查看: 3911|回復: 5
16x32 P10廣告屏點陣任意位置畫點畫線 單片機程序
ID:168911 發表于 2021-6-5 20:45 | 顯示全部樓層 |閱讀模式
16x32  P10廣告屏點陣任意位置畫點畫線,點陣直接用P10單紅門頭廣告屏,省去了自己焊接,刷了一個時鐘走時程序,圖片中間點是秒閃,
用的是12c5a60s2。
#include <REG52.h>
#include<intrins.h>
#include<math.h>
#define uchar unsigned char
#define uint unsigned int
#define BB P3
sbit SHCP=P2^3;        // 移位時鐘
sbit STCP=P2^4;        // 鎖存時鐘
sbit DATA=P2^5;       // 數據輸出
sbit OE = P2^0;           // 使能輸出
uchar PLAYBUF[64];
uchar a,b;
uchar sec=0,min=0,timecount=0;
bit point;
void serial_input(uchar dat);
void LED_dot_write(uchar x,uchar y,uchar c);
void line(uchar  x1, uchar  y1, uchar  x2, uchar  y2, uchar c);
void number(uchar su,uchar x,uchar y,uchar c);
void display();
    EA = 1;
    TMOD=0x01;   //timer0為模式1
    TH0 = 0x4c;
    TL0 = 0x00;
    ET0 = 1;
    TR0 = 1;   //定時器0可以工作
           a=sec-1;b=min-1;
        number(sec/10,17,0,1);
        number(sec%10,25,0,1);
        number(min/10,0,0,1);
        number(min%10,8,0,1);
        line(15,4,15,5,2);
        line(16,4,16,5,2);
        line(15,9,15,10,2);
        line(16,9,16,10,2);
        display();
        number(a/10,17,0,0);
        number(a%10,25,0,0);
        number(b/10,0,0,0);
        number(b%10,8,0,0);
/************數據串行輸入 *************************/
    unsigned char m = 0x00;
    for(m=0X00;m<8;m++)
        DATA=~dat&0x80;
        SHCP=1;
        SHCP=0;
        dat<<=1;
/******************任意位置畫點******************************************/
    uchar i;
    if(x>=32) return;
    if(y>=16) return;
    i=0x80;
    i>>=x-((x>>3)<<3);
    switch(c)
        case 0:PLAYBUF[(y<<1)+((x>>4)<<5)+((x>>3)&0x01)] &= ~i;break;
        case 1:PLAYBUF[(y<<1)+((x>>4)<<5)+((x>>3)&0x01)] |= i;break;
        case 2:if(point)PLAYBUF[(y<<1)+((x>>4)<<5)+((x>>3)&0x01)] |= i;
               else PLAYBUF[(y<<1)+((x>>4)<<5)+((x>>3)&0x01)] &= ~i;break;
        default: break;
/*****************任意位置畫線******************************************/
    uchar  x, y, t;
    if((x1 == x2) && (y1 == y2))
    LED_dot_write(x1, y1, c);
    else if(fabs(y2 - y1) > fabs(x2 - x1))
        if(y1 > y2)
            t = y1;
            y1 = y2;
            y2 = t;
            t = x1;
            x1 = x2;
            x2 = t;
        for(y = y1; y <= y2; y ++)
            x = (y - y1) * (x2 - x1) / (y2 - y1) + x1;
            LED_dot_write(x, y, c);
        if(x1 > x2)
            t = y1;
            y1 = y2;
            y2 = t;
            t = x1;
            x1 = x2;
            x2 = t;
        for(x = x1; x <= x2; x ++)
            y = (x - x1) * (y2 - y1) / (x2 - x1) + y1;
/*********************任意位置畫數字*********************************************************/
     if(su==0)
