查看: 1533|回復: 0
ZCC3221 28V高壓線性充電芯片
ID:817227 發表于 2021-6-3 15:12 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
n INTRODUCTIONnFEATURES
The ZCC3221 is a complete constant-current/ constant-voltage linear charger for single cell lithium rechargeable battery. No external sense resistor is needed, and no blocking diode is required due to the internal P-MOSFET architecture. Furthermore, the ZCC3221 is specifically designed to work with in USB power specifications. Its low external component count makes the ZCC3221 ideally suited for portable applications. Thermal feedback regulates the charge current to limit their temperature during high power operation or high ambient temperature. The charge current can be programmed externally with a single resistor. The ZCC3221 automatically terminates the charge cycle when the charge current drops to 1/10ththe programmed value after the final float voltage is reached. When the input supply (wall adapter or USB supply) is removed, the ZCC3221 automatically enters a low power sleep mode, dropping the battery drain current to less than
2mA.The ZCC3221 can be put into shutdown
mode, reducing the supply current to 50mA.Other features include battery pack temperature monitor, under voltage lockout, automatic recharge and two status pins to indicate charging
and charge termination.
l Charges Single Cell Lithium Battery Directly from USB Port or AC Adapter
l Input Voltage Range From4.5V to 24V
l Input OVP:6.5V
l No External MOSFET, Sense Resistor or Blocking Diode Required
l Preset4.20V/4.35VCharge Voltage
l Continuous Programmable Charge Current Up to 1.2A
l Recharge Conditioning for Reviving Deeply DischargedCellsandMinimizingHeat Dissipation during Initial Stage of Charge
l Constant-Current/Constant- Voltage/Constant-TempOperationwith Thermal Regulation to Maximize Charge Rate Without Risk of Overheating
l Battery Reverse Protection
l Automatic Recharge
l Battery Temperature Sensing
l Charge state pairs of output, no battery and fault status display
l Charge Current Monitor Output for Gas Gauging
l Automatic Low Power Sleep Mode When Input Supply Voltage is Removed
l Soft-Start Limits Inrush
主站蜘蛛池模板: 欧美精品三区 | 亚洲精品www久久久久久广东 | 亚洲激情成人 | www.huangse| 特一级毛片 | 91日韩在线 | 成人免费黄色大片 | 香蕉视频在线观看网站 | 日韩精品视频一区二区三区 | 国产成人毛片 | 国产乱码精品一区二区三 | 亚洲黄色在线 | 最新91视频 | 亚洲精品免费在线观看 | 国产精品久久久久久久久借妻 | 青青草免费在线 | 四虎com | 亚洲激情另类 | 爱啪啪av| 午夜a级片 | 久久最新视频 | 亚洲成人精品视频 | 亚洲福利视频一区 | 欧美一区 | 激情一区二区三区 | 三级在线看 | 国产成人综合视频 | 亚洲欧美日韩综合 | 亚洲视频在线观看 | 伊人综合影院 | 日本不卡一区 | 黄色片亚洲 | 999国产视频 | 国产在线一区二区三区 | 国产成人在线免费观看 | 欧美日韩国产一区二区 | 国产精品国产精品国产专区不卡 | www.夜夜 | 欧美日皮视频 | 欧美久久精品 | 超碰在线中文字幕 |
