
- * 輸 出 : 無
- int main()
- u8 i=0;
- SysTick_Init(72);
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //中斷優(yōu)先級(jí)分組 分2組
- LED_Init();
- RS485_Init(9600);
- TIM2_Init();
- while(1)
- UartDriver(); //串口驅(qū)動(dòng)
- i++;
- if(i%20==0)
- led1=!led1;
- delay_ms(10);
復(fù)制代碼- #include "rs485.h"
- #include "led.h"
- * 函 數(shù) 名 : RS485_Init
- * 函數(shù)功能 : USART2初始化函數(shù)
- * 輸 入 : bound:波特率
- * 輸 出 : 無
- u8 USART2_RX_BUF[64]; //接收緩沖,最大64字節(jié)
- u8 USART2_RX_CNT=0; //接收字節(jié)計(jì)數(shù)器
- u8 flagFrame=0; //幀接收完成標(biāo)志,即接收到一幀新數(shù)據(jù)
- unsigned char regGroup[5]; //Modbus寄存器組,地址為0x00~0x04
- void RS485_Init(u32 bound)
- GPIO_InitTypeDef GPIO_InitStructure;
- USART_InitTypeDef USART_InitStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOG|RCC_APB2Periph_GPIOA,ENABLE); //使能GPIOA\G時(shí)鐘
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);//使能USART2時(shí)鐘
- /* 配置GPIO的模式和IO口 */
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_2; //TX-485 //串口輸出PA2
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP; //復(fù)用推挽輸出
- GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
- GPIO_Init(GPIOA,&GPIO_InitStructure); /* 初始化串口輸入IO */
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3; //RX-485 //串口輸入PA3
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING; //模擬輸入
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3; //CS-485
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP; //推挽輸出
- GPIO_Init(GPIOG,&GPIO_InitStructure);
- //USART2 初始化設(shè)置
- USART_InitStructure.USART_BaudRate = bound;//波特率設(shè)置
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字長(zhǎng)為8位數(shù)據(jù)格式
- USART_InitStructure.USART_StopBits = USART_StopBits_1;//一個(gè)停止位
- USART_InitStructure.USART_Parity = USART_Parity_No;//無奇偶校驗(yàn)位
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//無硬件數(shù)據(jù)流控制
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收發(fā)模式
- USART_Init(USART2, &USART_InitStructure); //初始化串口2
- USART_Cmd(USART2, ENABLE); //使能串口 2
- USART_ClearFlag(USART2, USART_FLAG_TC);
- USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//開啟接受中斷
- //Usart2 NVIC 配置
- NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2;//搶占優(yōu)先級(jí)3
- NVIC_InitStructure.NVIC_IRQChannelSubPriority =2; //子優(yōu)先級(jí)2
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
- NVIC_Init(&NVIC_InitStructure); //根據(jù)指定的參數(shù)初始化VIC寄存器、
- RS485_TX_EN=0; //默認(rèn)為接收模式