           line(x,y+4,x,y+10,c);
        line(x+1,y+3,x+5,y+3,c);
        line(x+6,y+4,x+6,y+10,c);
        line(x+1,y+11,x+5,y+11,c);
        line(x+1,y+9,x+5,y+5,c);
    if(su==2||su==3||su==5||su==6||su==8||su==9)
          line(x+1,y+7,x+5,y+7,c);
          if(su==5||su==8||su==9)
               line(x,y+4,x,y+6,c);
               if(su==5)
                   line(x+1,y+3,x+6,y+3,c);
                line(x+6,y+8,x+6,y+10,c);
                line(x,y+11,x+5,y+11,c);
               if(su==8)
                line(x,y+8,x,y+10,c);
                line(x+6,y+4,x+6,y+6,c);
            if(su==9)
        if(su==2)
               line(x,y+3,x+5,y+3,c);
            line(x+1,y+11,x+6,y+11,c);
        if(su==3)
        if(su==6)
    if(su==1||su==4||su==7)
        line(x+6,y+3,x+6,y+11,c);
        if(su==4)
            line(x,y+3,x,y+6,c);
        if(su==7)
            LED_dot_write(x+6,y+3,0);
/***************整屏顯示*************************************************/
void display()
    uchar i = 0x00;
    uchar j = 0X00;
    uchar k = 0x00;
    uchar buf;
    uchar COUNT;
    for(k=0;k<4;k++)
        for(j=0;j<2;j++)
            for(i=0;i<2;i++)
                buf = PLAYBUF[24+(k<<1)+i+(j<<5)];serial_input(buf);
                buf = PLAYBUF[16+(k<<1)+i+(j<<5)];serial_input(buf);
                buf = PLAYBUF[8+(k<<1)+i+(j<<5)];serial_input(buf);
                buf = PLAYBUF[(k<<1)+i+(j<<5)];    serial_input(buf);
        STCP=1;
        STCP=0;
        BB=k;
        OE=1;
           COUNT =200;
        while(COUNT--);
        OE =0;
void time50ms(void) interrupt 1
       TH0 = 0x4c;
    TL0 = 0x00;
    timecount++;
    if(timecount==10)
        timecount=0;
         point=!point;
          if(point)
              sec++;
        if(sec>59)
            sec=0;
            min++;
        if(min>59)
        min=0;
ID:885138 發表于 2021-6-6 10:47 來自觸屏版 | 顯示全部樓層
厲害了,樓主電路圖有嗎
ID:168911 發表于 2021-6-6 18:57 | 顯示全部樓層
xxd0708 發表于 2021-6-6 10:47
厲害了,樓主電路圖有嗎
這個不用電路圖也可以,只要對應管腳就可以,這個放心好了
ID:1002257 發表于 2022-1-28 20:17 | 顯示全部樓層
這個怎么接51版
ID:168911 發表于 2022-6-25 21:11 | 顯示全部樓層
595移位,鎖存,數據,OE,掃描,
ID:1112603 發表于 2024-6-8 13:59 | 顯示全部樓層
這個程序為點陣的使用提供了一個別樣思路,真不錯!
主站蜘蛛池模板: 日韩欧美一区在线 | 日韩视频在线免费观看 | 成人在线播放网址 | 成人一区二区三区 | 精品99久久 | 狠狠躁躁夜夜躁波多野结依 | 亚洲一区二区免费电影 | 精品国产伦一区二区三区观看方式 | 国产一级在线 | 欧美一卡二卡在线观看 | 国产在线观看一区 | 免费国产精品久久久久久 | 国产日韩精品在线 | 91国内产香蕉 | 在线观看国产视频 | 亚洲成人三级 | 99久久久久国产精品免费 | 毛片免费看 | 欧美三级视频 | 国产精品视频在线免费观看 | 久久精品久久久 | 成人免费一区二区三区牛牛 | 免费在线观看av网站 | 国产成人精品一区二区三 | 亚洲精品久久久久中文字幕二区 | 日日日操 | 99免费 | 日韩成人免费视频 | 在线观看你懂的网站 | 欧美日本韩国一区二区 | 亚洲高清一区二区三区 | 欧美国产91 | 成人欧美一区二区三区黑人孕妇 | 在线视频亚洲 | 伊人成人免费视频 | 日韩在线日韩 | 一色一黄视频 | 国产精品久久久久久久久久免费 | 精品成人免费一区二区在线播放 | 久久久久久国产精品免费免费狐狸 | 午夜精品一区二区三区三上悠亚 |