- //1ms定時(shí)
- void TIM2_Init()
- TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);//使能TIM4時(shí)鐘
- TIM_TimeBaseInitStructure.TIM_Period=1000; //自動(dòng)裝載值
- TIM_TimeBaseInitStructure.TIM_Prescaler=72-1; //分頻系數(shù)
- TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;
- TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up; //設(shè)置向上計(jì)數(shù)模式
- TIM_TimeBaseInit(TIM2,&TIM_TimeBaseInitStructure);
- TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE); //開啟定時(shí)器中斷
- TIM_ClearITPendingBit(TIM2,TIM_IT_Update);
- NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;//定時(shí)器中斷通道
- NVIC_InitStructure.NVIC_IRQChannelSubPriority =3; //子優(yōu)先級(jí)
- TIM_Cmd(TIM2,ENABLE); //使能定時(shí)器
- //計(jì)算發(fā)送的數(shù)據(jù)長(zhǎng)度,并且將數(shù)據(jù)放到*buf數(shù)組中
- u8 UartRead(u8 *buf, u8 len)
- u8 i;
- if(len>USART2_RX_CNT) //指定讀取長(zhǎng)度大于實(shí)際接收到的數(shù)據(jù)長(zhǎng)度時(shí)
- len=USART2_RX_CNT; //讀取長(zhǎng)度設(shè)置為實(shí)際接收到的數(shù)據(jù)長(zhǎng)度
- for(i=0;i<len;i++) //拷貝接收到的數(shù)據(jù)到接收指針中
- *buf=USART2_RX_BUF[i]; //將數(shù)據(jù)復(fù)制到buf中
- buf++;
- USART2_RX_CNT=0; //接收計(jì)數(shù)器清零
- return len; //返回實(shí)際讀取長(zhǎng)度
- u8 rs485_UartWrite(u8 *buf ,u8 len) //發(fā)送
- u8 i=0;
- GPIO_SetBits(GPIOG,GPIO_Pin_3); //發(fā)送模式
- delay_ms(3); //3MS延時(shí)
- for(i=0;i<=len;i++)
- USART_SendData(USART2,buf[i]); //通過USARTx外設(shè)發(fā)送單個(gè)數(shù)據(jù)
- while(USART_GetFlagStatus(USART2,USART_FLAG_TXE)==RESET); //檢查指定的USART標(biāo)志位設(shè)置與否,發(fā)送數(shù)據(jù)空位標(biāo)志
- GPIO_ResetBits(GPIOG,GPIO_Pin_3); //設(shè)置為接收模式
- //串口驅(qū)動(dòng)函數(shù),檢測(cè)數(shù)據(jù)幀的接收,調(diào)度功能函數(shù),需在主循環(huán)中調(diào)用
- void UartDriver()
- unsigned char i=0,cnt;
- unsigned int crc;
- unsigned char crch,crcl;
- static u8 len;
- static u8 buf[60];
- if(flagFrame) //幀接收完成標(biāo)志,即接收到一幀新數(shù)據(jù)
- flagFrame=0; //幀接收完成標(biāo)志清零
- len = UartRead(buf,sizeof(buf)); //將接收到的命令讀到緩沖區(qū)中
- if(buf[0]==0x01) //判斷地址是不是0x01
- crc=GetCRC16(buf,len-2); //計(jì)算CRC校驗(yàn)值,出去CRC校驗(yàn)值
- crch=crc>>8; //crc高位
- crcl=crc&0xFF; //crc低位
- if((buf[len-2]==crch)&&(buf[len-1]==crcl)) //判斷CRC校驗(yàn)是否正確
- switch (buf[1]) //按功能碼執(zhí)行操作
- case 0x03: //讀數(shù)據(jù)
- if((buf[2]==0x00)&&(buf[3]<=0x05)) //寄存器地址支持0x0000~0x0005
- if(buf[3]<=0x04)
- i=buf[3];//提取寄存器地址
- cnt=buf[5]; //提取待讀取的寄存器數(shù)量
- buf[2]=cnt*2; //讀取數(shù)據(jù)的字節(jié)數(shù),為寄存器*2,因modbus定義的寄存器為16位
- len=3;
- while(cnt--)
- buf[len++]=0x00; //寄存器高字節(jié)補(bǔ)0
- buf[len++]=regGroup[i++]; //低字節(jié)
- break;
- else //寄存器地址不被支持時(shí),返回錯(cuò)誤碼
- buf[1]=0x83; //功能碼最高位置1
- buf[2]=0x02; //設(shè)置異常碼為02-無效地址
- len=3;
- break;
- case 0x06: //寫入單個(gè)寄存器
- if((buf[2]==0x00)&&(buf[3]<=0x05)) //寄存器地址支持0x0000-0x0005
- if(buf[3]<=0x04)
- i=buf[3]; //提取寄存器地址
- regGroup[i]=buf[5]; //保存寄存器數(shù)據(jù)
- led3=0;
- len -=2; //長(zhǎng)度-2以重新計(jì)算CRC并返回原幀
- break;
- else
- { //寄存器地址不被支持,返回錯(cuò)誤碼
- buf[1]=0x86; //功能碼最高位置1
- len=3;
- break;
- default: //其他不支持的功能碼
- buf[1]=0x80; //功能碼最高位置1
- buf[2]=0x01; //設(shè)置異常碼為01—無效功能
- len=3;
- break;
- crc=GetCRC16(buf,len); //計(jì)算CRC校驗(yàn)值
- buf[len++]=crc>>8; //CRC高字節(jié)
- buf[len++]=crc&0xff; //CRC低字節(jié)
- rs485_UartWrite(buf,len); //發(fā)送響應(yīng)幀
- void UartRxMonitor(u8 ms) //串口接收監(jiān)控
- static u8 USART2_RX_BKP=0; //定義USART2_RC_BKP暫時(shí)存儲(chǔ)詩句長(zhǎng)度與實(shí)際長(zhǎng)度比較
- static u8 idletmr=0; //定義監(jiān)控時(shí)間
- if(USART2_RX_CNT>0)//接收計(jì)數(shù)器大于零時(shí),監(jiān)控總線空閑時(shí)間
- if(USART2_RX_BKP!=USART2_RX_CNT) //接收計(jì)數(shù)器改變,即剛接收到數(shù)據(jù)時(shí),清零空閑計(jì)時(shí)
- USART2_RX_BKP=USART2_RX_CNT; //賦值操作,將實(shí)際長(zhǎng)度給USART2_RX_BKP
- idletmr=0; //將監(jiān)控時(shí)間清零
- else ////接收計(jì)數(shù)器未改變,即總線空閑時(shí),累計(jì)空閑時(shí)間
- //如果在一幀數(shù)據(jù)完成之前有超過3.5個(gè)字節(jié)時(shí)間的停頓,接收設(shè)備將刷新當(dāng)前的消息并假定下一個(gè)字節(jié)是一個(gè)新的數(shù)據(jù)幀的開始
- if(idletmr<5) //空閑時(shí)間小于1ms時(shí),持續(xù)累加
- idletmr +=ms;
- if(idletmr>=5) //空閑時(shí)間達(dá)到1ms時(shí),即判定為1幀接收完畢
- flagFrame=1;//設(shè)置命令到達(dá)標(biāo)志,幀接收完畢標(biāo)志
- else
- USART2_RX_BKP=0;
- * 函 數(shù) 名 : USART2_IRQHandler
- * 函數(shù)功能 : USART2中斷函數(shù)
- * 輸 入 : 無
- * 輸 出 : 無
- void USART2_IRQHandler(void)
- u8 res; //定義數(shù)據(jù)緩存變量
- if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET)//接收到數(shù)據(jù)
- res =USART_ReceiveData(USART2);//;讀取接收到的數(shù)據(jù)USART2->DR
- if(USART2_RX_CNT<sizeof(USART2_RX_BUF)) //一次只能接收64個(gè)字節(jié),人為設(shè)定,可以更大,但浪費(fèi)時(shí)間
- USART2_RX_BUF[USART2_RX_CNT]=res; //記錄接收到的值
- USART2_RX_CNT++; //使收數(shù)據(jù)增加1
- * 函 數(shù) 名 : TIM2_IRQHandler
- * 函數(shù)功能 : TIM2中斷函數(shù)
- * 輸 入 : 無
- * 輸 出 : 無
- void TIM2_IRQHandler(void)
- UartRxMonitor(1); ////串口接收監(jiān)控
- led2=!led2; //指示燈
- //delay_ms(100);
- TIM_ClearITPendingBit(TIM2,TIM_IT_Update); //更新中斷
STM32F10x RS485 modbus通訊源程序.7z
(181.3 KB, 下載次數(shù): 125)
2021-5-27 16:11 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
